R55 Engine temp
Old Apr 2, 2009 | 09:33 PM
shadyyu's Avatar
shadyyu
Engine temp
In our 2009 clubby, there is not engine temp to be seen anywhere. Beside installing a aftermarket guage, is there to know the engine temp???
Old Apr 2, 2009 | 09:34 PM
Oxybluecoop's Avatar
Oxybluecoop
nope
Old Apr 2, 2009 | 10:00 PM
Benibiker's Avatar
Benibiker
Yeah, when you see steam you know it overheated.
Old Apr 3, 2009 | 03:23 AM
danny 1940's Avatar
danny 1940
Myself and others on the forum use the Scan Guage. It will give temp as well as numerous other tid bits of information. It's a simple plug in to the OBD port and it works. I use it in the Mini and transfer to my other vehicles as need be. Dan
Old Apr 3, 2009 | 05:56 AM
Minidrivr's Avatar
Minidrivr
The other option now if you want OEM, is the new JCW gauge pack.
https://www.northamericanmotoring.co...s-for-jcw.html
Old Apr 3, 2009 | 06:19 AM
schatzy62's Avatar
schatzy62
But the only usable gauge that will be available is the temp gauge. The other two, Lateral G and Relative Torque. Who needs them. I want oil pressure and oil temp as well as boost.
Old Apr 3, 2009 | 07:05 AM
sailorboy's Avatar
sailorboy
It's beyond me why Mini doesn't include oil pressure, water temperature, and a volatge gauge in their cars. These are basic gauges found on most automobiles and are helpful in detecting potential engine troubles. I like to know when my engine is warm, that my alternator is charging at the correct volatge, and that my oll pressure is normal. Kind of basic....eh?
Old Apr 3, 2009 | 12:45 PM
dvhone's Avatar
dvhone
Originally Posted by sailorboy
It's beyond me why Mini doesn't include oil pressure, water temperature, and a volatge gauge in their cars. ... Kind of basic....eh?
+1
Old Apr 3, 2009 | 01:46 PM
Minidrivr's Avatar
Minidrivr
That was only in response to the OP asking about a temp gauge. I've never had the others in a vehicle so can't say if I would consider them useless. Oil pressure and temp would be nice in a single gauge opposite the water temp gauge on each side of the tach.
Old Apr 3, 2009 | 02:25 PM
shadyyu's Avatar
shadyyu
+1. So not used to don't have the engine temp....
Old Apr 3, 2009 | 03:46 PM
ScottRiqui's Avatar
ScottRiqui
That's what I like about the Chrono Kit in the first-gen MINI - it gives you coolant temp, oil temp, and oil pressure. I'm hoping that they introduce something similar for the newer MINIs eventually.
The only good thing I can say about the coolant temperature idiot light in the second-gen MINI is that at least it's a two-color light, so it will give you *some* kind of indication before the engine actually no-kidding overheats.
Old Apr 3, 2009 | 06:18 PM
ftttuhzbmcs's Avatar
ftttuhzbmcs
Why they ever put this type of vehicle on the street, let alone any vehicle on the street, without these gauges is beyond me. I will be at the MINI plant in May and I'm going to complain loudly about this issue.
Old Apr 3, 2009 | 07:17 PM
Sin MINI's Avatar
Sin MINI
I can place my R53 computer in test mode and show all kinds of things. I used it to prove to my stupid dealer and to MINI that my driving lights did not cause my coolant overheats.
Doesn't the Clubby have something like that?
Old Apr 3, 2009 | 08:12 PM
jondon69's Avatar
jondon69
Hey, re the scangauge -- can you set it to continually show engine temp or do you have to press buttons every time you want to see the engine temp?
thx!
Old Apr 3, 2009 | 09:47 PM
proximal's Avatar
proximal
thx!
It's continuous. I have mine set to show coolant temp, intake air temp, electrical voltage, and manifold air pressure all at once.
Old Apr 3, 2009 | 09:53 PM
ScottRiqui's Avatar
ScottRiqui
Have you ever compared the ScanGauge voltage readout to a measurement taken with a voltmeter right at the battery? When I've installed voltage gauges in the past, I've found that the voltage readings you get from the ignition wiring, cigarette lighter socket, fuse box, etcetera are often lower than the actual battery voltage.
Of course it doesn't matter much if you're only monitoring trends, I was just curious.
Old Apr 4, 2009 | 05:39 AM
rlw's Avatar
rlw
Proximal wrote (referring to his ScanGauge):
>> It's continuous. I have mine set to show coolant temp, intake air temp, electrical voltage, and manifold air pressure all at once.<<
That's exactly the readouts I use on mine, too. They seemed to be the most useful and fill-in for the non-existent Mini gauges. It is a damn shame that the customer has to do things like this, Mini should have included these gauges with the original instrument cluster.
The cool thing about the manifold air pressure (MAP) reading is that it can also be used as a surrogate turbo boost gauge. Jump on the throttle and watch its readout go from 4.5 to 27.5 in a second. By deducting ambient air pressure (approx. 14.5 in my location) from the reading, I can divine the boost being applied.
So, a reading of 27.5 = approx. 13 lbs. boost (27.5 - 14.5). I found that it will hold that value for several seconds, indicating that the overboost function seems to be working on mine...w00t!
2 big thumbs-up for ther ScanGauge II, it was the easiest after-market install I have ever done, took all of 2 minutes. I found it for $125 on Amazon.com. And I found that it mounts nice and neat and clean to the dash in the little area to the left of the steering wheel. I simply used some store-bought 2" velcro strips that I got from the local fabric stores for $1.00
-RW-
Old Apr 4, 2009 | 06:33 AM
jondon69's Avatar
jondon69
I'm thinking I'll be ordering one soon :-) Thanks!
Kimolaoha
Jul 5, 2023 01:04 PM
Chippawaguy
Aug 19, 2015 10:59 AM
tylewis
Aug 18, 2015 06:53 AM
PSIChocolate
Aug 13, 2015 12:46 PM
