R55 If I forget to...
If I forget to...
.......turn off the headlights, will the battery completely drain, resulting in needing a jump, or does the car shut them off automatically, after a period of time?
After boarding the train this morning, I could not remember if I turned off my headlights. I nearly had an ulcer at work, and luckily, I had turned them off.
Yeah, my MA told me to just leave them on all the time. The car will know what to do when you shut down and leave, locking the doors behind you.
But I have noticed that you do need to enable the fog lamps each time you motor up. Minor annoyance. At least I get to push a cool button again! That's worth celebrating!
Spike
Spike
Dang - how many Hellas do you have?? At 55W each, a pair of them shouldn't draw more than 10 amps with the engine off, and you have a 46 amp-hour battery, so 15 minutes (2.5 amp-hours) should barely make a dent.
+1 ... anyway to get the fog lights to stay/come on everytime the headlights are turned on?
check in the Mods/Electrical section and there is a mod to turn on the sport function each time the car is started it may work to do the same with the fog/driving lights. All the circuit there for the switches work the same way just different inputs to the computer. So that may work, or need just slight modification.
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
GAT
Oct 4, 2015 07:27 PM
ShadyCoop
Sep 20, 2015 08:57 AM
