R56 One thing that drives you nuts about your MINI!
Old Feb 23, 2010 | 07:56 AM
  #626
iamsteve710's Avatar
iamsteve710
Originally Posted by Mabbottusmc
It drives me nutz that an armrest is an option!
I purchased a preowned that came with the "POS" thing MINI calls an "armrest". The plastic cover kept sliding open, and was quite annoying. The dealer replaced it (under warranty) and told me they do this very frequently. The new one is staying shut for now, but I'm seriously considering removing it. If I remove it, can anyone suggest a place to store about 4 AA batteries that I always have on board for my MP3 player
Old Feb 23, 2010 | 10:03 AM
  #627
Goldilocks's Avatar
Goldilocks
You can stash the batteries in your secret compartment or glovebox
Old Feb 23, 2010 | 10:13 AM
  #628
jcauseyfd's Avatar
jcauseyfd
Originally Posted by Herleman
After a week of moving stuff around, I have to add to those who have complained about the lack of an easy method to open the hatch. A system that REQUIRES the use of the key fob seems goofy. I'd buy an aftermarket hatch opener if somebody were to market one.
But I still love the little car -- just looking to make it better.
My 2008 doesn't require use of the key fob. Just use the handle.
Old Feb 23, 2010 | 02:21 PM
  #629
strobeyprobey's Avatar
strobeyprobey
To make the hatch easier to access, turn off Auto Lock and set All doors to unlock (as opposed to just driver door) in the car configuration.
That locked boot DROVE ME CRAZY until I did this. Now it is *always* unlocked when I need it.
Why you need both those features off is this: If auto lock is turned on, after you get out of your car (requiring that annoying double pull) your boot is locked. DUMB since the car does not have the auto unlock when you stop.
Second if driver door only is set, you walk up to your car, hit unlock...boot is locked. Yes, you can press it again to open it. But then, lets say you don't need the boot until after you drive the car...Go to the boot...Boot is locked...need to hit the fob again.
Old Feb 23, 2010 | 08:18 PM
  #630
daffodildeb's Avatar
daffodildeb
Originally Posted by KevinC
I'm glad - because the factory armrest is an utter POS. I was forewarned here in these forums, and checked it out before placing my order, and sure enough, the thing was an embarrassment. It has a cheesy slide cover that feels (and no doubt is) cheap and from owner reports, slides open all the time when you don't want it to. And the thing is rickety and unstable-feeling. They need to start over on this one.
You betcha. I ordered my car sight-unseen, 2 months before the R56 was available in the U.S., and we "assumed" that an armrest would be an actual benefit. It's not, at least not the POS this one is. It's been replaced 3 times under warranty, and each time I've asked if I could get the clam-shell type that is also available, as the European model is. And I could--IF I paid $200. I paid $200 as an option. Why should I pay ANOTHER $200?
It's loose again, and my car's now out of warranty...
Old Feb 23, 2010 | 08:21 PM
  #631
daffodildeb
Originally Posted by Benibiker
Just changed a blown light bulb on the rear license plate. Who the heck designed that?! Taking the lens off is easy enough, then there's no room to stick your fingers in there to take out the blown bulb. The bulb looks like fuse and is held in place much like a fuse. I used a screw driver to pry it out and it just flew out there, I have no idea where it went. Got ready to install the new bulb ($3.20 from BMW) and again, you can't hold it with anything. I dropped it three times before I finally got it there! One simple bulb took me about 20 minutes to change! Jeeezzzzzzzzzzzzzzzz! I'm an aircraft avionics technician so I know about working in tight places but this takes the cake. Can't wait for the other bulb to burn out...
Haven't had the problem (yet), but I'm curious. Couldn't you use a hemostat or sponge holder (a really BIG hemostat-type instrument)?
Old Feb 25, 2010 | 12:17 PM
  #632
oldtruckpainter's Avatar
oldtruckpainter
She keeps calling me to let her out of the garage so she can play.
Old Feb 25, 2010 | 03:19 PM
  #633
daffodildeb
So why don't you?
This month I drove mine from Houston to Tampa and return; just got back Tuesday. No problems, just cruised hour after hour listening to audio books. Not much scenery along I-10, although there's a little detour I aways take around Baton Rouge, just to clear the cobwebs...
Old Feb 26, 2010 | 09:04 PM
  #634
Mato's Avatar
Mato
Mine barfs or its stomach rumbles after I fill her up
also doesn't like me taking the food of accelerator in second, it does give a shock around 2k rpm
Old Feb 26, 2010 | 09:13 PM
  #635
daffodildeb
Not following you--please 'splain.
Old Mar 5, 2010 | 07:45 PM
  #636
jpatrician's Avatar
jpatrician
Windshield wipers crapped out and refuse to come on. . .even after replacing the motor, fuse, and relays.
Old Mar 6, 2010 | 11:43 AM
  #637
pepperwhite09's Avatar
pepperwhite09
i have no complaints, i am a large man 6'4 300 lbs, most would say "the truck driving type" and i was, untill someone said hey go sit in that mini, so i did , and i loved it.
some of yall hate the hour and a half drive to your dealer, i love the hour drive, map quest says it should take 1 hour 7 minutes from my house to the dealer, i make it in 45 min. i love driving my mini. the longer the drive the better. i took mine from here in new orleans, to Allentown PA in 18 hours last month. this little car is great.
Old Mar 6, 2010 | 02:30 PM
  #638
daffodildeb
Hey, you're not doing it right--"motoring" means you're supposed to make it in TWO HOURS and 45 minutes! Go to Google maps and see the best way to do it; it won't be straight...
That's a tip for anyone, by the way. I lay out drives for our clubs all the time, and my first trip is to the computer. You'd be surprised what an aerial view will show you. I figure it that way, then drive the roads to check for traffic and potholes, and I have an easy drive in nothing flat. Er, make that hillly and curvy. Of course, you ARE allowed more time to savor the roads. Email me for more tips...
Old Mar 6, 2010 | 11:07 PM
  #639
pepperwhite09
see thats a big problem here in new orleans, every thing is FLAT and in straight lines. no winding mountain roads, just interstates and highways, and main roads, i need to get away for a while in the Rockies or something
Old Mar 7, 2010 | 04:51 AM
  #640
jcauseyfd's Avatar
jcauseyfd
Google Maps consistently overestimates the time. I once laid out a drive for our club that Google Maps said was a four hour loop. During my scouting, I never could get it to last longer than a little over two hours.
Old Mar 7, 2010 | 03:15 PM
  #641
daffodildeb
I don't pay any attention to their times--they're for your father in his Buick (or mine in his). Nor do I worry about THEIR routes. When we went to MITM last August, I "asked" Google to give me their idea of a route. Turns out, the "best" way was through Wichita. No, it's not! Also, they can't conceive of someone wanting to drive Colorado 82, between Balltown and Carbondale (goes by Aspen). I just wanted some mileage calculations, but no matter how hard I tried, I just couldn't get the system to allow it. Yes, I know it's closed during winter, but it's quite a nice drive during August!
And there are mistakes. There's a highway near here that drives by a dam. Notice I said, "by." According to Google, you're supposed to drive ON the dam, which is a gravel road for maintenance workers that has never been open to the public. And there's a Colorado highway I wanted to take to Denver, until I discovered (on screen) that it abruptly turned into gravel for too many miles to make it worth the risk of damage (no, not the Pike's Peak road). Fortunately, it's covered by "little man" that shows the actual road surface and terrain.
Stil, it's invaluable. I've planned many thousands of miles, both local and long distance, that has played out to some spectacular twisties and scenery.
Pepperwhite09, yes, you do need to head out to the Rockies some time. Until you do, there are options. Plenty of great roads anywhere in Arkansas, Tennessee, and North Carolina, and some nice ones getting there. Also, there are twisties southeast of Baton Rouge that will take some of the pain out of MINI ownership in flat areas. Join a club and you'll find 'em! Or let the satellites alert you to some. And don't forget, you're a lot closer than I am to the Dragon, or the road in Virginia that's even better...
Old Mar 8, 2010 | 02:37 PM
  #642
onetigerlsu's Avatar
onetigerlsu
daffodildeb
where are the twsties located southeast of baton rouge ?
Old Mar 8, 2010 | 02:41 PM
  #643
Goldilocks's Avatar
Goldilocks
drives me nuts cause I don't want Cricket to get splashed with rain after I spend hours detailing her out
Old Mar 8, 2010 | 03:01 PM
  #644
SMOG's Avatar
SMOG
Alliance Member
The road noise in the cabin is pretty loud for the amount of money you pay for the car. A Honda has slightly higher noise levels, measured on a meter, and the Toyotas are quieter. They need better, or at least some, insulation.
Stephen
Old Mar 8, 2010 | 03:18 PM
  #645
MinnieMama's Avatar
MinnieMama
Originally Posted by Soggy-1
The road noise in the cabin is pretty loud for the amount of money you pay for the car. A Honda has slightly high noise levels, measured on a meter, and the Toyotas are quieter. They need better, or at least some, insulation.
Stephen
Just turn up the radio and listen to some rockin' tunes. Or buy a Honda or Toyota - you'll be bored to death and then you won't hear a thing, ever again.
Old Mar 8, 2010 | 03:32 PM
  #646
daffodildeb
Originally Posted by onetigerlsu
daffodildeb
Okay, off I-12, south on 3002, south (left) on 1034, continue southeast on 16, southeast (left) on 16/42, east-northeast (left) on 42, north (left) on 441, back to I-12. It's about 32 miles, vs. 18 miles on cruise control. Someone told me a couple of years ago about some of these roads, but I didn't know which ones they were until I looked on the satellite view. Please note that some of these roads have rough areas, but nothing I didn't feel comfortable driving at "MINI speeds." Also, if I knew the area, and had the time, I know I could find others, but this was something I threw together at the last minute.
Old Mar 8, 2010 | 04:13 PM
  #647
daffodildeb
Stephen
That's to drown out your passenger's screams as you run through the twisties. Or your own.
Old Mar 8, 2010 | 04:18 PM
  #648
SMOG's Avatar
SMOG
Alliance Member
The Mini's handle waaaay better than the Honda or Toyotas. I do know that tires make a big difference but insulation is the next step! I have had enough "Loud" with machine guns and artillery and it is surprising that I can still hear the road noise. 98db @ 65mpg on some road surfaces is pretty loud.
S.
Old Mar 8, 2010 | 11:36 PM
  #649
mikemc's Avatar
mikemc
wish the dam sport button would have a auto lock on position or stay on even after i turn off my mini and restart later... its kinda annoying to me to have to turn it on every time i get in the car... cause you know i just gotta!
Old Mar 8, 2010 | 11:42 PM
  #650
mikemc's Avatar
mikemc
i though it was funny that toyota's slogan was 'toyota... moving forward'... and there recall was cause there pedals would stick...talk about bored to death!
(disclaimer:for those that are too serious, not intended to be in pour taste, just funny)
