R56 After car rests for a while...
Old Apr 23, 2008 | 07:32 AM
Auto_Pilot's Avatar
Auto_Pilot
I hear a whining, mechanical sound from the rear of the vehicle But only after long periods of rest.
Any body know what that is? I don't have NAVI, Multi-Disc Player...so I'm a bit puzzled. I'm sure its completely normal, but I'm just curious is to what my car is doing
Old Apr 23, 2008 | 07:53 AM
4xAAA's Avatar
4xAAA
Might need to qualify this with some parameters.
Is the power off when you hear it. Like, been off for more than 15 minutes?
Do you have convience package?
When I put the fob in the slot I hear the fuel pump pressurize the fuel line. Last a second or two, then shuts off.
Old Apr 23, 2008 | 08:00 AM
Auto_Pilot's Avatar
Auto_Pilot
Okay...yesterday...I get home, park the car in the garage...It sat for say 1.5-2 hours...then my buddy comes over and I show him my car. I open the passenger door, Ihear the familiar window thing, and I a hear a mechanical whiring noise near the rear It's done this before in the past after long periods of rest, but thought it was normal. But being the curious guy I am, I have to know
I have the premium package, and that's it. Hope that helps.
Old Apr 23, 2008 | 09:02 AM
djam43's Avatar
djam43
I believe it is the gas tank purging system.
Old Apr 23, 2008 | 09:10 AM
Auto_Pilot's Avatar
Auto_Pilot
Okay...general area makes sense...so I'll buy that. Is that the vapors from the tank being purged? This is also different from the hissing sound I hear from the front section of the car? Which I assume is purging the exhaust from the turbo.
Old Apr 23, 2008 | 09:25 AM
Robin Casady's Avatar
Robin Casady
I believe it is preparing the fuel system for starting. It does that when you open the door so that firing the engine will be a quicker process.
Old Apr 23, 2008 | 10:04 AM
LONO's Avatar
LONO
It is the fuel pump pressurizing the fuel lines.
Old Apr 23, 2008 | 10:39 AM
PistWalrus's Avatar
PistWalrus
Agreed.... It is your fuel pump charging the system. It gets pressure in your lines all the way up to the injectors so that the car starts quickly and does not have to turn over several times before the fuel get into the cylinder.
Old Apr 23, 2008 | 10:58 AM
Auto_Pilot's Avatar
Auto_Pilot
Thanks...that makes sense.
Old Apr 23, 2008 | 11:40 AM
mellowmcs's Avatar
mellowmcs
hissing sound from should not be the exhaust purging from the turbo since the exhaust is open from the turbine on. it is more likely to be the water pump cycling coolant to cool the turbo after engine shutdown.
Dec 23, 2015 10:36 AM
joedotmac
Aug 28, 2015 01:04 PM
Dashdog
Aug 10, 2015 06:17 AM
bctf1
Aug 6, 2015 12:55 PM
PatrikKN
Aug 5, 2015 09:10 PM
