R56 Dent but paint is broken, what to do?
Old Dec 6, 2008 | 08:48 AM
kevinminict's Avatar
kevinminict
A few weeks ago I was driving along and I hard a loud bang on my passenger side door, so hard you could actually feel it..... like something hit it.....I pulled over and there was this dent. ahhhhh
I don't know if some kid threw a rock, he would of had to throw pretty hard or I vaugly remember at the same time....seeing a stick in the road and couldnt avoind it I think I hit it with my drivers side tire and it could of somehow flew underneath the car and wack come out the other side and come up and hit the door? I was going about 45mph.
Whatever the case is this a simple fix for a dent wizard or body shop, because of the paint cracking, ugggg. The dent is right on the bottom middle of door...where it meets the rocker panel.
Any idea on what a body shop would charge VS a dent wizard, (50-125.00)
Sorry car was a little dirty and wayyy cold out when i just took this pic.
Old Dec 6, 2008 | 10:45 AM
corcoranwtnet's Avatar
corcoranwtnet
Body shops will give you a free estimate...
Old Dec 6, 2008 | 12:33 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy)
If the paint has broken through, likely pro body work needed. Though dent wizard could take out the dent first, and depending on how it looks afterwards you could have an airbrush guy touch it up, I'd not recommend that.
But from your pic I'm puzzled...thought your Mini was Mellow Yellow? Is the picture that far off in color? Blue/White?
Old Dec 6, 2008 | 01:46 PM
catseye's Avatar
catseye
I had something like that on my hood from a rock. Had my local dent guys flatten it, then I hit it with a little touchup paint. Not perfect, but cheap, and I figure I'll be redoing the whole hood at some point, so what the heck... I'd do that first and see how much it bothers you.
Old Dec 6, 2008 | 05:28 PM
Benibiker's Avatar
Benibiker
I was going to say the same thing, what color is your car? White and Blue?
Old Dec 6, 2008 | 11:28 PM
mattsenpai's Avatar
mattsenpai
is that your mini??
Old Dec 10, 2008 | 08:36 AM
kevinminict
LoL Its Mellow Yellow, I took the pic with my iPhone and the white balance on it was off. Thats All....>SO do you think its an expensive fix?
Old Dec 10, 2008 | 09:37 AM
CR&PW&JB's Avatar
CR&PW&JB
That "ding" does not qualify for Paintless Dent Repair (PDR). The paint is damaged and it's probably too close to the edge of the door panel.
Looks like conventional repair is the only option (hammering, sanding, painting, etc).
Appears to be a $150-250 job to me, depending on the labor rate in your area.
File a claim with your insurance if the estimate is much more than your Comp deductible.
Old Dec 10, 2008 | 11:13 AM
bhelton's Avatar
bhelton
I just dropped mine off at a collision center to have paint work done. Somebody backed out of parking spot right into the passenger side door, right on the edge with the hinge.
Anyway, the paints broken and the body shop estimated 5 hours of body/paint labor at $42/hour, but I think that was an insurance rate. The whole bill came to $360, but it needs an alignment too and that is $60 of it...so $300?
Lots of variables there though so I don't know if that really helps you...
Old Dec 11, 2008 | 01:39 AM
slinger688's Avatar
slinger688
I think it is worthwhile to try getting a couple more repair quotes and check bbb.org just to check out the repair shops. Based on the photo, $250-$300 seems within the ballpark.
Old Dec 11, 2008 | 05:59 AM
freez3's Avatar
freez3
From: United States of America, Ohio, Stark County, Uniontown
So close to the edge makes it almost impossible for a dent guy. Plus broken paint means more extensive repair.
The dent guys are good though... I had one take out a softball size dent in my fender (no broken paint) and you can't tell where the dent was.
Old Dec 11, 2008 | 06:49 AM
mtbscott's Avatar
mtbscott
My guess is that PDR might be able to take that out, but it may end up looking almost worse with a smooth surface with a big paint chip in it. If you go the body shop route, I'd be guessing closer to $500, seems to be almost the minimum charge at shops here locally.
bahman
Feb 14, 2016 10:29 AM
Fordgt4
Oct 10, 2015 10:42 AM
M7Speed
Oct 1, 2015 07:05 AM
B1mm3r101
Oct 1, 2015 06:22 AM
daviday
Sep 25, 2015 01:31 AM
