R55 XM for my Clubman
XM for my Clubman
Just drove our new NightFire Red Clubman home. I took the Blitzsafe XM adapter out of the old MINI with the intent of putting it back in the clubman. But, the wire harness I tapped into on the right rear of the mini isn't in the same place on the Clubman. Anyone know if the same adapter can be used for the Clubman and where the wire harness might be?
Just curious as to why you'd want to use a Blitzsafe box for your XM connection instead of the "Aux-In" already available. Would the Blitzsafe box offer any additional features, or is it just that the wiring would better suit your install?
Blitzsafe XM Direct does NOT work with the R56 or the R55 (Clubman). MINI is using a fiber optic bus (MOST) to transmit audio data which in turn feeds the head unit.
I purchased an XM Xpress R - it works through the Aux input and it matches exactly my Piano Black trim. Using a TuneDok cupholder mount. Almost as good as XM Direct.
I've contacted blitzsafe a couple of times about a xm solution for the R56, they say none is in works. I'd definitely spring for the unit if it became available. If enough pound on them, maybe they will. With the clubman and next year the R57 convert, followed by an mini SUV, you'd think they'd develop it. I'm also assuming that BMW is now using the optical bus, in the past the bmw and mini unit I think were identical. Contact customer support and tell them to develop the interface!!! (I have twice now.)
I use an xm roady and the aux input. Works great, just can't change stations from the wheel. I keep the remote in the car so I don't have to fumble by the cup holder. Also some have reported more drop outs using the sirius factory antenna, I opted to use the supplied xm antenna and have it mounted just behind the factory antenna and the wire hidden all the way to the cubby area.
What's the number to that company? I want to call, too. Maybe they're just waiting for the merger to go through.
LCranston
R55 :: Clubman Talk (2008+)
42
Jun 27, 2016 11:35 AM
TrueEddie
Sep 2, 2015 11:43 AM
