R56 MINI Cooper rated in the top 5 most economical cars to own by Consumer Reports
I was sure someone would've posted this already, but Consumer Reports has named the MINI Cooper among the top 5 most economical cars to own.
http://www.abcnews.go.com/Business/P...6965114&page=1
The article doesn't say much about the Cooper, specifically, but it's good to hear nonetheless.
Other cars in the top 5 were the Toyota Prius Touring (overall leader), Volkswagen Rabbit, Honda Civic EX, and Honda Fit.
Typical of the media getting the details wrong. In any case, yes, Coopers rock and the other models aren't far behind!!!
So what about this.....my manual Cooper (EPA 37 highway) gets over 40 mpg around town!!! In fact, right now the OBC sits at 45.3 in city driving (my city anyway)!!! Now, I understand EPA tests are all done under certain controlled conditions...but I wonder if the other frontrunners in this evaluation have similar results in real-life. Do they do better or worse than the "official" statistics report??
There may be more to this story than the quick and easy report that is featured.
gokartride,
Do you reset the OBC each time you fill up with gas? If not, you're not getting a current reading (I only mention this because I've seen other posters who never reset it, failing to understand that it then becomes a very long-term average).
Also, try calculating manually...I've always gotten higher readings from the OBC.
I play w/ the OBC all the time. In fact, I reset it every few days, but only so I can see what is happening to better optimize my driving style. When too many days go by the OBC does not update fast enough for me to adjust my driver inputs.
Either way......from my perspective it is reasonable to say the manual Cooper easily capable of 37 mpg city (I get 40 mpg, 42-43 OBC) and 41 mpg highway (I get 44 mpg, 46 OBC). That's still a good bit higher than the EPA #s.
The numbers aren't quite that good running the AC, though, or when I have passengers. Darn passengers.
Okay, back from driving to dinner from the train station and home back and forth through Arlington. OBC is now at 45.8 mpg. This car is crazy!!!!!
Side note.....I think I have an explanation for this. Very mild temps here the past few days = less warm up time and therefore less loss of mpgs (which are much lower during engine warm up) that have a big impact on OBC averages. Just a theory.
But yeah, I'm hoping that this particular CR tidbit is true! Oliver certainly gets good fuel mileage well, except for when I first started driving him. Learning standard = horrid fuel consumption (11.1L/100km, I think? Worst average every seen on a MC..?). Start, stop. Start, stop. Start--no, wait, stall. Start, stop. Start, stop. Revmatch fail. Revmatch fail. Start, stop. You get the idea.
Yes, I have checked manually, and you are right, it generally comes out 1-2 mpg is lower on a full tank than what the OBC is reading. I often report getting over 40 mpg, but in this case the OBC generally reads 42.5....I try to build in that 2 mpg fudge factor.
If Toyota and Ford's numbers are to be believed, most hybrid batteries (excepting the early Prii) have outperformed their stated lifetime (see: NYC Ford Escape Hybrids) and only a small percentage have had to be replaced. That's not bad for cars that are getting to be ~5 years old now. We'll check back in another three.
If I managed to convert that to US mpg right (21.2), I've done worse, but only on the track (15.0mpg, 15.7l/). I'm not the most economical driver, but I've never averaged below 25mpg (9.4l/) on the street.
You did the conversion correctly. As a hint, if you go to Google (the actual Google site, not the search bar in your browser), you can do conversions in the search bar.
Put "11.1 liters per 100 km in miles per gallon" in the search bar (without the quotes), and the first search result will be:
"11.1 liters per 100 km = 21.190503 miles per gallon"
The Google calculator has just about any unit of measure you can think of and will convert back and forth between them. An another example, if you search for "60 miles per hour in furlongs per fortnight", it will give you the correct answer (161,280).
I never had a sense of what l/100km actually meant, as I grew up with mpg (imperial or US), but I think I can get a handle on it as I worked out that 15.3mpg(US) = 15.3l/100km. From there I should be able to work out a reasonable conversion in my head.
(I think the number is 16.8 if you're using imperial gallons.)
That's good to know - I generally try to avoid abbreviations like "mpg" because the Google calculator doesn't know all of them, and it's kind of unpredictable as to which ones it will and won't accept.
For example, trying to do "20 mph to fps" doesn't work, because while it knows "mph" is "miles per hour", it doesn't recognize "fps" as "feet per second". But "20 miles per hour to feet per second" works fine.
