R56 Hood Scoop Melt Down Resolution Question
Old Sep 2, 2009 | 05:11 PM
  #151
orangecrush's Avatar
orangecrush
Originally Posted by Dwight Walhood
Hey Mark, you beat me to the "mark" by 8 minutes! Amen anyhow, and besides, your pic is better than mine.
LOL, the funny part is I wrote "yeahhh, what he said" almost immediately after you wrote what you wrote. Then I got called to dinner and forget to hit send.
I come back from dinner and you already made a post about it... hehe.
Okay, nevermind, it was funnier in my head...
Mark
Old Sep 2, 2009 | 05:20 PM
  #152
orangecrush
Originally Posted by eR1c
okay okay!!
Now I know your guys thoughts on the Mini Mania one!
trying to save a few $$, -having my Porsche engine re-built w/all racing/upgraded performance parts ain't cheap!!! So was trying to skimp on the Mini -my bad.
M7 it is.
I know, sometimes the parts are like Corvette or Porsche parts... it comes with a Corvette tax...the prices seem too much for what they are. However, I think buying a piece of stainless with holes in it with no insulation is nothing more than a heat deflector you'd find on a cheap dirtbike exhaust.
Old Sep 2, 2009 | 05:28 PM
  #153
rwwilsonjr's Avatar
rwwilsonjr
okay okay!!
M7 it is.
Who knows if it will work? It would be nice if MM would do some testing and report the results. That said, it just might reduce the heat going to the scoop "enough" to prevent it from warping.
The theory seems to be "similar" to a heat sink (used to reduce heat in electronics components). Stock car racers used to install a false floor which produced an air space between the firewall and the false floor. This air space was effective at reducing the heat to the interior of the car (especially the floorboard).
I guess somebody will just have to try it and see what happens.
Old Sep 2, 2009 | 09:36 PM
  #154
eR1c's Avatar
eR1c
yeah, i was kind of hoping someone had tried this MM heat shield out so they could give us the scoop (no pun intended). anyway, M7 already ordered.
Old Sep 3, 2009 | 08:39 AM
  #155
Ken G.'s Avatar
Ken G.
To answer the earlier question, my warping was between the top center to the top right of my scoop.
I wouldn't expect the mounting points to directly warp the plastic all the time. I've seen other plastics react to heat and stress by bending in accordance with the plastic's internal stresses and warping in ways that don't follow how the part is mounted. How the part was molded and the internal stresses created in that process affects how the part will deform as much as where the stress is applied by the fasteners holding the part in place.
What I'd like to know are more facts about this problem, like what's the actual temperature that section of the hood is reaching; exactly what type of plastic we're dealing with; and what it's exact melting temperature? Hmm, time to buy that remote sensing infrared thermometer I've always wanted...
Old Sep 3, 2009 | 09:38 AM
  #156
Dwight Walhood's Avatar
Dwight Walhood
plastic and PLASTIC
The damage you describe is the same I saw on mine and every other MCS I've seen that had some miles on it. IMO, the design is typically over engineered for a part that does nothing. The problem seems to be cheap plastic. Hi-Temp plastic ain't cheap. I feel the bean counters won out over the engineers, as usual .
I've got one of those fancy thermometers. Before mods, I was seeing scoop surface temps of 240-250 F. Some have reported temps as high as 350F. ! After mods (see sig), it's down to ~125F. My temp gun is a beaut, Laser/IR, point and area readings with a temp range of -6 to +968F. and accuracy of +/-4%. Cost a bundle, $40 at Harbor Freight! Try it on the BBQ.
Old Sep 3, 2009 | 10:44 AM
  #157
Milton Mini's Avatar
Milton Mini
Just had my hood scoop replaced after 2,400 miles. They said the center pin had separated possibly due to heat. Old scoop was bowed up. We'll see how long this one lasts. Local dealer is new (opening on 8/11/09) so has limited experience.
John
Old Sep 3, 2009 | 10:54 AM
  #158
LadyGodiva's Avatar
LadyGodiva
18,000miles on my '08 Clubman. Getting a new scoop next week.
Old Sep 4, 2009 | 12:51 PM
  #159
RedDog888
just remove the scoop grill, add a deflector and some gold reflective heat barrier film to the underside of the bonnet above the turbo and problem solved. In the winter will put gill back in for rain, but outside temp is way down and the barrier film seems to really do the job.
Old Sep 7, 2009 | 07:31 AM
  #160
sequence's Avatar
sequence
I saw the MM one and it looks like a standard heat dissapater, as opposed to a reflector/shield.
Old Sep 7, 2009 | 07:35 AM
  #161
sequence's Avatar
sequence
Originally Posted by orangecrush
A few months ago I bought an M7 heatshield (except from Way Motorsports instead of M7)
This one...
I assure you there is a reason why it's more expensive. This is an excellent piece. It does what it's suppose to do, fits perfectly and a year from now, what's an extra 100 bucks in the long run. The one you're looking at from Minimania doesn't look like it has the insulation and then on top of it, it has holes??? How is that suppose to deflect any heat? I'd spend the money and buy the better (IMO) product. Mark
Mark was the M7 difficult to install? (Im all thumbs here).
Also, from what Ive been reading on other MINI regional and international forums, looks like the JCWs, both factory and S1, may be more prone to this occurence. Mark when U had yr MCSa JCW, did U have this problem? Cheers
Old Sep 7, 2009 | 10:52 AM
  #162
orangecrush
The M7 is a matter of 5 minutes to install, if that. It's nothing more than 2-3 bolts. Very simple, very straightforward.
And yes, I had the melting hood scoop on my '08 MCSa by 2400 miles. (roughly 3 weeks of driving....that's ridiculous)
When I installed the JCW carbon fiber scoop, it still sank a tiny bit and in the right light, you could see the warpage, though minimal, it was still there.
I've got 9K miles on the JCW and see no signs of warpage so between opening the hood scoop, installing a heat shield and some reflective insulation under the hood, apparently that all helped.
Mark
Old Sep 7, 2009 | 08:02 PM
  #163
Benibiker's Avatar
Benibiker
Mark
Same here, going on 8,500 miles and no warpage. I installed the M7 shield about a week after I purchased my car and installed the reflective insulation just for good measure.
Old Sep 8, 2009 | 12:13 PM
  #164
RedDog888
The problem with these heat sheild is that they will help heat soak the turbo which will increase your intake heat and be that much hotter to cool down in the intercooler. I found the removing the grill on the scoop, inserting a deflector to angle a percentage of the air down towards the turbo and adding film heat barrier to the bonett seems to fix the melt down. Not really worried about the increase of air flow through open scoop. Way more ways fo the air to get out and not build up a backpreasure that would be significant to overcome the air coming in through the radiatior. I believe the reason OEM has the limited openings in the grill on the scoop is to cover all seasons issues, winter rain, snow and summer. A compramise is made to suit all, without the owner having to deal with changing opeing size for time of year or weather. When shutting down on hot engine, there is a ton of heat coming out of the open scoop that would normal be trapped like a rat!!!
Will post a pic when I get a chance.
Old Sep 8, 2009 | 12:17 PM
  #165
tgs91
This will work at low speeds however at highway speed there is not that appreciable amount of airflow coming in the hood scoop. At speed you get most airflow at front grill and at cowl
Old Sep 8, 2009 | 12:27 PM
  #166
RedDog888
Yea but at high speed there is enough air movement to keep the turbo from cooking the scoop. But looking at the amout of opeings through the radiatior and the flapper pannels next to the fan, the soop percentage wise I would say is about 20% but also it is all cool air, not air that's been throught the radiator grill...... When I get off the freeway have hot run, the bonett/scoop are very cool. So is it when it seats hot that the melting is occuring or is it while running at speed they melt?
Old Sep 8, 2009 | 12:55 PM
  #167
tgs91
Not based on anything empirical but I'd say a little bit of both and that much heat takes time to dissipate and cooking that plastic every minute of it.
Only thing I saw 'proof' other than seeing the actual sagged scoop was someone on here taking a laser thermometer to the hood scoop after installing the M7 and it was 100 deg cooler.
Heat must be going somewhere and I think there is enough airflow whether it be from holes in scoop itself, radiator, from under car to not roast the turbo.
If the heat shield is doing it's job, and it appears it is, the main heat is being deflected to the metal part of the bonnet as it cools down at a stand still
Another reason to make sure we change oil every 5K, our babies take a cookin'!
Old Sep 8, 2009 | 08:35 PM
  #168
Dwight Walhood
No Heat Venting
The heat build up problem occurs when stopped. There's simply no place for it to properly vent (hot air rises, etc). The stock scoop is a decoration (the first ones were closed, the "open" replacement a joke). IMHO, the cowl molding is the problem, it's completely closed! Any thoughts on this?
Old Sep 9, 2009 | 09:30 PM
  #169
corduroy's Avatar
corduroy
+1 on the cowl moulding. I've thought about this too
Old Sep 10, 2009 | 04:31 PM
  #170
RedDog888
Remove it, 4 screws. Yes after shutdown I feel tons of heat coming out of the scoop, but mine is open with the grill removed, the stock grill is a joke as far as letting out any heat or cool air in. Haven't had the time yet to post a pic of my mode, will soon.
Old Oct 3, 2009 | 04:44 PM
  #171
Tron Chief's Avatar
Tron Chief
19000 miles scoop melted at the top middle with a sag. Took it to the dealer for service and after some negotiation with the SA was able to get a free Carbon Fiber scoop installed. Pulled out of the parking lot to install the M7 heat shield and after the five minutes required for the install went to turn on my music and it was a CD. Strange since I had listened to it on my 4 hour drive to see my daughter and get my car worked on looked down to where my Ipod had been residing for the past year and not only was the Ipod with custom engraving Do you know what TA is? Return to John R. Dunlap gone but so was my Ipod cable. Now I'm dealing with the dealer to figure out how they are going to fix this. Guess it could have been worse as I had my MacBook in the boot along with a full set of Craftsman tools in a case.
Old Oct 3, 2009 | 07:44 PM
  #172
orangecrush
Ya didn't turn around and go back?? It would have been a little more effective than calling them a day later.
Hope you get your stuff back.
Mark
Old Oct 3, 2009 | 07:54 PM
  #173
Dwight Walhood
OMG, and I thought my dealer was bad!? Ever since my first "service" I've put on the white inspection gloves before leaving the lot . Hope you get your stuff back.
Old Oct 3, 2009 | 07:57 PM
  #174
Jeremy1026's Avatar
Jeremy1026
Moderator
Mine is beginning to warp. I'll probably bring it up to the dealer next time I'm in.
Old Oct 3, 2009 | 08:24 PM
  #175
Tron Chief's Avatar
Tron Chief
Mark
Oh I did go back and the answer was that this was not the first time. Sorry and customer service would be contacting me on Monday However legally they can't go searching everyone with out reasonable cause. However I will be contacting MiniUSA and letting all my friends know that this is going on
