R56 sport button
Old Mar 30, 2008 | 04:19 PM
genik's Avatar
genik
sport button
I wanted to ask -regarding the sport button- if there are any differences in petrol consumption when that button is turned on rather than being turned off! Is it more economic when turned off?
Old Mar 30, 2008 | 04:33 PM
Creeve's Avatar
Creeve
The sport button only changes the responsiveness of your throttle and steering. So while you can get the same economy you probably wont because you will have the tendency to accelerate harder producing worse economy.
Old Mar 30, 2008 | 04:37 PM
NashvilleMiniStan's Avatar
NashvilleMiniStan
More response = more horsepower = driving faster.
Old Mar 30, 2008 | 04:52 PM
gokartride's Avatar
gokartride
Yes, I'd expect to lose 1-2 mpg on a tank of gas running in sport mode. Even in cruising, non-sport rounds off even subtle throttle inputs where sport mode is more on-off. I like sport mode...but use non when I'm trying to optimize mpg.
Old Mar 30, 2008 | 09:08 PM
surfblue's Avatar
surfblue
Me too
Surfblue says: That's what I'm seeing...about 1 mpg difference in my town driving. I drove my 07 MCS with the button OFF well past the break in period, only trying it to make sure it worked. Then I started using it a bit, then a bit more, then a LOT more, and now it's the first thing that I click ON after the car is started. The only time I leave it OFF is if I'm doing a lengthy freeway drive. With the button off, I found myself not giving the car enough gas, causing it to "stumble" and sometimes even stall. I like the tighter throttle AND the tighter steering response in most situations.
Old Mar 30, 2008 | 09:25 PM
checkercoop's Avatar
checkercoop
I actually don't care for the remap the sport button provides, except for highway...highway I use it because it gives quicker acceleration at high speeds in top gears and tightens the steering so easy to stay in straight lane...otherwise always off...i like the regular throttle response (yes it is lagged but I've gotten used to it rather than sport on) and I could not imagine how much a work out twisties would be with the sports tighter steering.
Old Mar 30, 2008 | 09:27 PM
tonyeck's Avatar
tonyeck
I have always drove with it turned on as I prefer the position of the biting point from the clutch from sitting still.... and now I can't get used to driving without...
Old Mar 30, 2008 | 09:28 PM
<MINI>'s Avatar
<MINI>
"Surfblue says: That's what I'm seeing...about 1 mpg difference in my town driving. I drove my 07 MCS with the button OFF well past the break in period, only trying it to make sure it worked. Then I started using it a bit, then a bit more, then a LOT more, and now it's the first thing that I click ON after the car is started. The only time I leave it OFF is if I'm doing a lengthy freeway drive. With the button off, I found myself not giving the car enough gas, causing it to "stumble" and sometimes even stall. I like the tighter throttle AND the tighter steering response in most situations."
I did exactly the same thing! I need to read up on the mod that turns it on automatically. I consistently get 35 mpg in mostly sport mode driving 75/85 mph.
Old Mar 30, 2008 | 09:53 PM
noraa's Avatar
noraa
doesnt it change the PSI the turbo gives off as well? i think i read it here on NAM its like 1 PSI more?
Old Mar 30, 2008 | 10:37 PM
Oxybluecoop's Avatar
Oxybluecoop
Twisty's everywhere here in south Charlotte.I Keep the sport button on and almost always shift with the paddles.
Old Mar 31, 2008 | 06:36 AM
gokartride's Avatar
gokartride
I do, too , but aside from personal preferences, I've started to think of sport mode less in terms of "sporty" and more in terms of simply two modes of optimization. One optimizes for more direct driver input, the other optimizes for economy. I do wish I could seperate steering from the throttle in these modes, but oh well.
As for launching...I used sport mode almost exclusively the first 8-months I had my R56 as it was such a delight to not have to overcome the low-rpm sluggishness of R50. For aggressive launching and tossing a MINI about...sport mode it the way to go.
I have, however, now adjusted to non-sport mode, too. It is well-suited to gradual, smooth launches. Driving a Cooper manual strictly for economy (non-sport), city-only driving, I'm consistently over 41 mpg on the OBC. Yes, that is city driving. Even if you factor in some possible slippage in the OBC (assuming there is any) that's pretty remarkable. Currently, I'm at 42.6 mpg (city) after one full week of driving on this tank. That makes non-sport (imho) a mode for optimization of economy performance and so a valid choice, depending on how you want the car to perform.
Old Oct 25, 2008 | 10:35 AM
basil49's Avatar
basil49
sport button AUTOMATICALLY ON at start
Guys: go see thread https://www.northamericanmotoring.co...d.php?t=103258 ... several R56 owners there have experimented and figured-out how to add a postage-stamp-sized circuit-board (see gallery -- I've built several now) in the fuse panel that automatically turns SPORT mode ON when you start the car ... highly recommended, and still switchable
Old Oct 25, 2008 | 03:37 PM
iwashmycar's Avatar
iwashmycar
THANK YOU
Old Oct 26, 2008 | 04:29 PM
4xAAA's Avatar
4xAAA
Pretty good idea there, Gokart. Might have to try that myself.
Old Oct 26, 2008 | 04:45 PM
gokartride's Avatar
gokartride
Well, it works for me...others have reported different results. There are so many variables. Either way, the differences between modes is minimal...I just like to play w/ optimizing my mpgs (within reason).
Old Oct 26, 2008 | 09:11 PM
Stymie's Avatar
Stymie
If you've got an automatic tranny, it'll affect gas mileage since it does not upshift nearly as early as standard mode and locks out sixth gear until you're running at a fairly illegal speed in most places. If you're in sixth when you enable sport mode, it will immediately downshift. It also enables the engine assisted braking by automatically downshifting as you coast when you let off the throttle.
Old Oct 27, 2008 | 01:41 PM
callahan00's Avatar
callahan00
I usually dricve in Sport mode unless I am on a long highway trip so the steering is less twitchy.
Old Dec 15, 2008 | 08:55 AM
jmanpatsfan's Avatar
jmanpatsfan
When you move the auto shift lever over to them left (m/s), it says DS just like when you push the sport button. Is there difference? You dont get the steering and throttle response when you just move the lever to the left, right?
Old Dec 15, 2008 | 09:25 AM
nickminir56's Avatar
nickminir56
Yes, and for automatic the shift speed/smoothness is the same as D, not D+Sport.
Old Dec 15, 2008 | 10:00 AM
bluemeanie357's Avatar
bluemeanie357
My only caveat with not using Sport mode is the hesitation from start that is felt in "D" compared to DS... If you drive in Sport mode a lot, and then go back to not using it to conserve fuel around town, you will definitely notice it. I love the transmission, though; it's so versatile. I can get 6th gear in Sport mode by going manual; I can put the gearshift in manual and use the paddles, to avoid going back to auto mode; I can shift manually if I want to. I avoid Sport mode on long trips so I can stay in 6th and not worry about manually shifting when some idjit pulls in front of me because they like the middle lane, despite driving slower than the flow of traffic.
Old Dec 15, 2008 | 10:02 AM
Red Bull's Avatar
Red Bull
I read in the Factory JCW the sport button also put the car into overboost...is this true?
Filmy
15
Jun 6, 2023 06:27 AM
Filmy
Jun 28, 2016 08:58 AM
molala
Oct 2, 2015 01:53 PM
RDSJCW
Sep 16, 2015 03:54 PM
HogWldFLTR
Sep 8, 2015 05:25 AM
