R50/53 Flapping Noise from front driver side wheel???
Old Mar 5, 2007 | 06:57 PM
TaylorL99's Avatar
TaylorL99
Alright....i have a 2004 MCS about 43000 miles. There is a horrible flapping noise coming from the front driver side tire/wheel...The flapping noise will speed up when you speed up and slow down when the car slows. I can't drive with the window down without it aggravating me . I took the tire off and looked around and cleaned some brake dust off thinking this would fix/reduce the noise...no...this actually caused the noise level to increase. I spun the wheel when it was jacked up and my couldnt hear anything....the tire has no defects that would cause the noise so i'm at a loss . Any ideas what this is or ways to fix it?
Old Mar 5, 2007 | 07:40 PM
AudioNToxication's Avatar
AudioNToxication
Did you do a very careful inspection of the tread area for rocks or nails that have managed to get stuck in there. Sometimes those can make noises and not cause the tire to lose air.
Old Mar 5, 2007 | 08:03 PM
TaylorL99's Avatar
TaylorL99
i did inspect it carefully and cant find anything :( ... would that affect runflats without the sensor catching it?
Old Mar 5, 2007 | 08:21 PM
AudioNToxication
the sensor only kicks in once the pressure drops like 10% or something like that, if the nail/screw went in and stayed in the tire may not be losing any air so no low pressure light. Also did you check and see if the plastic on the A pillar is loose, that could make some noise.
Old Mar 5, 2007 | 08:22 PM
TaylorL99's Avatar
TaylorL99
i have to take it to the dealer soon to replace the (flywheel)? bc of a clicking noise in the engine so i guess ill see what they say..i just wanted some idea of whats going on before i take it
Old Mar 5, 2007 | 10:41 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I had a noise like this when I had brake dust covers on the rims. After my brake job, I didnt need the covers so the noise is gone.
Old Mar 6, 2007 | 03:46 PM
TaylorL99's Avatar
TaylorL99
no brake dust covers here
Old Mar 6, 2007 | 06:41 PM
ozarkroots's Avatar
ozarkroots
Coordinator :: Mini's of the Ozark Region
Flapping noise in front
There is another possibility and that is a seperated tire tread. This would not necessarily be apparent by looking at it.
Try this: swap the front tires and see if the noise moves to the other side.
If it does then a seperation may be the source . On the other hand if it does not then try plan "B". No I don't know what plan "B" is.
Good luck!!
maestro39
Oct 27, 2015 02:38 PM
cm.d
Aug 19, 2015 08:51 AM
Minibeagle
Aug 13, 2015 10:00 AM
messyjesse96
Aug 12, 2015 05:51 AM
