R56 R56 fluid capacities
Old May 26, 2007 | 06:40 AM
colominis's Avatar
colominis
Anyone know the capacities for the engine oil, differential oil, and transmission? Will be doing a new car post-breakin change. The dealer seems reluctant to give me the info.
Old May 26, 2007 | 07:06 AM
buzzsaw's Avatar
buzzsaw
Check your owner's manual and if not there--Google it. Worked for me.
Old May 26, 2007 | 07:26 AM
Ryephile's Avatar
Ryephile
I know the engine oil is 4.5 quarts just from changing it already. The owners manual has the rest of the quantities.
Old May 26, 2007 | 10:15 AM
z3bum's Avatar
z3bum
MINI says the engine oil is 4.4 quarts. The transmission used around 2 quarts of oil when I changed it (by accident) I didn't try to measure the transmission oil amount, rather I pumped oil into the fill port till it squirted back out (the old way to do it) and then replaced the bolt. The transmission shifts quite smoothly with the Mobil 1 gear oil. Probably would do even better with Redline.
Old May 27, 2007 | 04:18 PM
colominis's Avatar
colominis
capacities
My owners manual certainly does not have fluid capacities except for fuel. Otherwise I would not have asked the question.
Old Feb 5, 2011 | 09:19 AM
fastring's Avatar
fastring
Capacities R56
Bump. I've googled and its not in the manual. Looking for capacities like transmission oil and such.
Old Feb 5, 2011 | 09:39 AM
Kimbo80's Avatar
Kimbo80
Here you go fastring. This is for the "S" models, but you can use the same site for JustaCoopers/Clubmans, etc. I can't find the specs on the lsd.
http://www.amsoil.com/mygarage/vehic...+MINI+COOPER+4
Old Feb 5, 2011 | 10:33 AM
klricks's Avatar
klricks
Page 151 of the '06 owners manual (PDF version) does have some capacities though not all the ones you are looking for.
Fuel, Oil, washer, coolant is all it has.
Old Feb 13, 2011 | 08:14 AM
fastring's Avatar
fastring
Thanks Kimbo80, I've booked marked that Amsoil chart, looks like a good ref.
IQRaceworks
Jul 15, 2022 05:51 AM
Aug 19, 2015 12:51 PM
dchang0
Aug 10, 2015 03:37 PM
