R56 Removing Seats '08
Old May 4, 2008 | 01:04 PM
mysticturner's Avatar
mysticturner
Removing Seats '08
My 2008 MCS is on the ship now (or at least I believe it is - no way to confirm yet). I'm planning on buying some 303 fabric guard and treating the seats ASAP after delivery. Question: Any difference on pulling the seats vs a 2006? I've pulled my wife's front seats and it's much easier to clean under and treat the seats that way. Second question: How hard is it/what's involved with pulling the back seat?
To me it's just a lot easier to do that and not have to worry about overspray.
Old May 4, 2008 | 03:29 PM
Robin Casady's Avatar
Robin Casady
I haven't done it yet (plan to for installing Dynamat), but I believe you have to disconnect the battery. Otherwise, disconnecting the airbags can cause an error code in the OBC.
Old May 4, 2008 | 03:55 PM
tony1athome's Avatar
tony1athome
Pulling the rear seat is pretty much trivial. There's one bolt in the center in the back that needs to be undone. Lift up the center and slowly pull and rotate out from the side. To pull up the seat, pull out the LATCH connectors, pull up the front and then (and this is non-intuitive) push down in the center of the bottom.
Note that mine is an '08 Cabrio, so the form factor is a bit different, but the concept is the same.
Old May 4, 2008 | 04:15 PM
DrkSilver163's Avatar
DrkSilver163
Its pretty simple, 4 bolts holding the rails down and thats it. Id disconnect the battery before unplugging the seat from the harness underneath though.
Old May 4, 2008 | 04:51 PM
Satsloader's Avatar
Satsloader
My Mini is also on the water, on it's way .
I planned to pull the rear seat out as well, but my plan is to leave it out for extra room ( I don't intend on having more than one passenger at any time ). I'm a field service rep, and carry parts for office equipment. The amount of parts I need to carry these days has diminished to the point that the Mini will make a perfect service vehicle.
I'm curious about seats having harnesses ( which shows how long it's been since I had a new vehicle, 305k on my third Toyota 4wd pickup ). Does the rear seat have any electronics hooked to it?
Many thanx!
Bill in Pacific Grove, Ca.
Old May 4, 2008 | 05:13 PM
ksmaas1's Avatar
ksmaas1
no need to disconnect the battery. It only thows the air bag code if the yellow connector is unpluged while the key is in the ignition. just don't put the key in while you have it unplugged or while you are plugging it in and you'll be fine.
Old May 4, 2008 | 08:56 PM
tony1athome
Not the rear. The fronts have them for the airbags and the seat heaters.
A former PG resident...
Old May 5, 2008 | 04:07 AM
mysticturner
Thank Goodness. I didn't even think of that when I pulled the seats out of the 2006. That would've been a shocker. Working under the seats popping off plugs and BOOM!
Old May 5, 2008 | 04:30 AM
Oxybluecoop's Avatar
Oxybluecoop
Here's the procedure for removing the back seats(and the rest of the rear interior).
http://coopermods.com/archives/4
Old May 5, 2008 | 05:51 AM
Ambrosia's Avatar
Ambrosia
no, the airbags won't go off when you disconnect the seats...but if you unplug and the key is in the ignition or you turn on the car while they are unplugged it throws an error code which can only be reset by the stealer.
Old May 5, 2008 | 04:08 PM
Satsloader's Avatar
Satsloader
Tony and Oxyblue, thanx for the back seat info!
Hey Tony, do ya miss the fog?
Bill in P.G.
Old May 6, 2008 | 01:42 AM
tony1athome
Not in the least!
Old May 6, 2008 | 09:26 AM
k6rtm's Avatar
k6rtm
T45 torx head to get the bolts holding the front seats out.
flyers47
Jul 27, 2020 02:38 PM
Mini'mon
Aug 26, 2015 01:02 PM
greekzilla
Aug 23, 2015 03:44 PM
DWooderson
Aug 10, 2015 09:12 AM
