R56 how to remove stock exhaust tips on s model
Old Aug 31, 2008 | 01:46 PM
sk8erguyzach's Avatar
sk8erguyzach
need help removing my exhaust tips i removed the allen wrench type screw in the center and it just wont budge i need help!
Old Aug 31, 2008 | 03:07 PM
Frank Matyja's Avatar
Frank Matyja
Blew By U
spray the allen screws with WD40 and let them sit for 30 minutes then you will be able to remove them...good luck
Old Aug 31, 2008 | 04:11 PM
sk8erguyzach
i got the screws out that wasnt the problem i just cant pull off the tips i dont see any other thing holding them on
Old Aug 31, 2008 | 07:40 PM
4xAAA's Avatar
4xAAA
Try this idea. Drive the MINI as normal for 30 minutes or so. As soon as you get back home grab a water hose and a rubber hammer. Spray the exhaust pipe with water just at the base of the extension tip. Be careful not to spray the extension tip. After a couple of seconds of cooling water spray tap on the back of the tip with the rubber hammer. It still may require some convincing, but it should come off.
I took mine off real easy. Had a Grand Prix run into the back of the MINI...waa laa, I use one as a pencil holder on my office desk.
Old Aug 31, 2008 | 08:02 PM
sk8erguyzach
i will definatly try thiss thanks
Old Sep 1, 2008 | 06:24 AM
tag's Avatar
tag
Just wondering, why take them off?
Old Sep 1, 2008 | 06:38 AM
DrewN's Avatar
DrewN
Here's one reason:
https://www.outmotoring.com/mini-coo...aust_tips.html
Old Sep 1, 2008 | 10:14 AM
sk8erguyzach
so i can put these on
Old Sep 1, 2008 | 12:31 PM
sk8erguyzach
4xAAA it worked it worked suprizingly well thanks
Old Sep 1, 2008 | 08:27 PM
r56mini's Avatar
r56mini
You just have to muscle it off.
Old Sep 2, 2008 | 08:15 AM
SuperGreg's Avatar
SuperGreg
Could you please take before & after pics?
Old Sep 2, 2008 | 08:25 AM
sk8erguyzach
i would but but after i got them on i realized i need bigger bolts so im running to home depo and as im heading home i hear a ting ting i pull over a little farther down the road and find that i only have one exhaust tip i go back and find it but by that time it had been all bent and deformed by a big rig
so i just put the stock one back on for now
Old Sep 2, 2008 | 09:31 AM
scruffylooking's Avatar
scruffylooking
Dude, clean up your room. Haha.
Old Sep 2, 2008 | 10:28 PM
sk8erguyzach
its just the plastic it was wrapped in
ASRman
Aug 13, 2015 09:33 AM
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
