R55 Water on boot!!!
Old Nov 9, 2014 | 10:56 AM
pjv1k's Avatar
pjv1k
Water on boot!!!
Not the first time and this time I made sure I didn't open the rear doors in rain storm... My spare tire holder and all its tools are filled with water, anyone else have one this issue?? Why do I hate this car??? 11 clubman s
Old Nov 9, 2014 | 11:40 AM
Fiveostang's Avatar
Fiveostang
You have a spare tire? WTF!
Old Nov 9, 2014 | 03:10 PM
pjv1k's Avatar
pjv1k
Just the holder for it not a actual spare this is mini we are talking about!!!
Old Nov 9, 2014 | 04:02 PM
MINIMAN1411's Avatar
MINIMAN1411
I had the same issue on my 2013 Clubbie, it was a seal on the sunroof that had gone bad and somehow whenever it would rain, the water would end up in spare wheel well, it ended up rusting my jack and tow hook.
Old Nov 9, 2014 | 04:44 PM
pjv1k's Avatar
pjv1k
Good to know do you know which seal it was??
Old Nov 9, 2014 | 05:40 PM
MINIMAN1411
I don't remember which one, it was a while ago, but my service advisor said it was common in the clubman, so if you ask them, they might know.
Old Nov 10, 2014 | 01:51 AM
pjv1k's Avatar
pjv1k
Thanks I'll give them PIA a call
Old Nov 11, 2014 | 05:58 AM
Its the rear sunroof tubes, check to make sure they are connected and they are not clogged, they are under the headliner.
#3 http://www.ecstuning.com/Search/SiteSearch/54137174869/ 54137174869
Seal in the sunroof or the clubman barn door seal.
Sunroof seal: 54107210652
http://www.ecstuning.com/Search/SiteSearch/54107210652/
Rear door main seal.
Rear Trunk Barn Door Seal 51762757822
http://www.ecstuning.com/Search/SiteSearch/51762757822/
https://www.northamericanmotoring.co...corrosion.html
https://www.northamericanmotoring.co...er-leak-2.html
Old Jan 9, 2017 | 01:44 PM
davidg5700's Avatar
davidg5700
Sorry about resuscitating an old thread, but my sons Clubbie ('13 S) is getting water in the boot under the foam insert. Is there a way to tell definitively if the drain tubes are blocked? Would water show up in other areas?
Thanks.
Old Jan 9, 2017 | 08:41 PM
cargusjoh's Avatar
cargusjoh
EDIT LINK FOUND (pro tip use google) : https://www.northamericanmotoring.co...ater-leak.html
I searched with out success for a previous post I read regarding a possible poor weld on the spare tire hold. If I remember correctly, it was at the top part, at the rear of the MINI. This is not much to go on. I don't recall if you have to take off the threshold to get to it for inspection.
Can anyone help with that post or more information here?
Old Jan 10, 2017 | 06:12 AM
Yea, thats it. There are two linked above in my post #8
Check the drain tubes and also check those seals in the back and top. When you open the clubdoors you can get to the seals. For the sunrool seal, you have to go from the top.
Diagram
http://www.realoem.com/bmw/enUS/show...70#51762757822
Old Jan 11, 2017 | 11:18 AM
davidg5700's Avatar
davidg5700
Thanks for all the links, but looking through them, I don't see where the drain tubes are routed.
I looked through the diagrams on realoem, but still can't identify this. I looked around the boot a bit, but nothing looked obvious to me. Any idea where I can find these drain holes?
Old Jan 11, 2017 | 11:42 AM
Try this:
http://www.realoem.com/bmw/enUS/show...diagId=54_0372
or this
https://www.northamericanmotoring.co...runk-pics.html
Old Jan 19, 2017 | 06:11 AM
bugeye1031's Avatar
bugeye1031
Moderator
i had this issue....looked closely at the plastic sill (the big one under the barn door) and i could see a dried trail of dust where the water flowed....I replaced the weatherstrip around the barn door (Rear Trunk Barn Door Seal 51762757822) and the leak stopped. Very easy to do. i believe that the seal had gotten twisted at the top lip and the water flowed down from there into the boot. the twist was very slight and not at all noticeable unless you look for it.
Old Jan 25, 2017 | 02:29 PM
clubman2009's Avatar
clubman2009
My wife's '09 Clubman is having a similar issue but the water drips down the rearview mirror and onto the dash. I better check the rear and make sure no water is puddling up in there rusting everything out.
Where can I find a door seal for the 3rd door? The seal where the 3rd door and passenger door meet is torn and needs to be replaced.
Thanks.
USNAE2
16
Jun 17, 2022 07:17 AM
ian260
Mar 29, 2017 06:08 AM
gknorr
Dec 26, 2016 09:38 AM
vetsvette
Oct 2, 2015 05:32 PM
gknorr
Oct 1, 2015 09:20 AM
