R56 Engine Temp Through the OBDC
Old Jun 1, 2007 | 11:34 AM
Loony2N's Avatar
Loony2N
Is there any product out there that can give real time engine (coolant) temp readings via the OBDC?
Old Jun 1, 2007 | 11:40 AM
Partsman's Avatar
Partsman
Legion_of_Doom
http://www.scangauge.com/
This where I bought mune...
http://cgi.ebay.com/ebaymotors/ScanG...spagenameZWDVW
Old Jun 1, 2007 | 11:43 AM
Robin Casady's Avatar
Robin Casady
Originally Posted by PARTSMAN
Do you have this working on an R56? There was a thread about these earlier, but no one had one working.
Old Jun 1, 2007 | 11:59 AM
Loony2N's Avatar
Loony2N
Does anyone have this working on their R56?
Old Jun 1, 2007 | 12:00 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I believe you are thinking of this...
http://www.dashhawk.com/
The R56 is OBDII just like the R50/53, it will work fine.
Old Jun 1, 2007 | 12:05 PM
Loony2N's Avatar
Loony2N
Do you know if the manifold pressuer reading is available on the R56? Scangauge's website says it isn't availbale on some cars.
Old Jun 1, 2007 | 12:15 PM
Partsman's Avatar
Partsman
Legion_of_Doom
MAP can be read through the SGII on my R53.
I honestly don't know if it can be read from the R56 as it uses a MAF.
Old Jun 1, 2007 | 12:18 PM
minimaximini's Avatar
minimaximini
Not really. It should be CAN compatible (pin 6 and pin 14 active) as R56 is. The R50/53 is ODBII different ISO - so some diagnostic tools that worked for the R50/53 do not work for R56.
(I dug into this because I was looking for a cheap scan tool).
So - ask if they are ODBII + CAN compatible (ISO 15765).
MMM
Old Jun 1, 2007 | 12:31 PM
Loony2N's Avatar
Loony2N
MMM
The site says they are CAN compatible.
Old Jun 1, 2007 | 12:39 PM
Partsman's Avatar
Partsman
Legion_of_Doom
MMM
I don't think pins 6 and 14 have anything to do with monitoring basic engine functions such as coolant temp, as LynnEl originally inquired. Those pins will be needed for in depth diagnosis and trouble shooting.
Old Jun 1, 2007 | 12:42 PM
Robin Casady
I called PES Network (the ebay link) and they claim it is compatible with the 2007 MCS. So, I ordered one. I'll post a report when I've tried it.
Old Jun 1, 2007 | 03:00 PM
minimaximini
True that, but...
I think it has to do with the transmiission speed (the older port being lower speed - RS232 derivate). At least that is at:
http://en.wikipedia.org/wiki/On_Boar...nostics#OBD-II
My mistake - I should have copied/referenced the whole source.
MMM
Old Jun 1, 2007 | 04:56 PM
lava's Avatar
lava
That looks interesting - does it draw power from the port, or run on battery/accessory power port?
Old Jun 1, 2007 | 07:17 PM
Partsman's Avatar
Partsman
Legion_of_Doom
The SGII gets power from the OBDII port, it powers on and off with the key.
Here it is in my car...
Old Jun 1, 2007 | 09:41 PM
lava's Avatar
lava
perfect
Old Jun 1, 2007 | 09:46 PM
Longboard110's Avatar
Longboard110
auterra
Kimolaoha
Jul 5, 2023 01:04 PM
Chippawaguy
Aug 19, 2015 10:59 AM
tylewis
Aug 18, 2015 06:53 AM
PSIChocolate
Aug 13, 2015 12:46 PM
