R56 LSD: How do I know I have it?
Suppose i order a new mini, and i ask for the LSD to be implemented in the car! Is there a way when the car arrives to find out if the LSD is really there? How can i check?
I was wondering too...
LSD
Here's a bit more of a description of how to properly test for LSD.
1. Turn DSC off
2. Depress Clutch
3. Push throttle to floor until engine "bounces" off of rev limiter
4. slide foot off of clutch pedal allowing it to spring up
5. Do not lift foot off of throttle
6. As engine reaches rev limiter shift to second gear
7. Let speed build up to around 35 mph
8. Perform Handbrake turn
9. Drive back to where you started
10. Look for 2 black tire marks
enjoy
1. Turn DSC off
2. Depress Clutch
enjoy
1. Turn DSC off
2. Depress Clutch
enjoy
1. Turn DSC off
2. Depress Clutch
enjoy
1. Turn DSC off
2. Depress Clutch
enjoy
1. Turn DSC off
2. Depress Clutch
enjoy
I don't know for sure if this will work with fwd but put the front wheels in the air, and with the car in neutral, rotate one wheel by hand. The other should move in the opposite direction. This works with rear wheel drive. Not as much fun as dropping the clutch at 5 grand tho'
The $500 addition on the window sticker
Let me drive it and I will know because mine doesn't have LSD. Likewise, let someone with a MINI with no LSD drive your car. How?
Turn the steering wheels to the right, turn TC/ASC off, put it in 1st gear and accelerate hard.
The easiest way to know if your R56 is equipped with the factory LSD [besides the window sticker], is to hand the keys to an experienced driver and take one corner. If the inside front tire lites up and the outside tire does not pull the car through the corner, then it's an open diff. If the car has a factory LSD, the steering wheel will get jerky, add lots of torque steer, and the car will pull through the corner when you MASH the throttle instead of violently roasting the inside wheel.
Another way to tell is if you are stuck in deep snow or mud and just one front tire is spinning and the other one isn't doing anything lol. I had this experience in a muddy driveway but both tires were spinning and kicking mud up all over the place...I was still moving forward though
Made a mess of my car, but boy was it a blast! So I think that proves mine does in fact have the LSD like I ordered...not sure if that's a "valid" test though lol
The best way to tell is like previously stated, in a corner when you get on it hard the car should pull through the corner nice and hard, not start smoking the inside tire.
Made a mess of my car, but boy was it a blast! So I think that proves mine does in fact have the LSD like I ordered...not sure if that's a "valid" test though lolThe best way to tell is like previously stated, in a corner when you get on it hard the car should pull through the corner nice and hard, not start smoking the inside tire.
Boy Howdy, you're throwing rocks at a hornets nest with that one. Might want to put your flame suit on! Might as well have said you like using Mobil1 in your mini and you hate the R53
You'll see pink elephants? (I keed I keed...)
, punch it through a corner in 2nd
