R55 Fender well nuts, spinning?
I use a pick or screwdriver to hold the outside part while turning the inner. If they round out you will need to destroy them to remove and get new ones.
http://www.waymotorworks.com/expandi...body-clip.html
actually a very common fastener used on MANY cars today
they are disposable . . . you can buy a box of them at any decent chain part store
The liner has those clips that always seem to twist and break. Use a fat head Phillips OR a split head pry tool to hold them so the head will not just spin. And goodluck.
07130702966 Plastic Rivet
http://www.ecstuning.com/Search/SiteSearch/07130702966/
Plus 1 on using a Door Panel Removal tool to hold the lower 'socket' section from spinning while trying to remove the inner 'screw/pin'.....
: mad:
Yep, when BMW took over Range Rover / Land Rover they acquired the BMW / MINI hardware.
wildwestrider
11
Jan 29, 2016 05:06 PM
