R56 ALTA's Latest Test Mule is HERE! Pics inside!
Old Aug 8, 2008 | 10:23 AM
  #51
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Originally Posted by Blainestang
Nice numbers, for sure.
Are these SAE?
I realize there are many variables, but any idea how they compare to DynoJet numbers? For instance, do you have any same-car comparisons from cars tested on your dyno and on a dynojet?
Just trying to get an idea of how the hub-mounted dyno's compare to the Dynojets and Mustang Dynos I'm used to
Sorry for the delay! I am going to defer this question to ALTA2 (Jeff) to answer in better detail than I could! Thanks again for asking!
Old Aug 8, 2008 | 10:33 AM
  #52
ALTA2's Avatar
ALTA2
Manufacturer
Shortly, but lets just say that the numbers match what Mini claims. Yes that may be unbelivable! Mini under rated the car once again!
Old Aug 8, 2008 | 11:38 AM
  #53
Blainestang's Avatar
Blainestang
So, if I were to dyno a car on the hub dyno and then on a dynojet it *should* yeild similar numbers... and I could "add the typical 15% parasitic loss" to get to crank numbers?
I take it that that's the case given that you're saying it's underrated ... just clarifying.
Old Aug 10, 2008 | 07:16 PM
  #54
ADAMSALTAMINI
Not exactly. Our dyno measures the REAL WHEEL HP. So with the numbers we achieved, they include the loss through the powertrain and thus we have been able to deduce that the factory has underrated the TRUE HP of the 09 JCW. Similar to the underrating on the R56 Cooper S.
Hope that helps! Thanks again!
Old Aug 10, 2008 | 07:25 PM
  #55
minim8o's Avatar
minim8o
Originally Posted by ADAMSALTAMINI
WAIT a minute! Nothing could be farther from the truth! If we didn't purchase this car (as well as other MINI models) we wouldn't have the proper data to release appropriate parts for the car. I bet YOU didn't know the exhaust is different than the std. R56 Cooper S, etc. etc.
How's that stock JCW TBE compare to yours BTW?
BTW, I imagine if you didn't buy a JCW and started selling a tune for it, folks would bash you for that... Really, is it possible to win in all situations? I think it's a pretty incredible commitment you're taking the $ plunge "eating your own cooking" instead of relying on someone's good graces to use their car as your test mule.
Old Aug 10, 2008 | 07:28 PM
  #56
ADAMSALTAMINI
The JCW TBE is far smaller than ours. It does have some marked changes that Jeff (ALTA2) has been polishing details on a big thread about all of them. He has been busy so sorry for the delay!
On the BTW: THANK YOU VERY MUCH! Well put!
Old Aug 10, 2008 | 08:11 PM
  #57
Pinky Demon's Avatar
Pinky Demon
Hey Adam,
I'm going to be buying a Mini in the next year or so, and I must say, you guys at Alta put out some impressive products. At least I know that when I get it, my bank account will never be too full. Thanks a lot ya jerks!
Old Aug 11, 2008 | 06:58 AM
  #58
ADAMSALTAMINI
Originally Posted by Pinky Demon
Hey Adam,
Nice quote! Love it! Thanks for the compliments and yes anytime I can help with anything, PLEASE let me know! Chat soon!
Old Aug 11, 2008 | 07:06 AM
  #59
Blainestang
Right... the car is making about as much "wheel horsepower" as MINI claims it will at the crank. Therefore, it's underrated.
I'm just trying to figure out how your particular dyno compares to a typical dynojet.
For instance, if the JCW makes 202whp on your dyno... Would it make about 202whp on a Dynojet, or would it make more or less?
Given the many variables, there may not be a legitimate answer... just thought I'd ask.
Old Aug 11, 2008 | 08:03 AM
  #60
ALTA2's Avatar
ALTA2
Manufacturer
Our Dynapack is in the middle. So a local Mustang dyno reads a little lower than ours, about 5% Wheel HP less. But a dynojet normally reads about 15% higher than ours. On the other hand a Dyno Dynamics dyno reads typically 10-12% less than ours. There is no way to compare unless the same car hits all the dynos it can in a day or 2.
But we have lots of stock R56 runs, modded R56 runs, Stock R53 runs, and modded R53 runs, in our library. The R53's all run less HP than they are rated to 15%-ish, which is normal drivetrain losses. The R56's we have dynoed was about 10WHP less than engine HP was rated to. So either they are using some magic lubricant or underrating the engines.
Old Aug 11, 2008 | 08:21 AM
  #61
Blainestang
Yeah, it can be very tough to compare, given all the variables, but your answer pretty much answers my question.
Thanks, Jeff.
BTW, has anyone put a stock "base" 6-speed Cooper on a dyno?
Old Aug 11, 2008 | 09:39 PM
  #62
ADAMSALTAMINI
Thanks, Jeff.
WE have done each year and A/T and 6-spd. Jeff can provide more dyno plots or links to them if you want.
Thanks again!
Kimolaoha
Jul 5, 2023 01:04 PM
W0TM8
Dec 19, 2019 07:50 AM
AWOL
Mar 28, 2016 10:51 AM
stierzy34
Sep 15, 2015 04:40 PM
brother i
Tires, Wheels, & Brakes
Aug 23, 2015 01:15 PM
