R56 head rest problem
Old Jul 23, 2011 | 01:07 PM
Hampton1's Avatar
Hampton1
head rest problem
Own a 2011 MCCS, how do I remove the plastic piece from the back seat head rests so they aren't blocking my view? I know u can remove the actual head rest, but would like to remove the plastic piece so I can push them all the way down. Any ideas?
Old Jul 23, 2011 | 02:29 PM
tccox's Avatar
tccox
Ok, remove headrest, take a very small screwdriver or even a bent paper clip and push metal pin in plastic collar out. Once you get it started you can finish pulling it out with your fingers. Remove plastic collar and reinstall headrest. Repeat for the othe headrest.
Best thing I've done since buying my mini
Old Jul 23, 2011 | 07:42 PM
arnnad's Avatar
arnnad
headrests
Anybody know if this will work in the CM? The front head rest bottom is almost level with the top of my wife's head, who is 5'. I had thought the plastic pieces were locks to prevent the removal of the headrest and not to prevent maximum lowering.
Thanks for your input
Old Jul 25, 2011 | 05:15 AM
Hampton1's Avatar
Hampton1
Thanks...it was an easy process and now I can see out the back window...didn't even take 5 minutes.
Old Jul 25, 2011 | 02:58 PM
Jolio's Avatar
Jolio
Did you end up taking them out or pushing them down?
Old Jul 25, 2011 | 03:41 PM
jacobjr's Avatar
jacobjr
Removal of the little black "collars" allows you to push them all the way down for maximum visibility instead of taking them out. That way should you have occupants in the rear they will still have the protection of the headrests by adjusting them back up.
Old Jul 25, 2011 | 04:40 PM
mini-mine's Avatar
mini-mine
I just picked up my 2011 Cooper Friday and was so frustrated by this, I thought I was missing something! It just seemed like they should go all the way down! Thank goodness they are now all the way down like they were in my 2006! Seems like a really dumb thing for them to be that high!
Old Jul 26, 2011 | 05:24 AM
Hampton1's Avatar
Hampton1
I just removed the collars using a small screwdriver and a hammer. The pins pushed right out...doesn't require a lot of pressure, just a few light taps. The head rests slipped right back into place, but now slide all the way down to the seat. The dealer told me that it was a new DOT mandate for whiplash injuries...I new someone on the NAM website had already "resolved" this issue...Thanks Again.
Old Jul 30, 2011 | 10:10 AM
Snappychip's Avatar
Snappychip
Thanks for the tip. I said a bunch of four letter words the first time I folded my seats down and found these collars. 5 minutes and they are gone now.
Old Jul 30, 2011 | 01:06 PM
arnnad's Avatar
arnnad
head rests
My Countryman doesn't have these collars. The head rest columns go through a black release device that's part of the underlying seat, with no apparent way to remove without damaging the seat itself.
Old Aug 20, 2011 | 11:34 AM
RedDog888
Just do the rear seats delete mod!! There
You have it!!! All the view you can get!!LOL
Kimolaoha
Jul 5, 2023 01:04 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
MIminiclubman
Aug 5, 2015 09:14 PM
PatrikKN
Aug 5, 2015 09:10 PM
