R56 Which sensor measures intake air temp on R56?
Old Mar 27, 2010 | 10:30 AM
gkp's Avatar
gkp
I have an error code P110F that may relate to intake air temperature. Is there a separate sensor for intake temp? Or is the data taken from the MAF or the ambient air temp sensor? Does anyone know?
Also, does anyone know where the coolant temperature sensor is?
Old Mar 27, 2010 | 12:50 PM
pillar's Avatar
pillar
i would think its the MAF. could be excess oil.
Old Mar 27, 2010 | 01:09 PM
Oxybluecoop's Avatar
Oxybluecoop
coolant temperature sensor (N14).pdf
Old Mar 27, 2010 | 03:29 PM
countryboyshane's Avatar
countryboyshane
The intake air temperature sensor should be the same sensor that measures ambient air temp, and that one is located somewhere in the lower front bumper near the fog lights. If you're referring to the post intercooler charge-air temp that's a different story...
Old Mar 27, 2010 | 03:50 PM
gkp's Avatar
gkp
Gracias, gentlemen.
Old Mar 27, 2010 | 08:49 PM
slinger688's Avatar
slinger688
Just wanted to clarify. The intake air temperature sensor is not the same as the ambient air temperature sensor. The ambient air temp sensor is on the lower front bumper. The MAF does not measure intake air temp because it is before the IC. The air intake temp sensor is after the IC, on the hard pipe on the passenger side.
Old Mar 27, 2010 | 09:04 PM
slinger688's Avatar
slinger688
Take a look at this, it is part 5.
Old Mar 28, 2010 | 08:20 AM
gkp's Avatar
gkp
Thanks, Slinger. So that's it on top of the pipe? Is the diagram from OEM.com? I was looking for a diagram there but didn't find it.
Old Mar 29, 2010 | 06:33 AM
slinger688's Avatar
slinger688
Yes on top of the pipe. Got the diagram from Realoem.com.
Kimolaoha
Jul 5, 2023 01:04 PM
tylewis
Aug 18, 2015 06:53 AM
massmini03
Aug 12, 2015 11:19 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
