R56 Mildew Smell With AC On
It's been a little cooler here the last few weeks so I've been running without the AC on, and sometimes even the heat. However, it was quite a bit warmer yesterday and I ended up turning the AC back on.
Wow! there was a terrible mildew smell coming from the air vents. The smell isn't there when the heat is on or if we just have fresh cool air, but every time we turn the AC on now we get that horrible smell.
Has anyone else experienced this with their R56? We're not using recirculation for either heat or AC so it seems like the air path into the cabin would be the same, so why do we get the smell with AC? Does the air get redirected into an area where water could have collected and mildewed?
Any ideas?
Any ideas?
Any ideas?
Any ideas?
I have the same issue with my R53. The smell is like a bad case of dirty feet everytime I turn on the A/C on. I'm going to replace the cabin air filter and see if that works. I've already checked the evaporator drain and it works properly so the issue isn't stagnat water accumulating at the evaporator. The filter will be changed this weekend and I will report back with the results.
What I don't get though is why I only get the smell with AC and not with heat or fresh air. If it was the cabin filter, wouldn't that affect all air entering the cabin?
Where do I find the evaporator drain?
I got that exact same smell at around 4000 miles. At 1st I got it when the weather turned cooler and would just run the fresh air. Then eventually I got the smell whether it was AC or fresh air. I haven't gotten around to changing the cabin filter but hope this will fix it. Will also check the evaporator drain as suggested here as soon as someone explains how to do this.
Dont know exactly where it is, but if you park your car after a run with the AC on, in you will see a little puddle of condensate water under the car when you park.trace this out and it will lead you to the little drain which comes from the AC evaporator housing. You will have to put the car up on ramps.
Glad you got it unstunk.
USA-RET
Jun 14, 2024 01:56 PM
drrigg
May 27, 2022 03:31 AM
Sep 2, 2015 09:05 AM
