R52 Exhaust upgrade... installation issues with brace
Old May 13, 2007 | 05:39 AM
  #26
mistro's Avatar
mistro
this was a problem with my Borla too
  #27
acej80's Avatar
acej80
Thanks for the '06 pictures!
Looks like the parts I highlighted in the picture are different between the 05 and the 06. Or is the perspective of the pictures different enough and my eye sight poor enough, to cause an optical illusion? If that is the part that is different, then this would mean that adding the longer bolts and spacers would essentially replicate what MINI did for the 06 model year.
Old May 13, 2007 | 08:40 AM
  #28
MINIFVR's Avatar
MINIFVR
Both of those pics above are from the 06' MCSc. The only difference is that there are longer bolts and two nuts spacing the brace on the bottom one. We need a pic of the 05' (I have one). I'll try to get one up here soon. I looked at the brace the other day to see what my options were for my incoming exhaust and it doesn't appear to be too much different, if at all.
Old May 13, 2007 | 04:25 PM
  #29
acej80's Avatar
acej80
Boy did I confuse things. I thought riquiscott had an 05 MCSc, and not an 06. So ignore my post above. However I still think those brackets look different which is why I think bostoncooper didn't have to add spacers.
Old May 13, 2007 | 04:38 PM
  #30
MINIFVR's Avatar
MINIFVR
It's all good. I figured you mixed it up. Riquiscott modified his brace to accomodate a bigger space for the piping. Good thinking.
Old May 14, 2007 | 03:47 PM
  #31
MINIFVR's Avatar
MINIFVR
Old May 14, 2007 | 03:51 PM
  #32
MINIFVR's Avatar
MINIFVR
Take a look in my gallery. I posted pics of the brace from a few angles. It appears to be exactly the same as the 06' (Mine is an 05'). Looks like htere weren't any noticeable changes from 05'-06'.
Old May 16, 2007 | 06:30 PM
  #33
Intense's Avatar
Intense
252whp 200trq RMW style
The Invidia exhaust does not fit on cabrio's..... I have found this out the hard way.
Cabrio's have some under chasis bracing that was not accounted for in their design. I have sent pictures to Tom at Invidia showing the bracing and the problem. The exhuast sits directly on the bracing, in fact.. without the bracing on it would sit about 2 inches too low. When the bracing is installed it pushes the exhaust up about 2 inches causing it to sit right on the chasis and the bottom of the car causing one hell of vibration.
Right now my cars at a custom exhuast place getting some new bends so it fits correctly.
Pretty bummed out about it but I love the way it sounds and looks
....live and learn right?
I called Invidia before I bought this exhaust and was told "Yep! it'll fit both the cabrio and coupe model no problem"
Some glaring oversights indeed
Old May 16, 2007 | 06:38 PM
  #34
MINIFVR's Avatar
MINIFVR
Do you are just getting the midpipe bent a little to clear the brace? Or are you getting a new pipe completely? How much is the exhaust place going to charge for this, because I know that I'll have to have mine bent...
Old May 16, 2007 | 07:46 PM
  #35
Intense's Avatar
Intense
They couldn't just heat and bent it They had to weld a peice of galvanized bent aluminum right before the Y right above the brace. So now I have a piece of aluminum welded into my stainless steel exhaust..... The good thing is that he didn't use a crush bend so the flow isn't too impeded. They also had to heat my hangers up and bend them some to get everything to fit right.
Total cost was $150.00
Old May 16, 2007 | 07:54 PM
  #36
mistro's Avatar
mistro
Does anybody know the size and length of the bolts that hold up the braces because I am going to have to buy more washers...
Old May 16, 2007 | 07:59 PM
  #37
mistro's Avatar
mistro
MINIFVR sorry I did not respond to your first PM. I have had installed (by two master shadetree MINI mechanics, James and Lucas) a Borla Exhaust that I bought on ebay. It hit the brace. Lucas took the exhaust to a muffler shop who for $75 bent the mid pipe and fabricated a smallpiece near the Y (like Intense), but now there is an exhaust leak at the top end of the Y so tomorrow or Friday we take it back to the muffler shop to try and resolve the leak. I have a very slight rattle upon start up which I think will be handled with a few more washers since I don't have nearly the amount that the first picture has...
BTW may have a second Borla up for sale in a liitle bit... It will not be modified, but it will be around half of what a new one would cost.
Rgds, Michael
Old May 16, 2007 | 08:09 PM
  #38
ScottRiqui's Avatar
ScottRiqui
The brace bolts are 10mm in diameter. If you can't find 10mm washers, you can use 7/16", and they'll only be four-thousandths of an inch oversized.
Old May 16, 2007 | 09:39 PM
  #39
mistro's Avatar
mistro
Any idea how long the brace bolts are?
Old May 17, 2007 | 03:19 AM
  #40
ScottRiqui's Avatar
ScottRiqui
Sorry - forgot about that part of your post. The replacement bolts I used have 50mm of thread. That length should work even if you don't need as many spacers as I did.
Old May 19, 2007 | 05:33 PM
  #41
MINIFVR's Avatar
MINIFVR
I've decided to replace the factory torx bolts (which are pretty soft, and not under a lot of pressure), with 2.5'' 12-point bolts. There will be a washer and a 1'' spacer in between the black part of the brace and the silver part (for the spacing). This should look a little more solid, and even more OEM-like after they're spraypainted black.
That should do it!
Old May 20, 2007 | 09:51 PM
  #42
neilgj's Avatar
neilgj
Hmmmm...It sort of sounds like it's worth the extra $100 to get the exhaust that is designed to fit the cabrio...
Old May 21, 2007 | 06:37 AM
  #43
ScottRiqui's Avatar
ScottRiqui
Well, the longer bolts and spacers to lower the brace 3/4" only cost about $5, and if you go ahead and get them *before* you start the installation, it doesn't add any time to the install, since the brace has to be removed/replaced during the installation anyway.
Even after it's been lowered, the brace still isn't the first thing that you'd scrape, so there's no clearance issue, and after several autocross sessions on my exhaust and on the other car where I lowered the brace, I'm confident there's no issue with the extra shear loads on the longer bolts either.
If I were ordering an exhaust from a company that made a cabrio-specific exhaust, *and* the vendor had the cabrio version in stock, then I might get the cabrio-specific part. But lowering the brace is a simple mod that greatly expands your available exhaust options.
Old May 21, 2007 | 09:29 AM
  #44
neilgj's Avatar
neilgj
You're right, $5 worth of nuts and bolts is a good deal, but I was refering more to the folks who needed $150 worth of exhaust piping manipulation. I also wonder if there are compounded issues if you use a non-Cabrio exhaust and the M7 USS - or if you just need more spacers..
[Full disclosure: I bought the Milltek Cabrio exhaust and I have the M7 USS]
Old May 22, 2007 | 03:52 PM
  #45
MINIFVR's Avatar
MINIFVR
You won't need $150 of exhaust piping manipulation if you do this simple mod on the brace! Perhaps I am misunderstanding what you're saying, but this pretty much eliminates any exhaust manipulation that I'm aware of.
Old May 23, 2007 | 06:13 PM
  #46
MINIFVR's Avatar
MINIFVR
I just did the brace mod. Took me 15 minutes. Best idea for anyone looking for an aftermarket exhaust for the cabrio.
Old Oct 18, 2007 | 03:09 PM
  #47
pyrrhusmj's Avatar
pyrrhusmj
Has anyone who has done the brace mod had any issues? I did it recently and my car is feeling funny whenever I take a corner really tight or go over a speed bump. I am hoping it is just mental on my part.
Old Oct 26, 2007 | 08:07 PM
  #48
seang's Avatar
seang
Jeez ..PPL.. what length are the bolts, how many nuts, what washers????
Just get the right exhaust for the car....I have a Minspeed on my 06 cabrio..AWESOME sound and easy to install...CHEAPER.....unbolt original and the xbrace lower all parts replace with new exhaust and bolt it all back up! The new piece only weighs 25lbs!! get rid of all that dual muffler overwieght stuff for crying outloud.....30-40 min and your done! took that long for you to read all the posts about what bolts to change
Old Jan 19, 2008 | 05:59 AM
  #49
IamSMC's Avatar
IamSMC
Originally Posted by rkw
The JCW exhaust is a universal design to fit both cabrio and hardtop. It has a flattened section of pipe to clear the cabrio brace. Unfortunately for hardtop owners, the flattening isn't necessary and creates some flow restriction.
Anyone have a pix of this?
The one I've found doesn't seem to show it and it indicates "NOT FOR MINI COOPER S CONVERTIBLE"
http://www.trademotion.com/partlocat...catalogid=3751
Teh
Aug 22, 2022 04:37 AM
squawSkiBum
Oct 2, 2015 09:21 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
ASRman
Aug 13, 2015 09:33 AM
