R55 Will it leave a residue?
Old Feb 26, 2013 | 06:52 AM
IzzyG's Avatar
IzzyG
I have the factory JCW spoiler on my Clubman:
I'm getting a replacement spoiler and was wondering, since the spoiler is technically glued on, will removing it leave a residue that you then need a body shop to buff/work on? Or is it a clean removal with maybe goo-be-gone? And how difficult is it to break the bond? Will 2 guys on each side pull up work? Or is there a trick to this? Thanks.
Old Feb 27, 2013 | 03:10 PM
CZ Mate's Avatar
CZ Mate
I not sure you can just pull it off with just brute strength. It is glued on with a 2 component adhesive which is very strong. I know i read on here that someone had removed the spoiler.
I would recommend using a heat gun and some fishing line. you should be able to get it off and be able to clean off the residue by hand.
one last thing that came into my mind was, i thought i read that if installed at the factory it was also bolted on. (but i might be wrong) I did a bunch of research, because i have a JCW spoiler and need to install it on my wife's.
hope this helps.
Old Feb 27, 2013 | 04:09 PM
M'Cooper's Avatar
M'Cooper
I highly doubt its just glued on with double side tape. Im sure its bolted as well as taped from the inside of the roof up. I would make very sure before you pull on it or you can dent the roof. I have read from the factory there bolted and glued and if the dealer installed it on delivery its just glued.
Old Feb 27, 2013 | 04:20 PM
IzzyG's Avatar
IzzyG
Only one bolted on is the other type of spoiler. All JCW spoilers are just glued on. This was confirmed by 2 dealers and a bunch of posts online. And I found out they use Betalink glue/epoxy. Some success stories out there but I'm just gonna get a body shop to remove it. They'll be liable for damage at least(spoke to owner of the place and they're willing to take the risk)
Old Feb 27, 2013 | 05:12 PM
CZ Mate's Avatar
CZ Mate
M'Cooper,
Yes it is glued on (not just double sided tape)
IzzyG,
Hope that helped out a little bit. Good luck with the removal. what spoiler you getting? Pictures?
Old Feb 27, 2013 | 05:59 PM
yetti96's Avatar
yetti96
What are you doing with this one? Possible dibs?
Old Feb 27, 2013 | 06:29 PM
IzzyG's Avatar
IzzyG
Someone has dibs on it but hey it also depends on offered price I'm not putting it officially for sale until I'm sure I can remove it without damage though.
I'm replacing it with a special fabbed challenge wing :X
Old Feb 28, 2013 | 06:26 AM
yetti96's Avatar
yetti96
Can't wait to see the new wing
Fourflys
43
Oct 20, 2015 09:42 AM
XsV
24
Sep 30, 2015 03:17 PM
fkrowland
Sep 30, 2015 10:30 AM
silence2-38554
Sep 28, 2015 12:19 PM
gnhovis
Sep 28, 2015 04:07 AM
