R52 Fess Up Sun Roof Cabrio Users
Old May 24, 2007 | 09:59 AM
rc'S's Avatar
rc'S
How many of you get lazy and just use the sun roof option on your cars doing a short run? I sometimes think that with the sunroof open, it is windier than the top down with the blocker. I did find out one thing the sunroof does when it is open and angled . It acts as a spoiler and the bugs that hit it flop down on top of you as your driving.
Old May 24, 2007 | 10:09 AM
tigwantstoplay's Avatar
tigwantstoplay
I confess. I use the sunroof feature on short trips. I also find that if you roll the two back windows down only about 2", the wind is significantly reduced and the sunroof option much more enjoyable.
Old May 24, 2007 | 10:13 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I'm not sure I would call it "lazy". I'd call it convenient.
Short runs and lower street speeds allow for a little sunroof opening and less time taken to open or close the top.
I took a cabrio out for a test drive and tried the various options on the top. I like the small opening. I didn't take it on the freeway.
I wouldn't want "bugs that hit it flop down on top of you as your driving".
That's not part of the desired MINI motoring experience but I believe you that it can happen.
Old May 24, 2007 | 10:35 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Sunroof - check. Probably about 10% as much as I go fully top-down, though. Which is about 80% of the time.
Old May 24, 2007 | 10:57 AM
ThomB's Avatar
ThomB
I sometimes use it (along with the rear windows down a bit) on cooler morning. That said, I had top down, windows open this morning...
Old May 24, 2007 | 06:28 PM
Lordon's Avatar
Lordon
Were both guilty and proud of this. And besides the AC works better that way. Its a bit warm in the desert.
Don and Lori
Old May 24, 2007 | 07:54 PM
eager2own's Avatar
eager2own
Another 10% sunroof with 80% top down (+1).
When too cold outside I use it with the rears partly down (especially 'cause I haven't gotten the windscreen yet . . . I know -- that's the best cabrio mod, but I've been throwing my money into other mods).
I also like the sunroof on days when it looks like I may run into some rain before I make it home, and I don't want to risk topdown.
Old May 25, 2007 | 09:52 AM
The Red Wolf's Avatar
The Red Wolf
It's not lazy- what other car even gives you this option? Zero. . . That's one of the unique features of the MINI cabrio, and one I'm sure will be copied. Full open is the best, but take what you can get- whether limited by rain, distance, temperature, etc.
Old May 25, 2007 | 02:04 PM
toomuchfun's Avatar
toomuchfun
I use the sunroof feature when the weather can't decide what it's doing, e.g. on and off rain. My bf thinks I've gone crazy, I used to want the windows up and ac/heat turned on all the time, but now I want the top down or sunroof open no matter what the temp is outside, and the cabrio's versatile roof enables me to do so!
Old May 25, 2007 | 03:47 PM
cadfael_tex's Avatar
cadfael_tex
I like it. Use it especially when I've got unsecured items I don't want to mess with but don't want to blow out.
Old May 25, 2007 | 04:10 PM
polizei's Avatar
polizei
Yup, I use my sunroof almost every time I get in my MINI.
Oh wait, I don't have a cabrio.
-Cody
Old May 25, 2007 | 05:09 PM
ScottRiqui's Avatar
ScottRiqui
It already has been. I saw an ad last week (Volkswagen Eos) that advertised itself as being the only car with a sunroof incorporated into a retractable hardtop. I'm sure that if it weren't for the MINI, they would have phrased it differently to leave out the "retractable hardtop" caveat.
Old May 26, 2007 | 12:29 PM
lilstyles's Avatar
lilstyles
I use my "sunroof" but I agree that it gets really windy with it open, can't complain though, I'm glad the option is there..
Old May 27, 2007 | 05:32 AM
Annewithane's Avatar
Annewithane
I've never actually liked sunroofs all that much. Too much noise and too windy, even with the back windows open. In the 10 months I've had the cabrio, I've probably only used the sunroof 5 or 6 times. And that was for either because of intense sun or stop-and-go showers.
I guess I'm a purist. I don't consider my 90:10 clause fullfulled unless my top is FULLY down.
Old May 27, 2007 | 06:21 AM
MINIFVR's Avatar
MINIFVR
I like that the cabrio has the retractable sunroof, despite the fact that I am a purist as well . Think about it this way- it's there if you want it (for those who aren't hard core) and it just shows that MINIs are at the forefront of advancing technology. Engineering a ragtop in a MINI while only adding about 150 lbs and maintaing rigidity is a marvel in itself! I don't see it as a negative in any way.
Old May 28, 2007 | 04:36 AM
azula's Avatar
azula
i have a question about the sunroof, can it be put down with the key? i've heard rumors
Old May 28, 2007 | 04:56 AM
rc'S's Avatar
rc'S
Yes, just like putting the top down, push the unlock button.
Old May 28, 2007 | 05:00 AM
BlimeyCabrio
....IF, and that's a big IF, this feature has been programmed / enabled for your specific car. I had to ask specifically for this feature to be enabled at delivery.
Depending on how you have the unlock feature programmed, it works something like this:
1) Press unlock to unlock drivers side (depending on programming, may also unlock passenger side.
2) If passenger side doesn't unlock on the first press, press again to unlock passenger side.
3) Press AND HOLD the unlock button for about 5 seconds. The sunroof will start to open - continue holding until it stops, then release.
4) If you want to take the top down, press AND HOLD again for about 5 more seconds. The top will start to to unlatch - continue holding until it stops.
Old May 28, 2007 | 05:09 AM
rc'S's Avatar
rc'S
It still supprises me all the options that have to be asked for. CF in Va Beach seemed to have made everything available that is available.
Old May 30, 2007 | 07:32 AM
zzMini's Avatar
zzMini
Lazy!!!!????!?
I guess no one reading this is old enough to have owned a MANUAL convertible...
I had two where top up/down was about a 15 minute commitment...and still had it down as much as possible. The MINI has got to be the easiest and quickest top out there - you don't even need to LATCH it!!
With my cabrio, if I am going to make 2 stops that are 1/4 mile apart, top goes down for each of them! (Closer than that, I walk - can always use the exercise!)
I think I have used the sunroof twice in a year. The tip someone posted about lowering the windows makes it less noisy, but with me, tends to be all-or-nothing...! I can see its usefulness as a 'second-best' , where it had been pouring when you left your garage, and now you are on the highway with no safe place to stop, and now it stopped raining...
Old May 30, 2007 | 09:11 AM
AggieMini
NEVER! I NEVER CHEAT WITH JUST THE SUNROOF! I always have my top down. Even in the pouring rain because I took my top down vows seriously.
I am totally kidding, by the way. ha ha...
HogWldFLTR
Oct 1, 2015 11:38 AM
R60SX
Sep 23, 2015 09:01 AM
KristaMcCoy
Sep 12, 2015 05:37 PM
