R55 Changing Sport Suspension
Old Dec 10, 2015 | 09:13 PM
lyonsfin's Avatar
lyonsfin
Hi Folks. I am about to be another BMW convert....Seriously considering a low mileage 08 Clubman S. Only catch is that it has the Sport Package. Most of the options of that package are very desirable but the ride quality over less than perfect roads is almost jarring (not as bad as my 83 911) and it seems to bother my wife. I know that I can switch from run-flats to normal tires, I can change from 205-45 to maybe 195-55, but can I return the stiffer suspension back to more of a "touring" ride? Springs? Shocks? Both? Cost?
Thanks for the help
Old Dec 11, 2015 | 05:21 AM
MyroMini's Avatar
MyroMini
I had the same setup in my 09 Clubman S. Just switching to non-runflat in 215-45R17 made a world of difference in the comfort level. I would try that before going the more expensive route of suspension swap
Old Dec 11, 2015 | 08:37 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Yes, I'd go with the tire route first and then maybe look into alternative suspension options. Changing out the run flats will make a world of a difference in ride feel.
888.280.7799 | 6am - 5pm PST
Old Dec 11, 2015 | 09:38 AM
lyonsfin's Avatar
lyonsfin
Thanks for the support. Sounds like a plan. The tires may be original so they will be ready to be changed in a short time.
Old Dec 11, 2015 | 09:42 AM
sub3622's Avatar
sub3622
After you change the run flats go with FSD´s shocks
Old Dec 11, 2015 | 10:25 AM
Switch off those runflats, drive it and see how it feels to you. Then mod.
Old Dec 11, 2015 | 12:55 PM
Big Jim Swade's Avatar
Big Jim Swade
I have an 08 Clubman S with the standard suspension, original shocks and 215/45-17 tires and the ride is still great. I haven't had a reason to upgrade the shocks yet, but FSD's will be on the list some day.
Old Dec 11, 2015 | 02:00 PM
BMBULBE's Avatar
BMBULBE
I have sport suspension plus the sport package (17" wheels, etc), and also changed to non-run flats. Big improvement. The ride is now very firm, but not "severe."
Old Dec 13, 2015 | 05:54 PM
bratling's Avatar
bratling
Super Moderator
Before you buy that '08 you should pull a service history. Lots of problems in 2007-10 models. If you can find a 2011+, you'll likely save yourself some headaches.
Here is a great guide on what to watch out for:
https://www.northamericanmotoring.co...ml#post3512385
Also useful:
https://www.northamericanmotoring.co...11-recall.html
shahriar35
Jan 5, 2016 04:27 PM
MrRaD
Nov 20, 2015 03:55 PM
Jeffob5
R55 :: Clubman Talk (2008+)
Nov 16, 2015 06:06 AM
Tylerlanger1
Nov 14, 2015 01:18 PM
Jeffob5
Nov 11, 2015 12:38 PM
