R50/53 Whistling windshield
Old Apr 12, 2007 | 06:10 PM
89AKurt's Avatar
89AKurt
I just got my second windshield (cracked in the same spot). Used a local established glass shop. I even went to the trouble of getting clips and A-pillar caps ($65 a piece!).
Now I have wind whistling above 30 mph! Haven't had it up to 75 mph yet, am expecting something like an F-15 taking off. The top moulding doesn't look flush enough, and the corner trim was a bit loose.
Has anyone else had this problem after getting a windshield replaced? I shoulda called the first company back, even though they're not listed in the phonebook (only phone solicitation I've ever been suckered into) because there was no noise. Will it require redoing the whole thing to get it right? Will they claim I slammed the door with the windows up and say too bad?
And am I the only one, when something gets fixed, something else gets screwed up?
Old Apr 13, 2007 | 03:04 AM
NMgokart's Avatar
NMgokart
Unless your auto-drop/ auto-close feature isn't working, I'd say that was not possible! Take it back; they'll fix it.
Old Apr 13, 2007 | 03:06 AM
BillTheCat's Avatar
BillTheCat
Not uncommon, if the tech who does your glass replacement is inexperienced with MINIs. (Or with whatever model of car you bring them) If trim is visibly misaligned after the job, any stand-up, reputable shop will fix the problem for you. Should not charge a dime.
And that should oughtta stop the whistlin'.
Old Apr 13, 2007 | 07:28 AM
89AKurt's Avatar
89AKurt
That's what I thought, thanks!
Old Apr 13, 2007 | 10:00 AM
Gromit801's Avatar
Gromit801
Mine has howled from new. Only above a speed which must not be named!
Old Apr 14, 2007 | 06:55 AM
LEPRACHAUN's Avatar
LEPRACHAUN
According to my glass guy(I've had 3 windsheild put in my '04) the top molding is a problem. If not put in just right it'll become loose. All kinds of noise. And yes the glass company should redo it for free. My guy even came out and met me in a Burger King parking lot to adjust it the last time.No charge.
Old Apr 17, 2007 | 08:37 AM
ubaid1's Avatar
ubaid1
From Factory
From the factory, I've had the same problem at higher speeds, no cracked windshield, nothing, stock. Nothing has been replaced. Is there any fix?
Old Apr 17, 2007 | 09:20 AM
Jenn B's Avatar
Jenn B
Mine too... like a freakin banshee. It drove me nuts.
Old Apr 17, 2007 | 10:11 AM
Gromit801's Avatar
Gromit801
When you're driving, and the howling starts, push your hand against the upper center of the windshield, and you hear the howl change in pitch.
A very thin bead of clear silicone (use masking tape as a guide), trying to get it up under the outside molding. Then use an X-Acto knife to CAREFULLY trim the excess.
Old Apr 26, 2007 | 09:34 PM
89AKurt's Avatar
89AKurt
I had the shop work on it. I suspected the top corner pieces were the culprit, so they added some glue. No more whistling! Wish all problems could be fixed as easily.
Old Apr 27, 2007 | 10:58 AM
Grimace's Avatar
Grimace
Same problem here, '06 MCS. It will be on my list of little things to have the dealer address at first service, still only at 1900 miles.
Old Apr 27, 2007 | 02:52 PM
markldriskill's Avatar
markldriskill
Singing bonnet, humming boot, whining supercharger...
...but my windshield cannot whistle, and my steering wheel has pretty poor rhythm.
I know I should resist these urges, but it just isn't always possible. Many of my close associates have recommended therapy.
Colt45Magnus
Aug 27, 2024 05:03 AM
LifeAfterBeetle
R60/R61 Stock Problems/Issues
15
Mar 2, 2016 07:10 PM
bahman
Feb 14, 2016 10:29 AM
aldito2
Sep 30, 2015 10:44 AM
The Rossness
Sep 17, 2015 03:06 PM
