R55 JCW Temp. Gauge in R55
I understand that the verdict is split on the "look and feel" of OEM gauges for R56/R55... Some (most) hate it, some (including me) like it.
I like them mostly because those are OEM instruments (installed by dealer's service and covered by warranty). I am not a fan of numerous DIY kits and mounts I have seen on various MINI forums (including this one
). Cutting the wires or tanks or pipes to install is not "my forte"...
Yes, some third party manuf. make some nice looking clocks, but after installing my JCW temp. gauge today I liked what I got. You be the judge.
). Cutting the wires or tanks or pipes to install is not "my forte"...Yes, some third party manuf. make some nice looking clocks, but after installing my JCW temp. gauge today I liked what I got. You be the judge.
I like it
I was debating the same setup and if I wanted 2 gauges or 1 gauge and the navi mount. How is the view of the nav screen through the wheel? It seems like you would lose a bit of the upper left corner of the screen.
Got it at Morris Town MINI, their "internet price" (check web site) that is lower than any other dealer I checked in US or Canada... I did not mount it by my self. I took it to dealer for warranty purposes. Charge was for 2h labor with 20% discount coupon. Total cost of mounting (with local GRAB TAX of 13% !!!!!) was $290. Ouch....
But, when I sit in my BROWNSUGAR I don't think about it... I just enjoy
True... But what kind of info. you are looking at upper left corner of GPS???? I don't, so I don't mind....
Would you consider posting the parts numbers for everything that it took to get this result?
I like it, but more importantly, it provides much needed information. I've had a water pump issue that might have been avoided if I'd have seen the water temperature.
Great job.! it looks awesome, I've been searching for last two months about JCW gauges and finally decided to get two clock set (water temp. and toque ind.) for my 12mc. I'm not sure about the installation but probably I'll do this on my own..
and I've a question about the lighting, does JCW gauge light up when u unlock the car ? like other gauges ?
Those gauges look very nice at night and reflect a consistency in color especially at night.
Here are the part numbers and options. You can custom select the gauges to what you like.
John Cooper Works Sport Gauge Installation Kit - Double Indicator
http://www.ecstuning.com/Search/62112149355/ES515305/
John Cooper Works Sport Gauge Installation Kit - Single Indicator
http://www.ecstuning.com/Search/62112150353/ES515306/
The individual gauges:
Indicator Cooling Water Temperature - Celsius
http://www.ecstuning.com/Search/62110445458/ES515303/
Indicator Relative Torque Gauge - %
http://www.ecstuning.com/Search/62110445459/ES515304/
Lateral G Force Gauge - G's
http://www.ecstuning.com/Search/62110426786/ES515302/
And here is a Link to the install instructions. Click HERE.
Thanks and I hope that helps.
Here is the offical PDF install instructions for both type kits:
Click Here.
Looks great lit up at night with the dual guages.
https://i.imgur.com/QVjs7.jpg Thanks for the link NJ MINI.
Click Here.
Thanks, I already have the official MINI instructions from the motoringfile site, was just wondering if anyone has actually installed the kit themselves and if they could share any new insight on how to connect pins B7 and B8. Pin B8 doesnt even have a terminal on the end, just a cut wire. The location descriptions for those connections are a bit vague. B7 has a terminal pin end and yet it says to use the "mini connector" (scotch-lock type tap) while B8 with no end terminal is to be inserted into a connector. That doesn't make sense to me.
My question about the JCW gauges... Preface: I understand the H2O temp, but why the other two? WTF cares about Lateral G Force??!??!? How about Oil temp? Pressure? Turbo Boost? Things that actually matter.
I would greatly prefer oil pressure instead of "relative torque" but after searching extensively, these gauges are the neatest setup available....I'm going with the 2 gauge setup (torque and H20 temp).
I still haven't installed this gauge setup yet (got sidetracked by other mods) but have now decided to just install the coolant temp on the left side. I have the 2 gauge kit (bought it before I took delivery of my MINI 2 years ago!) and will just remove part of the bracket made to hold 2 pods and tuck the unused cable out of the way inside the dash.
As for symmetry, I've kind of gotten used to the idea of having it look asymmetrical with just one pod on the left.
Aug 19, 2015 12:51 PM
tylewis
Aug 18, 2015 06:53 AM
Accessory Products
Aug 11, 2015 12:37 PM
Aug 11, 2015 12:34 PM
