R56 filling in oil (R56 2008)
Old Jul 19, 2011 | 12:29 AM
zoranb's Avatar
zoranb
How often do you fill in oil to your MiniCooperS?
Personally i have filled in 2lt of oil in the past 4 months (is this normal?)
Old Jul 19, 2011 | 02:33 AM
Porthos's Avatar
Porthos
How hard are you driving?
Old Jul 19, 2011 | 03:34 AM
chazct's Avatar
chazct
long story short (full report later) my 08 S was 3 qts low blew engine. mini says it is not unusual to burn a quart every 800 miles (?!/!) so every other tank full of gas make sure you check and add a qt.
Old Jul 19, 2011 | 11:03 AM
countryboyshane's Avatar
countryboyshane
What a load of complete B.S. This isn't a 2-stroke diesel engine.
I can go 5000 miles before an oil change and not have to add one drop of oil to the crankcase in between changes. I love how MINI is basically saying, "you got a Monday build." It seems with the PSA engines you either get a great built engine or a pile of scrap. There is no middle ground and it's a 50/50 roll of the dice. I think I would rather have my engine rebuilt than take a gamble on another R56 down the road.
Old Jul 19, 2011 | 11:18 AM
Porthos's Avatar
Porthos
I could have told you to check your oil. That is a no brainer to owning a car. And yes every other fill up I check my oil.
Old Jul 20, 2011 | 02:12 PM
genik's Avatar
genik
i did 2000km last 3-4months and i had to fill in 2lt, is this normal? and if it is, why does this happen?
and i dont really drive so hard
Old Jul 20, 2011 | 03:42 PM
chazct's Avatar
chazct
i'm sorry, but a 36 month old car of any make shouldn't be burning oil, especially when the manufacturer is telling not to bring it in for service for 16,000. i went thru the same issue with my wife's vw passat when they told me "oh yes it is normal to burn up to a quart of oil every 3K miles". B.S.
my little S had 79k in 36 months. i usually drive around 30 k per year. funny how for the first 78,000 miles i never burned oil
Old Jul 20, 2011 | 06:22 PM
yetti96's Avatar
yetti96
Don't forget it may not be burning oil or getting past the rings it is the crappy PCV system that allows the carbon buildup on the DI motors. That oil mist has to go somewhere and if you get it misting enough and it gets "burned" through the motor with the fuel it will eventually lower the level. Every car and situation is different.
Old Jul 20, 2011 | 10:01 PM
genik's Avatar
genik
plz explain further and simplyer what you describe here, cause im not really into technicall issues
woodstudio
Mar 15, 2020 08:28 AM
Zettinger
Aug 25, 2015 04:04 PM
Lex2008
Aug 16, 2015 08:33 PM
kwijmbo
Aug 5, 2015 09:00 PM
