R56 Only 410 miles and exceed 4500rpm
Old Dec 15, 2009 | 10:05 AM
zemina's Avatar
zemina
I thought it should be covered here but I could not find it. Sorry if this is already covered.
Ouch... it was close to 4500rpm when I drove wife's 2010 Mini cooper S yesterday. While I driving I just wanted to try to use the paddle shifter (since I drove only 6 spd manual Mini cooper S), so I push the paddle shift and more gas.... wow suddenly rpm went to close 4500rpm, so I off gas quickly... probably be rpm was 4200 or 4300 or 4400... but this is first time to get over 4000rpm.
The manual said that "... but do not exceed the following ... 4500rpm or 100mph ..." I hope it won't hurt the new engine
I just want to hear the engine will be fine, but what do you guys think? is she going to be okay?
Old Dec 15, 2009 | 10:15 AM
phxsteele's Avatar
phxsteele
it will be fine. Just dont make a common pratice out of it until the break in is over. I was the same way with mine when I first got it not I run it like a spotted ape. My baby hits 6500 on a daily basis.
Old Dec 15, 2009 | 10:37 AM
nickminir56's Avatar
nickminir56
Don't do it on a daily basis .
Old Dec 15, 2009 | 10:46 AM
thevelourfog's Avatar
thevelourfog
It's perfectly fine, that's not over doing it at all!
Old Dec 15, 2009 | 11:03 AM
zemina's Avatar
zemina
Ahh yeah, Thanks all replies. But my concern was it's close to 4500rpm (maybe it was 4300 or 4400) went few seconds (maybe 5 ~ 10 seconds) constantly before I off the gas...
Old Dec 15, 2009 | 11:18 AM
sequence's Avatar
sequence
despite what the manual says, it's good to vary yr rpms during break-in, just dont use the cruise yet.
Dont sweat the 4500 blip a bit.
Old Dec 15, 2009 | 12:53 PM
tambi's Avatar
tambi
I'd hit 6k rpm two weeks into the purchase, trying to race by boss's S2K on the ramp to the highway..
I lost tho...
Old Dec 15, 2009 | 01:23 PM
Elwood09's Avatar
Elwood09
There are a lot of folks that swear your engine will perform better and last longer if you ignore the factory recommended break in.
I chose to go with the recommendation, but I certainly wouldn't worry about a quick excursion above 4K! I am absolutely sure that you will never see that one event cause a problem for you!
Enjoy your new car! They are awesome, aren't they?!?!?
Old Dec 15, 2009 | 01:41 PM
drewstermalloy's Avatar
drewstermalloy
I wouldn't worry about it.
Old Dec 15, 2009 | 03:26 PM
zemina's Avatar
zemina
Ahh... yeah feel better... Thanks much
Old Dec 15, 2009 | 03:30 PM
uber.bucket's Avatar
uber.bucket
you're fine ;p
what's worse is babying an engine during break-in period
Old Dec 15, 2009 | 04:57 PM
Btwyx's Avatar
Btwyx
You didn't even hit 4500, so why worry. Its only guidelines, so why worry. I hit the redline in Quentin exiting the dealer, it didn't seem to do him any harm. (Then I reread the manual and thought I'd better be a bit more gentle.) I slipped up plenty of times during break in on al the MINIs.
Old Dec 15, 2009 | 05:39 PM
thevelourfog
I've heard that bogging the motor is worse during break in than high revs (not applicable with the auto). I also think you're already well broken in at 400 miles anyways.
Old Dec 15, 2009 | 07:35 PM
gawannamini's Avatar
gawannamini
Don't give it a second thought - no damage of any kind could have occurred. Modern engines are very well machined and a break in period is far less important than in years past. You will find posts here in NAM from engine mechanics that go so far as to say that being too easy on the engine those first few thousand miles is actually not good for seating the rings in the engine.
Old Dec 15, 2009 | 10:35 PM
BensMini's Avatar
BensMini
I made several trips into the forbidden zone during breakin. None were intentional but after all the cars I've owned I didn't lose any sleep over it. I am one of those who feel a spirited breakin is good in the long run.
Old Dec 15, 2009 | 10:41 PM
wildcrazy442000's Avatar
wildcrazy442000
+1
Old Dec 15, 2009 | 11:03 PM
not-so-rednwhitecooper
Originally Posted by gawannamini
Don't give it a second thought - no damage of any kind could have occurred. Modern engines are very well machined and a break in period is far less important than in years past. You will find posts here in NAM from engine mechanics that go so far as to say that being too easy on the engine thoses first ffew thousand miles is actually not good for seating the rings in the engine.
This is true. The rings are seated in under 500 miles. The rings are the only part of then engine that actually "break in" during the first few hours of the engine running.
The break in period is BMW covering its own ***.
Old Dec 16, 2009 | 04:54 AM
AustinS's Avatar
AustinS
Take a look at this article and see what you think.
http://www.mototuneusa.com/break_in_secrets.htm
Old Dec 16, 2009 | 08:22 AM
edgein's Avatar
edgein
Plus I'm sure every person who took that car out on a test drive before you ran it to well above 4500.
(What?! You mean I'm the only guy who takes cars out on spirited test drives?!)
Old Dec 16, 2009 | 10:17 AM
ian3's Avatar
ian3
I accidentally did the same, had to make a quick move to get out of an intersection, it went high, but didn't last long. I'm not going to make a goal out of it, but things are still running so far...
Old Dec 16, 2009 | 08:26 PM
BuffMini's Avatar
BuffMini
I dunno, my mini tech said to give it a thousand and just run the crap out of it...thats what I did and 15,000 miles later all is good! Mine is justa cooper though
Old Dec 17, 2009 | 09:44 AM
MauriceW's Avatar
MauriceW
I try to vary engine RPM a lot and not rev the engine to high RPMs under load during the break in period. I will allow high RPM engine braking, however. I have read that it helps the rings seat. I will get back to you in 100,000 miles to let you know if it's working! At least I will once my car comes in!
Old Dec 17, 2009 | 03:25 PM
Bullitt44's Avatar
Bullitt44
"Bullitt"
no worries at all. Most engine builders request 100 mile break in.
Old Dec 17, 2009 | 03:34 PM
J_'09s's Avatar
J_'09s
I was "playing" with a Civic type S the day after i took delivery of mine. 15 thousand miles later and its still as strong as the day i was messing around. Good times.
Old Dec 18, 2009 | 11:25 PM
k3v1n's Avatar
k3v1n
lol you guys are funny. I redlined mine from the way home from the dealer
