R55 Best rubber floor mats?
Anyone have a recommendation on R55 rubber floor mats? I want something that stays in place well primarily, black, can handle rainy Oregon weather. I'm leaning towards Weathertech but might consider OEM ones, although there appear to be 2 OEM rubber mat styles.
I currently have OEM carpeted mats... Those round plastic velcro things that screw into the floor... They feel like they never get tight. It feels like they are spinning into the carpet or carpet pad, not the metal of the floor. Is that normal?
Thanks.
Thanks.
Weather tech
anyone have a recommendation on r55 rubber floor mats? I want something that stays in place well primarily, black, can handle rainy oregon weather. I'm leaning towards weathertech but might consider oem ones, although there appear to be 2 oem rubber mat styles.
I currently have oem carpeted mats... Those round plastic velcro things that screw into the floor... They feel like they never get tight. It feels like they are spinning into the carpet or carpet pad, not the metal of the floor. Is that normal?
Thanks.
Thanks.
Weather tech are good. My only gripe with them for the Clubman is the rear mat gets "crushed" when the front seats are all the way back/down.
Still, great protection all around. My kids muddy/salty boots from last winter never touched the carpet! The best part is it covers the center "hump" and really protects the carpet well.
Weather tech also uses a screw type mount. It fit perfectly on the drivers side. But the mounts were several inches off on the passenger side (not an issue since they are moulded to the floor, so they do not slip).
The drivers side was fine, a little short near the gas pedal. The OE mats fit a little better here..
(Yes, I've had both sets).
+1 on the weathertech / MINI version for the Clubman , easy to clean.
Fronts 82112290653
http://www.ecstuning.com/Search/SiteSearch/82112290653/
Rear Set They have a matching design. 82112290688
http://www.ecstuning.com/Search/SiteSearch/82112290688/
Fronts 82112290653
yes the slip but not enough to effect driving. I haven't had any squeaking with mine. I do like just taking them out and pressure washing them. Never have to vacuum carpets again.
We have OEM rubber in my wife's Mini and they work for her use. I have Weathertech in my BMW and really like them. Here in Colorado they get trashed in the Winter. Just pull them out, dump the crud and wash in the utility sink and they are good to go. I haven't noticed any foot slip and there is no squeaking.
I like these, they fit right away on the passenger side and a little trimming on the drivers.
http://www.pepboys.com/product/detai...or_mats/rubber
They come in black as well.
I like Weathertech but a word of caution. If you have the stainless steel foot rest plate the Weathertech hard plastic rubbed a permanent mark in it over last winter season. As a result I cut out a portion of the mat so it did not contact the foot plate any more. Also since I was annoyed looking at it I tried rubbing it out but no luck, I ended up rotating the plate 180 degrees so I did not need to see it every time I drive. Also I currently have the rubber MINI OEM mats and will install the Weathertech's mats back once it gets colder. They really hold water/slush.
I had weather tech in my old Honda, I really liked them. I have the OEM mats for the mini, and they seem to be the same construction as Weather Tech. I'd go for either of them, just buy the cheaper set. I wouldn't be surprised to learn that mind's are just rebranded weather tech.
Fronts 82112290653
Fronts 82112290653
The round Velcro discs just screw into the carpet, so theres never a 'fully tight' posistion. The MINI branded weather techs from ECS come with new discs, so you can make a new hole if you wanted. Perhaps the your old discs have spun around too much and rounded out the area they are set into?
Pretty cool design mats , on top of that. Easy to clean,.
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
