R52 Rear Rubber Top Molding is Rotting Away....
Old Mar 11, 2021 | 05:04 PM
  #101
Cobre's Avatar
Cobre
We have a fix it kit now. https://www.ecstuning.com/b-assemble...37123437kt1kt/
Also the original kits also if you like OEM. https://www.ecstuning.com/b-assemble...37123437kt1kt/
Are these full replacements, or just a gap filler/fix? It would be super nice to have some pictures
Old Mar 12, 2021 | 12:30 PM
  #102
Original trims are full kits.
The fix kit just replaces and add a top part of the seal(that cracks) and keeps the old main piece, which you trim off the old cracked part and but up behind the new seal.
Old Mar 14, 2021 | 04:13 PM
  #103
wtorres141's Avatar
wtorres141
My version of this modification...
I took inspiration from several posts here, combined them into this ....<$45 for this attempt.
First I totally disassembled, then cut the rubber off both parts...cleaned and shape sanded remaining plastics. Then used jb weld to join and make the base a single piece. Sanded to near perfect shape. This took the longest...glue, dry, sand...fill low spots, sand ...etc... Wash it all down with rubbing alcohol once done.
Then used 1" vinyl to wrap the piece..
Purchase the same z-shaped weather strip as the ecs kit. Then added an extra strip of double-sided tape. Be neater then I was....line up the straight edge to the top of the strip better than I did.
I did not take pictures of all the next steps. But i attached the weather strip using the red, original tape against the plastic base and let it cure overnight inside the house. On the car, I used clear nail polish to seal the threads on the bottom of the canvas, to add protection but also to provide a surface for the tape to stick to.
Fill reassembled, not bad...looks better than new from a few feet away. I could have been neater but it's good enough for me ..my rubber was totally deteriorated.
Will let it cure for a few days, the weather strip is tapped to the canvas and the plastic piece. ...some 303 fabric guard before spring and this will be done for now. Let's see how long this lasts. Thanks for all the ideas...NAM is a great resource!
Old Mar 15, 2021 | 09:50 AM
  #104
Nice work. ^^
Old Mar 25, 2021 | 01:29 PM
  #105
DiscoDave's Avatar
DiscoDave
AWESOME! I was going to try and find some rubber molding to fit. This saves me that headache. Thanks Mike!
Old Mar 26, 2021 | 06:44 AM
  #106
Yep.
Old Jul 13, 2021 | 11:45 AM
  #107
Ringo2222's Avatar
Ringo2222
Originally Posted by footin35
Just ordered from Classic Mini. NAM price is $127 plus shipping. My local dealer price was $143. Minimania was $160 plus shipping.
Buenas tardes!! Podrías poner aquí el LINK o el teléfono del lugar donde la has comprado por favor?? El precio es por cada lado o por ambos lados?? Muchas gracias.
Old Jul 21, 2021 | 11:58 AM
  #108
We have them here: https://www.northamericanmotoring.co...ng-away-2.html
Those prices you are finding are old and the price has gone up, but we have them.
Old Aug 19, 2022 | 07:53 AM
  #109
MiniSpokane's Avatar
MiniSpokane
Any Answer?
Did you ever receive a satisfactory answer to your question. I am about to replace my molding on my convertible and I still am not sure where these foam strips go.
Originally Posted by Mini Mee
Do you have a diagram or pic of where these parts go?
Attachment 152879
Old Aug 19, 2022 | 02:10 PM
  #110
khnitz's Avatar
khnitz
I just replaced these mouldings on my daughter's R52S. You should see the foam strips on the ones currently on the car. They fit at the curve of the corners on the outside of the curve underneath the chrome strip. I used the old ones (the ones removed from her car) as the guide of where to attach them on the new ones.
Old Aug 19, 2022 | 07:25 PM
  #111
MiniSpokane
Please explain what the 6 screws with what looks like nails through them are for and where and how to install the foam strips. Also, why are there no step by step instructions on how to install these on the Mini Convertible?
Old Jan 3, 2024 | 11:29 AM
  #112
Sorry just saw this post, the 6 rivets are for the side near the fabric. The main screws are the ones that always rust and crumble. They go around the outside and for that rear light mount. I have replaced mine once already. The little wedge things go on each side near the ends and are for adjustment that can go in and out on the trim near the top inside. Most of the time you only use the screws out of this kit and dont use the rivets or the little plastic wedges, you can replace the foam if you want to renew it on the inside.
DIY in French but you can see what you have to do, get a torques screw driver set https://www.ecstuning.com/b-schwaben...eces/sd-t6pcs/
https://www.northamericanmotoring.co...ing-screw.html
https://www.ecstuning.com/b-genuine-...1137123438kt2/
Old Dec 27, 2024 | 07:21 AM
  #113
Just an update, we landed the r52 Convertible ones in stock again. And we are running a rare Genuine MINI sale.
Old Dec 28, 2024 | 03:09 PM
  #114
Jonny's Avatar
Jonny
Link to sale?
Old Dec 30, 2024 | 07:52 AM
  #115
Its linked, the url clicked through to the site link on the parts.
Here is all Genuine: https://www.ecstuning.com/b-genuine-mini-parts/v-mini/
Old Jul 28, 2025 | 09:19 PM
  #116
pkgmSu2000's Avatar
pkgmSu2000
Old Jul 28, 2025 | 09:21 PM
  #117
pkgmSu2000's Avatar
pkgmSu2000
https://x8r.co.uk/mini-convertible-r...bber-trim.html
Old Jul 29, 2025 | 06:26 AM
  #118
Yep we have the fix kit listed above and used by many on here.
Old Jul 29, 2025 | 08:34 AM
  #119
pkgmSu2000's Avatar
pkgmSu2000
good morning. Your kit is exactly the same as the British kit I linked? Looks to be similar but if you had more pictures and installation video too?
Old Jul 29, 2025 | 10:03 AM
  #120
Hello, see above the guys in this thread installed it.
https://www.northamericanmotoring.co...ml#post4577691
Old Jul 29, 2025 | 11:01 AM
  #121
pkgmSu2000's Avatar
pkgmSu2000
hello again, i did take a look. Doesn’t seem to be quite the samw with many more steps involved. Can you source the British kit and bring it over to the states? I bet the throw in fine Enough tea too :-)
Old Jul 29, 2025 | 12:30 PM
  #122
Hello, thats the one a bunch of people have been using on here for years.
Also that guy above sanded and painted his and removed more of the seal. Most of the time its a they are just removing the top portion and adding that seal and done.
https://www.northamericanmotoring.co...ml#post4527421
Old Jul 30, 2025 | 07:34 AM
  #123
pkgmSu2000's Avatar
pkgmSu2000
Does the ECS kit include enough trim to replace the seals on BOTH top and bottom both left and ride side? It’s not just the top seals that crack.
Old Jul 30, 2025 | 08:11 AM
  #124
Should be enough for both 13ft of the Z shape. Measure the distance before you order.
Old Jul 30, 2025 | 10:01 AM
  #125
pkgmSu2000's Avatar
pkgmSu2000
that’s great, but if the material is short? Gotta buy a whole second kit?
