R56 Are "short" antennas just ... short?
Old Jul 19, 2009 | 07:27 AM
slindo's Avatar
slindo
Or do they contain any extra trickery to make up for the shorter length?
I am looking for a shorter antenna for my '09 MC to use when I am cartopping a boat. There are several in the $30-40 range, but they appear to be just stubs of aluminum that, being shorter than the stock antenna, can be expected to produce somewhat inferior reception on marginal stations.
It looks to me like it DIYing a clone should take all of ten minutes, if they are just solid metal. But if they contain any gadgetry to compensate for the shorter length, then I probably ought to buy one of the commercial versions. Anyone know?
Old Jul 19, 2009 | 07:34 AM
mdrums's Avatar
mdrums
I have a Cravenspeed short anntenna and it works just fine. It was $24. I do not know if it has something inside to make it work but it does.
Old Jul 19, 2009 | 09:01 AM
OldRick's Avatar
OldRick
They are just short metal stubs. They don't work as well as stock.
Old Jul 19, 2009 | 02:23 PM
Robin Casady's Avatar
Robin Casady
Try this experiment. Find a marginal station in your area. Remove the antenna and see how the reception changes. I couldn't tell the difference for the stations I listen to. However, I usually use an iPod or iPhone, so I don't spend a lot of time with the radio.
Old Jul 21, 2009 | 09:40 AM
Chemdean's Avatar
Chemdean
I changed to a 4in. Alta antenna recently. For stations in my area, I noticed only a slight decline in reception of weaker stations.
Old Jul 21, 2009 | 09:56 AM
Porthos's Avatar
Porthos
My Alta 2in was $20 and I really can't tell the difference even with mountains in the way
Old Jul 21, 2009 | 10:15 AM
jdj1314's Avatar
jdj1314
I have a 09 MCS and replaced my antenna with a cravenspeed antenna and I can't tell the difference. It works and looks great. I also use my ipod most of the time.
Old Jul 21, 2009 | 10:19 AM
drewstermalloy's Avatar
drewstermalloy
I've used the radio twice in the entire year I have had the car. The smaller antennas make no difference to me.
Old Jul 21, 2009 | 09:29 PM
gregdconsulting's Avatar
gregdconsulting
I have a short antenna. Reception is worse and if you ever listen to AM it is horrible. I put the stock one back on.
Old Jul 22, 2009 | 07:20 AM
Engender's Avatar
Engender
I have an alta shorty... I think it's the 6", but the reception is just fine. Granted, I live in a large Metro area with a lot of radio tower coverage and I don't listen to AM, but I've never had a problem getting WHYY, my default radio station.
Old Jul 22, 2009 | 08:01 AM
rockridge's Avatar
rockridge
I have the Alta 2" antenna, and reception is much worse for the distance FM stations I listen to on occasion. I have kept it on, because I listed to my Ipod and MP3 CDs 95% of the time, and I like the look better than stock.
Old Jul 22, 2009 | 09:16 PM
MiniManiac74's Avatar
MiniManiac74
I bought one for $9 off Ebay and I never have radio reception problems.
Old Aug 14, 2009 | 09:19 PM
arturo chavez's Avatar
arturo chavez
i just cut mine to the thick part and put AN EIGHT BALL and it looks cool and works better than the shorties
Old Aug 15, 2009 | 06:29 AM
ran-o-matic's Avatar
ran-o-matic
Originally Posted by Engender
... I don't listen to AM, but I've never had a problem getting WHYY, my default radio station.
I've been trying to avoid starting a new thread on antennas and this seems as good a place as any to bring this up. Looking on my Clubman, there is an antenna in the driver's side rear window. On other cars configured like this, the window antenna would be for FM, and the long antenna on the roof would be for AM. If the MINI works the same way, that would explain why FM stations like WHYY are not impacted when using a shorter antenna. AM really should be where you see problems. OR - I could be completely wrong.
Old Aug 15, 2009 | 06:32 AM
ran-o-matic
Almost forgot - I didn't look at the windows on a Coupe, so I don't know if there are any antennas in them. Some other car brands interlace the antenna with the rear window defroster.
Old Aug 15, 2009 | 06:36 AM
Tsar's Avatar
Tsar
My reception got worse, but I prefer the look of the smaller antenna so it's staying. Plus I prefer to listen my ipod anyways.
Old Aug 15, 2009 | 09:28 AM
jnoll's Avatar
jnoll
short antenna
according to my MA the grid on my 09 Clubman drivers rear window is an antenna, but I don't know if it is for AM or Fm. I thought it was strange to have a defroster grid on just 1 side window, but he informed me its not.
Old Aug 15, 2009 | 09:42 AM
ran-o-matic
Now I'm more curious, so I tried an experiment. Tuning a weak FM station on the radio, I removed the roof antenna. No affect. I then tuned an AM station and removed the roof antenna. Complete loss of reception. At least on a Clubman, the roof antenna seems to be for AM and not FM.
Old Aug 15, 2009 | 06:13 PM
rataczak's Avatar
rataczak
I could tell no difference from stock to stubby!!!
Old Aug 15, 2009 | 06:19 PM
ran-o-matic
AM, FM or both?
Old Aug 15, 2009 | 06:40 PM
rataczak's Avatar
rataczak
I honestly have never tried on AM channels. But I can tell no difference on FM!
Old Aug 15, 2009 | 07:08 PM
Mind.The.Gap's Avatar
Mind.The.Gap
I replaced my stock antenna with an Alta 2" and still get great reception. It looks a lot better and to me is definitely worth the 20 bucks.
Old Aug 15, 2009 | 07:42 PM
ran-o-matic
AM is a real wasteland these days, I guess. I really think that rooftop antenna is for AM and not FM. The Coupe must have the FM antenna somewhere else, just like the Clubman. Otherwise people would notice reception problems when they remove most of the antenna.
Like I said above - interlaced with the rear defroster - is a good bet.
Old Aug 15, 2009 | 08:15 PM
ron-s mini's Avatar
ron-s mini
I am in a metro area and it does not make much difference here.
Old Aug 16, 2009 | 05:55 AM
swflaboy's Avatar
swflaboy
I have the 4" from Alta. I noticed no difference in the few FM stations I listen to regularly. I never listen to AM but tried to find some talk/news recently while on a 2600mi trip and the reception was awful. Don't know if that had anything to do with the new antenna.
