R52 Cabrio Roof Wear Update
I have a 2005 MCSC and the roof has been showing the notorious wear marks above the passenger windows. Although there is no hole (yet), it is clear that the canvas is wearing away in a section about 1/3" long and about 1/8" wide on each side of the roof.
I took my car in for service yesterday and the service advisor indicated that they have been instructed to not replace any more roofs because the canvas wear continued on the new roofs as well. He said MINI USA is working on a real fix but he knew of no date for a solution.
I called MINI USA, told them what he said and asked if they had any additional detail. They indicated that they are indeed hard at work on a solution to the problem and expect one "very soon". I asked if a customer notice of some sort will go out when a fix is available. They indicated that that was not in the plans but that I should keep in touch with my dealer to find out when a fix is available.
So, now you know what I know.
Originally Posted by neilgj
[For what it's worth, I also noticed that the 2006 Cabrios have a much larger rear window - I'd say about 50% larger - than the 2005 model]
Originally Posted by LouiefromStLou
I had my roof replaced in September. It is showing no roof wear at this point. But if it does, I guess I'll be getting a third!
Lois
Lois
Got mine
replaced 4 days ago. Car was built Oct of 04. The roof had white marks all over it. Looks great now, though its to cold to actually take the top down so I guess it will have to wait till next summer to see if it comes back.
Had our third top installed (2 replacements) about a month ago on my wife's MCc, and so far so good with 'wear marks'. Had to go in this week to fix 'rattles' from the top mechanism and windows not sealing properly, but all seems fine now.... We'll see how this one lasts!
Ken
Ken
Mine is getting replaced as I type this. I will keep an eye on it and post back. I hope the rattles are gone as well in the process. Hoping that it is resolved, because I really don't want to have to get another one. I was under the impression they already found the solution. May have to wait till spring.
UPDATE: Top has been replaced and looks different. Hard to remember all the aspects of the old one but it appears that they have made large steps to solving the problem. From memory the support bars that lock into the windshield are not all plastic anymore. The side closest to the side windows is rubbery now, like the trim around the windscreen, instead of hard plastic (which I think it was before). Also alot of the edges appear to be rounded now. My rattles are gone too.
I haven't been able to compare to an old '05 top yet. There is another conv in my parking lot at work. I think I will bring the mini to work one of these days and park next to it to review the physical differences. Bottom line, it looks like they made big steps in solving the problem. I'll keep you posted on the wear as I am hoping for some warm days this winter. I haven't opened it yet to see if it sits differently either. I'll check that out soon.
About a month after I posted my first message, the dealer called to tell me my new roof was in (?!?) I had the new roof put on and so far (knock on wood) no signs of wear. There appears to be additional reinforcement around the wear areas on the underside of the roof.
I thought the roof rattle would go away after I had the new roof went on - but it did not. I did isolate the source to the plastic housing above the passenger side door. I sprayed a little of that magic elixir - WD40 - in the gap and have been rattle free for over a month!
I too have an October 04 build MCSc with white wear marks on the liner above the side rear windows. I live in Ohio and don't drive the car in the winter, so compared to others in warmer climates, I may not use the top as much. I just assumed that this was normal. Has anyone had issues in this area from more frequent use. If so, I'll address this issue during my next service visit.
Oh, and I have a few air whistles too that I need addressed and tighted back up.
I have to admit, though, with all the moving parts, I am surprised nothing has broken yet on the top. I was initially concerned that this thing was too complicated to not break at some point!
I have a 2006MCSC with the dark blue roof. I saw some light color marks starting to appear after 2 weeks.
The roof when folded pushes the fabric from the top of the roof VERY TIGHTLY against the rear roof fabric and the vibration from driving causes them to abrade against each other.
As an old Triumph Spitfire owner I always put a towel in between the fold of the plastic back window to keep it from scratching when I folded it.
I purchased two thick dark blue hand towels (to match my roof) and now place them in the two back corners when the roof is 3/4 closed to prevent the mechanism from forcing the roof tightly down on itself.
Seems to have worked fine. No more wear marks!
For all of you who have had your roofs replaced, did you go in and ask the dealer to replace it? How bad were the marks? Mine has been showing wear (Sept 04). I find it very hard to believe my dealer, or any dealer would do anything. Not real happy with my dealer right now.
The marks were clearly wear marks, identical on each side of the roof, of the same size and shape. The woven threads of the roof canvas were clearly visible and the roof had discoloured to the natural colour of the canvas. It looked to me as only a matter of time until there was a hole in the canvas.
The dealer didn't give me any trouble or make any excuses or suggest it was my fault or normal wear and tear. As a point of reference, I am in the SF Bay Area where the dealers seem to have a reputation for not being customer advocates [although I have not yet had that experience at MINI of Mountain View].
There is now a fix for prevention of roof wear
. I went in for my oil change (Friday 2/4) & they said there was a recall (of sorts) & that they would be putting some padding somewhere to prevent roof discoloring. They did it while they did my oil change. Sorry I don't know where they put it as I wasn't there to watch.
. I went in for my oil change (Friday 2/4) & they said there was a recall (of sorts) & that they would be putting some padding somewhere to prevent roof discoloring. They did it while they did my oil change. Sorry I don't know where they put it as I wasn't there to watch.I am on my second roof... replaced back in August 2005 and I so far so good. However, I am curious to see what will happen once the warmer weather returns and I resume dropping my top.
Please let me know...
Originally Posted by yomamali
Wow!! that's great news!! Could you speak more about the 'recall (of sorts)'.
I really can't sit in my Mini & notice that something new is staring down at me from the roof.
I had our '05 MCC at the dealer last week (clear coat problem) and while they had it, they mentioned a "service adjustment" on the top. The SA said it had something to do with the alignment on some tops not working correctly and making a precautionary fix?
I looked on my work ticket & here is what it says about the recall work they performed on my top:
recall 0054130100 (I assume that is the recall #) other than than not 100% sure what they did.
Yes, there is a recall on the cabrio tops (my current top is my third one).
However, no all tops will be replaced as some need some minor adjustments to prevent the discolaration and wear from happening.
We took delivery of both MINI C (mine is MCS my husband has a MC) on the same day both tops are black yet my MINI had two tops instlalled since delivery (nov. 20, 2004) and several other issues (boot closure killing the battery, rattling noises in the dash , new glove box, computer not detecting flat tire), while my huband none. Go figure !!
I noticed that the convertible is much more delicate compare to my MCS 2003
MD STREGA2
MD STREGA2
Originally Posted by lastrega
...and several other issues (boot closure killing the battery, rattling noises in the dash , new glove box, computer not detecting flat tire), while my huband none. Go figure !!
MD STREGA2
MD STREGA2
is very freaky, I will go out to my Mini & the lights are on yet the stick is in the off position. Ghost in the machine
[ Ghost in the machine
[/quote]
Well at least your not bored !!
Look me up at the Dragon I want to meet your Cabrio.. Maybe we should have "Cabrios only" event at MOTD 2006
MD STREGA2
[/quote]Well at least your not bored !!
MD STREGA2
