R56 Disabling Tire Pressure Sensor???
Old Jan 29, 2008 | 08:03 AM
  #26
graphicjoe's Avatar
graphicjoe
Originally Posted by r56mini
Ford trucks Roll!!
True, but Ford SUV's (Stupid Ugly Vehicles) roll a lot better. But, in fairness, SUV's from other companies roll very well, too.
Roll On!
Joe
Old Jan 29, 2008 | 09:40 AM
  #27
jimsevo8's Avatar
jimsevo8
Originally Posted by ksmaas1
Does anyone know if the 2008 sensors will fit in wheels from the R50/R53? I'm getting close to ordering a 2008, and I have 6 sets of wheels for our 2002 MC and 2002 MCS, and I'd like to use one for snows. Not concerned for the autocross set...I'll ignore the light for the minute the run lasts.
I think the bigger problem you will have is the bolt diameter. on the R56 the wheel bolt diameter is 14mm and the R50/R53 is 12mm. I don't know if the R50/R53 wheel holes are large enough to accomodate the 14mm bolts.
Old Jan 29, 2008 | 09:48 AM
  #28
ColinMc's Avatar
ColinMc
From what i've read on the factory wheels it's not as much of an issue as for aftermarket wheels...for the R53/R56 swap...not sure about R50
Old Jan 29, 2008 | 10:28 AM
  #29
Rastven's Avatar
Rastven
It's still going to be somewhat of an issue though. You'll likely need to get the 14mm to 12mm stud conversion kits that vendors here sell.
Driving with the TPMS disengaged gets mighty annoying as no data will stay in the top screen of the OBC display.
Old Jan 29, 2008 | 10:42 AM
  #30
Eric_Rowland's Avatar
Eric_Rowland
Does anyone know if the 2008 sensors will fit in wheels from the R50/R53? ...
I don't believe so. There was a pic around here somewhere - the new TPMS wheels have a flat spot on either side of the valve stemp so the sensor can fit flush.
Old Jan 29, 2008 | 02:03 PM
  #31
MINIAC's Avatar
MINIAC
They are
Old Jan 29, 2008 | 02:12 PM
  #32
PistWalrus's Avatar
PistWalrus
They are, I have the wheels on the car right now!
Old Jan 29, 2008 | 08:59 PM
  #33
<MINI>'s Avatar
<MINI>
Originally Posted by ghosthound
just buy 4 extra sensors and keep them in the car when you autocross... haha i dont know if that would actually work.
I think they have to be pressurized, as someone else stated. I put mine in the boot and reset the system with no luck. As soon as I drove off the light came back on.
Old Jan 30, 2008 | 04:16 AM
  #34
ksmaas1's Avatar
ksmaas1
Someone needs to design a little box that fits 4 sensors and can then be pressurized with compressed air and stored in the car for the MCS owners, or for the MC, just put all 4 inside the spare tire, and hope you don't need to drive on it. Does the spare have a sensor already?
Old Feb 7, 2008 | 05:02 AM
  #35
VelvetFoot's Avatar
VelvetFoot
From what I read above, on the '08s there is only a light and no beep? A light I can take, but beeping all winter when the snows are on would be very annoying. (We ordered our MINI yesterday!)
Old Feb 7, 2008 | 05:40 AM
  #36
PistWalrus's Avatar
PistWalrus
I get a light but NO beep. I don't think you'll have to worry about that.
Old Feb 7, 2008 | 10:19 AM
  #37
Wolfgang80's Avatar
Wolfgang80
Can you transfer sensors on an 08 without removing the wheel from the tire?
Old Feb 7, 2008 | 10:25 AM
  #38
jblaw's Avatar
jblaw
Pressurized box...
not a bad idea... any site sponsors interested (probably not for liability reasons...)
Old Feb 7, 2008 | 10:35 AM
  #39
VelvetFoot's Avatar
VelvetFoot
Thanks. I'm thinking that maybe the fellow got it mixed up with BMW, since they sell them there too.
Old May 30, 2008 | 11:07 AM
  #40
woodstudio's Avatar
woodstudio
Sensors
I'm someone will make an over-ride electronic device for use with all cars. Something that runs on a battery and outputs the signals the sensor wants to receive.
Old May 30, 2008 | 02:17 PM
  #41
ckranert's Avatar
ckranert
Wolfgang08- The sensors are inside the tires so you would have to remove the tires to get to them. I saved myself the hassle and bought them from Tire Rack via e-Bay ($190 for four sensors and valves). Putting new wheels and tires on and didn't want to pull apart the OEM ones.
Kimolaoha
Jul 5, 2023 01:04 PM
TJANK
Aug 24, 2015 06:11 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
nomar116
Aug 9, 2015 09:42 AM
