R56 Weeping washer nozzles on 2008 MCS?
Old Apr 10, 2008 | 03:54 PM
russr's Avatar
russr
I have a week 2, 2008 MCS and here in NJ it was ~72F. Anyway a few minutes after my car sat in the garage, I came back out and noticed there were was a small puddle of windsheild washer fluid around each nozzle. It looked like it was continuing to ooze out. Never noticed this before, but it's never been this warm since I got the car.
I know this was an issue on 07 models, but I thought they had fixed it. Would the solution be the same for an '08 model?
Old Apr 10, 2008 | 08:15 PM
Oakland Raiders Mini's Avatar
The Mini cries when it isn't driven.
Old Apr 10, 2008 | 08:33 PM
ATCQL's Avatar
ATCQL
My understanding from this forum is that has been happening since the first model year.I have experienced this on both my 05 and 07.Could be as simple as lowering the level to which it is filled.Q
Old Apr 10, 2008 | 08:52 PM
Benibiker's Avatar
Benibiker
Actually there are some check valves that have been installed under the hood to stop the weeping. Check with your MA and read the latter part of this thread:
https://www.northamericanmotoring.co...hlight=weeping
Old Apr 10, 2008 | 08:54 PM
Guest's Avatar
Guest
Old Apr 10, 2008 | 10:00 PM
funkdaddy's Avatar
funkdaddy
Yup. Mine weeps too, there is some marring of the hood paint from whatever crazy-strong fluid they use from the factory. I can smell the stuff every time I use it.
Old Apr 11, 2008 | 10:59 AM
russr's Avatar
russr
funkdaddy, it's good to see that they didn't just screw up my car as our cars are the same production week. I looked under the hood and there is a check valve at the T where it splits left and right, but there isn't one right by the nozzles. I really thought MINI was supposed to have fixed this on late '07 and 08 models. Now I have some staining on my stripes from the windishield fluid. I'm gonna take it to Princeton on Monday.
Old Apr 11, 2008 | 11:22 AM
Arnbut's Avatar
Arnbut
The check valves haven't stopped mine from weeping.
Old Apr 11, 2008 | 11:44 AM
Bhatch's Avatar
Bhatch
Dealer installed a check valve in mine, fixed it good.
It screwed up my stripes, and i got them to replace them also,
Old Apr 11, 2008 | 01:14 PM
russr's Avatar
russr
I will bring it up when I take my car in to the dealer on Monday for my rattles and wind noise. Hopefully they've heard of this problem.
Old Apr 11, 2008 | 04:34 PM
ghosthound's Avatar
ghosthound
mine got fixed with the check valves and have been leak free since!
Old Apr 11, 2008 | 07:39 PM
russr's Avatar
russr
would one of you who got it fixed be willing to post a picture of where the check valves are? I want to see if my '08 has anything.
Old Apr 11, 2008 | 08:33 PM
Bufadora's Avatar
Bufadora
Mine weeps too. I thought it was because I rode her too hard. Wife does the same thing.
Old Apr 11, 2008 | 10:31 PM
rippymcs's Avatar
rippymcs
Take it easy on the wife. They don't come with warranties.
Old Apr 11, 2008 | 10:33 PM
rippymcs's Avatar
rippymcs
My washer nozzel weeped once. I figure it was due to the high temp under the bonnet that caused the water in the tubes to expand.
Old Apr 16, 2008 | 08:51 PM
russr's Avatar
russr
Update: took the car to the dealer and they were aware of this issue, but just as surprised that MINI has not implemented this change on '08 MCS models. They installed the check valves inline with the nozzles and replaced my stripes.
If you have an '08 MCS and you find that your nozzles are weeping on warm days, you'll either have to take it in or drain the factory washer fluid and put in some off the shelf stuff. Word is that off the shelf fluid doesn't leak out the way the factory stuff does even w/o any check valves.
Old Apr 17, 2008 | 07:40 AM
Bishamon's Avatar
Bishamon
I informed my dealer about my weeping nozzles, as well as informing them about the service bulletin. The only service bulletin they could find was for the rear nozzle, but they couldn't find anything for the jets on the hood, even after I told them to look under a bulletin for the R53 (as the R56 info was apparently added to a pre-existing R53 bulletin). As they were unable to reproduce the problem, they sent me on my way and asked that if it happens again when I am close to the dealer I should bring it in.
woodstudio
Mar 15, 2020 08:28 AM
gmcnaugh
Oct 27, 2018 03:42 AM
BRracing
Dec 22, 2015 09:25 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
