R52 Chirping from the rear when driving
Old Jul 25, 2022 | 06:03 PM
juicy360's Avatar
juicy360
Anyone have any experience with a chirping sound coming from the rear while driving? Seems to be road educed. It's a high pitch tweet like sound. Metal on metal. Can't pinpoint it. Seems to be coming from both sides. Top up or down. Passengers or no passengers. I checked the rear seat strike plates but the latch is plastic so don't think that would be it. I shook the seats and could not get the same sound.
I just replaced the rear shocks. I can't recall if it made the sound before. I've only had the car a week.
Thanks in advance for the help.
Old Jul 26, 2022 | 05:32 AM
ChiefM's Avatar
ChiefM
Is it coming from inside or outside of the car?
Old Jul 27, 2022 | 12:48 PM
juicy360's Avatar
juicy360
I lowered the back seats. It was louder. So I'm assuming something coming from the boot area. But it's clearly road bump related. If it's perfectly smoot no chirping but every little bump chirps. I'm going to have my wife drive it and I'll stick my head back their to see if I can isolate it.
Old Jul 28, 2022 | 12:28 PM
A383Wing's Avatar
A383Wing
possible rear brake pads moving in the caliper if you have disc brakes on the rear. If drum brakes, possible broken spring inside drum. Does the noise go away when you apply the brakes while it's making the noise?
Old Jul 28, 2022 | 02:01 PM
zabond's Avatar
zabond
or maybe dry sway bar bushes if its coming from both sides on a bumpy road
Russ
Old Jul 29, 2022 | 05:29 AM
khnitz's Avatar
khnitz
Not having a little more history with the car, it might be something else, too. But, given that you just replaced the shocks, I would double-check that. Did you tighten the bolts with a load on the shocks (so that they are in their static/neutral position)? Did you torque the shock bolts to the required spec? That is where I would start.
Old Jul 29, 2022 | 09:40 AM
ChiefM's Avatar
ChiefM
Put some lube on number #9 on left and right sides, upper and lower. It could also be the #7 bushing.
Old Aug 2, 2022 | 11:13 AM
OX4_R52's Avatar
OX4_R52
Thank you for the info. It is for sure coming from something suspension related. I had the top down yesterday and I could hear it from the "outside". I ordered new sway bar bushing, and sway bar links.
When I changed the rear shocks I used the power flex poly bushings. Do you think those squeak?
Old Aug 2, 2022 | 11:15 AM
OX4_R52's Avatar
OX4_R52
I have new rotors and pads to install, but the noise does not go away when you press the brakes.
Old Aug 2, 2022 | 01:57 PM
ChiefM's Avatar
ChiefM
It's possible, I hope you put the lube on thick that came in the package.
imaslowdriver
Jun 10, 2020 04:22 PM
Old Joe
Apr 7, 2018 11:16 PM
ronmichael
Feb 6, 2010 07:49 PM
minibeel
Sep 4, 2007 06:56 AM
mataku
Suspension
Jun 2, 2005 12:28 PM
