R50/53 Cost of front brakes
MINI front pads are what $45? And the rear are almost the same. So they are charging you what 8/hr of labor?
And I could of swore pads are part of the maintence on the car in your under 36k miles.
40,ooo miles. That $540 includes pads, turning the rotors and a test drive.
OK I knew that was a F U price. But what should I expect for a the job at a good mini shop?
Chris what are you talking about? Who told you that one? O' your MA right!
Dealer prices are just insane. You can get OEM rotors and pads for less than $250 all around. So $750 is service... that is crazy and I hope that is not the norm or I am in trouble.
That did not even include new rotors? But turning them... wow...
Prices on OE BMW/MINI brake parts have gone up drastically in the past few years. MINI front pads are $75 MSRP (at least according to Pelican Parts), and the rotors are about $80 MSRP each. Add another $20 for a wear sensor. That's over $250 MSRP just for the fronts.
Now is a great time to:
1. Buy aftermarket OEM size rotors (front and rear)- $220
2. Replace old pads with low dust pads- $120
3. Pay a local shop or get a friend to install- $ ?
Never pay the outrageous dealer prices for anything; the only time you need to go to the service shop is for warranty and recalls.
Update: the $540 did include new rotors. Well if the parts after market are $250 then $540 is not far off the mark for the dealer.
How much more for the JCW brakes installed?
On Saturday I literally paid $95 ($80 + $15 tip) to have my front brakes and all lines done by an off-duty MINI tech from the dealer. He installed:
- StopTech slotted rotors
- Axxis pads
- StopTech ss lines
- full bleed & fluid swap w/ ATE Blue
Parts?
- Rotors, $95 ea. for slotted (StopTech)
- Pads, $99 for Axxis Ultimate Street - Hawk HPS out of stock (StopTech)
- SS Lines, $130 for all four (StopTech)
- Fluid, $9.95 x 3 (RaceShopper)
- Wear sensor, $22.00 (Dealer part)
Not freezing in my garage while doing the whole deal? Priceless....
Seriously though, for stock parts (and turned rotors) that price seems really high. If you are able to continue using the rotors then the whole deal should run maybe $200 depending on labor rate and parts pricing.
Personally, I did pay a bit more getting the parts straight from StopTech. But their service is great and one stop shopping is convenient. I bought the fluid at RaceShopper, excellent place that I recommend highly.
JCW brake kit installed is about $1400-1500 depending on dealer labor rate. I think the kit hovers right around $1K if memory serves correct and ~4 hours to install (1 hour per wheel).
- Axxis pads
- StopTech ss lines
Parts?
that was $250 for font and rear parts... but the OEM are even cheaper in the rear than the front so probably $175 for parts for just the front.
A local BMW shop (non-dealer) said that they would charge 8 hours of labor @ $72 and hour + parts. BUT I may have been mistaken on the labor time... I thought he said 8 hours but
that seems really high and I did not fully understand what he was saying. He was trying to say either 1 hour per axle or 2 hours per axle, I could not understand him. I will have to confirm because
that is a large discrepancy
Rawhyde
Although doing brakes is rather simple, don't attempt it if you do not have experience or do not have someone with you who has significant experience working on brakes. They are such critical safety components that they need to be 100% perfect. I know how to do the job and I still pay my local independent BMW mechanic to do brakes.
[/quote] JCW brake kit installed is about $1400-1500 depending on dealer labor rate. I think the kit hovers right around $1K if memory serves correct and ~4 hours to install (1 hour per wheel).[/quote]
Actually, you can get a new set of JCW brakes for around $850.00 on Ebay from Morristown Mini
But I'm paying about $525.00 to have them installed.
Chuck
Chuck
I'm sorry, but unless you are a total clutz, or just don't want to do something mechanical yourself, doing a brake job.... assuming you can read instructions is very straight forward and very simple and easy.
I'm not knocking anyone who does not want to do these jobs, or someone who does not have the tools or an appropriate place, such as a dry garage. But if you want to save money, doing it yourself is a very viable option. Teach yourself how to do it by reading and asking questions. Make a list of what to do and what tools you need. Buy that stuff. Then have at it. Every person on this forum who knows how to do something is chomping at the bit to share their talent and knowledge.... use them.
It will be a lot easier than you think and you will gain a ton of satisfaction in having done something like this for yourself. I personlly would drive my MINI off a cliff before I would pay someone some of the prices quoted on this thread. Ridiculous
If you do it yourself, then you know exactly how it was done, (hopeful correct). You know that no shop monkey abused your car while it was in there hands. You know that no one slammed your door into that floor jack or a brick wall, or stuck a screwdriver through your leather seat because they forgot it was in their back pocket. Of got grease all over your seats of carpet... etc.
I appologize for my rants, and truly do not intend to offend anyone.
YD
YD
BEATNUT
In the old days of drum brakes, there was a bit of an art getting all the bits and pieces back in the right place doing the right thing. Discs? Piece 'o cake. As long as you're not breaking into the lines, it's tough to do it wrong. Get the parts, read the instructions, take out the old and put in the new (do one side at a time so you have a static example) and you're all set. Really the most important thing to remember is to reseat the pistons (aka pump the brake pedal) after everything is back together.
Of course, if you're not comfortable doing the job, have a friend help, or just leave it to the pros.
Its not a dealer but an independant BMW mechanic.
BEATNUT
Not $540.
