R55 Haunted barn doors
Old Mar 15, 2010 | 06:15 AM
  #26
taysan's Avatar
taysan
Well over the last Friday/Saturday deluge of non-stop rain we had in Toronto, my 2008 Clubman started popping the rear hatch faster and more often than Paris Hilton.
Once the rain stopped and things dried out, it stopped exhibiting this exhibitionist behavior. I dropped it off at MINI this morning and they gave me a spanky new 128i as a loaner (BMW Toronto does MINI service here). Nice car
These little things better sort themselves out soon, or I'll be selling the car before warranty runs out.
Old Mar 19, 2010 | 09:06 AM
  #27
PRinTX's Avatar
PRinTX
That crazy, I was complaining to the dealer that the right door did not pop-open (you know hit the button and it swings open) like the left one and they said it was a safety mechanism to keep the door from hitting other cars when pressing the button.
Old Mar 19, 2010 | 10:08 AM
  #28
taysan's Avatar
taysan
It shouldn't fly open, but if it opens while you're driving, enough small bumps and turns will eventually cause it to swing wide open.
BMW replaced all sorts of things on mine, including the handle itself. Any excuse to bill the mother-ship under warranty I suppose.
Old Mar 23, 2010 | 06:24 PM
  #29
Little Bean's Avatar
Little Bean
Mine stopped being haunted if i thru the key fob in the boot and then got in and drove away. Then I changed to my spare key fob and have not had a problem since.
Any thoughts?
Old Mar 26, 2010 | 07:14 AM
  #30
tominizer's Avatar
tominizer
Same here....... changed to my spare key fob and the issue went away. I have to try going back to the other one and see if it happens again.
Old Mar 27, 2010 | 05:49 PM
  #31
Chief_Charlie's Avatar
Chief_Charlie
Driver's Side Left Rear Door Won't Open
After I first received the 09 Clubman in Sept 08, had a problem with the left rear door not opening. The dealer apparently performed the service for the wet wiring, and the problem went away...until recently.
Once again the door won't open......but sometimes it will if you open and close the right door firmly. Then it quit working alltogether
Turns out the problem is a defective "micro switch" in the right door which isn't tripping to tell the left door (via the computer) that the door is open, so it's OK to release the lock.
Have an appointment to take it to the dealer on April 1st....no fool'in
Old Mar 31, 2010 | 07:59 AM
  #32
n559br's Avatar
n559br
I just completed replacing the door latch on the right split door in my mini. It was a drowned car but only had about 6" of water in the floor boards. I found the microswitch was bad but cannot be repaired without disassembling the latch. Since the latch only retails for $65 it was an easy fix. The auto opening feature is activated by the CAN bus from the JBE so any corrosion on the CAN bus leads could cause noise and possible malfunctions.
If you want to test the microswitch you need a long metal probe and slide it into the latch opening about 2 inches and then you can get the switch to trip to let you open the left split door. Of course there is no shop manual I have been able to purchase to tell me how to fix just the switch.
Old Apr 25, 2013 | 03:27 PM
  #33
pmsummer's Avatar
pmsummer
One of the things I forgot to mention to my SA before the car went out of warranty... and I thought it was just me somehow.
Old Oct 9, 2013 | 02:17 PM
  #34
bastokyg's Avatar
bastokyg
I see that I'm coming in a little late here, but I have a 2011 Clubman S and I often come outside in the morning to find one of my barn doors open. The dealer told me it was because I probably pressed the fob button by mistake, but since the first couple of times I have been very careful about putting my fob away as soon as I walk in the door after work. This continues to happen, fairly regularly. I wish there was some way to adjust the sensitivity. I had to wonder if one of my neighbors had a similar frequency and it was opening my door, but I have moved fairly often lately and the only thing I can figure is that it's haunted. Windows are sometimes down on both sides. Once I went out after it had rained hard all night, to find the windows down, but the interior completely dry. Can ghosts defy the laws of physics?
Enough people seem to be having this ghostly opening issue to make it seem like something Mini needs to look into. I know there is a water issue, but I don't think that's it.
Old Oct 9, 2013 | 03:00 PM
  #35
pmsummer's Avatar
pmsummer
Sounds like you need to schedule a visit (only 200+ miles!) to a/your 'local' MINI dealer. The windows going down hint of a need to 're-flash' the controls. When's your next oil change due?
P.S. My mother was born in Rogers.
P.P.S. I became convinced my jeans are just too tight/pockets too full of knives and phones.
P.P.P.S. Welcome!
Old Oct 9, 2013 | 04:11 PM
  #36
bastokyg's Avatar
bastokyg
Yes, a trip to the dealer is scheduled...
Coincidentally, I scheduled a service for next week (yes, 200+ miles away!!) and we'll see what they can do. My dealer in San Jose wrote it off as "fob-in-the-pocket." I've been careful though.
Thanks for the welcome! I've only been in this area for 6 months -- it's a great place to drive a Mini!
Old Oct 9, 2013 | 04:14 PM
  #37
pmsummer's Avatar
pmsummer
Do this, if you can.
http://www.ozarkmini.com/
Old Oct 9, 2013 | 04:17 PM
  #38
pmsummer's Avatar
pmsummer
Looks like you are fixin' to have a slightly closer dealer.
https://www.facebook.com/parkermini
Old Oct 9, 2013 | 06:43 PM
  #39
bastokyg's Avatar
bastokyg
slightly closer, but good to know!
Thanks!! The difference in distance between Bentonville and Kansa City, MO compared to Bentonvillle and Little Rock is only a matter of a few miles, it seems. I guess I had it easy in the SF Bay Area where there were 3 dealerships within 50 miles. Now I have to plan a whole day around getting a service.
Old Oct 9, 2013 | 06:54 PM
  #40
bastokyg's Avatar
bastokyg
WOW! Wish I had known about this sooner
Haven't yet made it to Eureka Springs -- this looks like fun. Thanks!!
USNAE2
16
Jun 17, 2022 07:17 AM
jeri534
Nov 6, 2015 01:40 PM
torpeau
Oct 8, 2015 11:10 AM
patsum
Oct 1, 2015 06:33 AM
dutchhome
Sep 30, 2015 07:17 AM
