R56 How should i use DSC on my snowy commute?
I drive about 40 miles each way every day and i go up and over mountains....a total blast in the summer...but now that the winter is here, i need a crash course in how to use the DSC button.
woooosh...right over my head....
..gotta love the unintentional pun.
So is it on by default? Or is it on when i push the button and the DSC light is on? I noticed today when i was driving ( no light on) that when i spun the tires the light would blink on for a second.
default is on as it should be. great safety feature. only when you press and hold and see that icon in the tach is it disabled. i haven't had to disable it to get moving in ice and snow yet. only disabled it for some use-at-your-own-risk "fun".
When you push the DSC button, and a light should come on and your computer should say DSC off... however you need to hold it down...
Now what happened to you is that when it blinks, thats when it takes action over throttle to prevent slip and regain tractions...
In case you are interested, here is a link from the MINIUSA.com website about DSC:
http://miniusa.com/#/learn/FACTS_FEA...ety_Features-m
Just click on the tab there and it should help you to understand how and what DSC is and does.
There are times, going up a steep driveway, for instance, when turning it off will allow you to get up the driveway - with it on you wouldn't. This is only at slow speed. Needed it today to get up my snowy driveway.
Not for use traveling on the regular roads.
And thanks for the link and all the help...
cool...thanks!!
There are two systems controlled by the DSC button--ASC, and DSC. Leave them on unless you get stuck in the snow and ASC is causing problems starting up. In most cases, ASC will help when there is limited traction, occasionally it gets in the way.
If you are running snow chains, you may want to turn it off.
Samhillrocks
Sep 29, 2015 12:55 PM
Colt45Magnus
Sep 16, 2015 11:15 AM
