R50/53 Things You Didn't Know About Your MINI
Old Aug 1, 2010 | 10:07 AM
  #1826
jimzbobs's Avatar
jimzbobs
Hmmm. Never knew about this problem. Just wonder is this isolated for the S only or both base and S
Old Aug 3, 2010 | 06:34 AM
  #1827
AllBlack05S's Avatar
AllBlack05S
Originally Posted by adele
I currently have my '05 Mini S with sunroof at the dealer after the discovery of water in the battery box located in the boot of the car.
The BST cables (trunk - front bay), and the battery fuse box located in rear of car must be replaced. This all started when the airbag light started showing up on the display panel. NAM had a series of water in battery box situations mentioned in March '09 related to the '03-'05 Minis. If anyone knows what is causing this, please share. Poor design of the hatch to seals around tail lights and the possible plugged drain channels from the rear sunroof have been mentioned as possible causes. As of now, I am still investigating the options. If anyone has had this problem and found a solution, please share.
Its the hatch handle gasket, which is available by itself for a few dollars from the dealer. All you need is it some goof off and a t-20 or t-25 torx screwdriver (don't remember which but you need both for these cars so may as well get both.) The gasket dries up and shrinks over time but at least it's a cheap fix
Old Aug 3, 2010 | 08:30 PM
  #1828
ToBFree's Avatar
ToBFree
On my '02 I replaced the rear hatch handle because the license plate light contacts had corroded away. I discovered the gasket had been leaking in a couple spots. It's an easy replacement (gasket or the whole handle). The hatch handle can be purchased ready to paint to match your body color or in chrome (which I did because I was lazy that day).
Another gasket to watch out for is the 3rd brake light. When it starts to leak you'll start getting water drips down the inside of the boot window. That was a good day to install the clear/LED 3rd brake light I always wanted.
Be careful on both jobs as the wiring isn't all that long as I remember it.
Lastly, keep your eyes on your sunroof drains when you wash your MINI. You should always see water dripping out of the two plastic outlets in the boot hatch jamb which is where the rear corners of the sunroof drain. The two front corners are connected by hoses to metal tubing that runs down the A pillar and drains out behind the front wheels. I had one front hose slip off the tubing which resulted in a pool of water at the front passenger footwell. It can be slipped back on after removing the subroof trim, reaching in between the headliner and roof with a long pair of needlenose pliers and some patience. I used a small paint brush to dap some door gasket adhesive on the tubing to ensure it didn't slip off again.
Oh, to own an '02 and experience all of the issues a MINI could have. But my new '10 is a blast daily driver and gives me time to pamper the '02 again.
Old Aug 12, 2010 | 09:28 PM
  #1829
Un0RiGiNaL's Avatar
Un0RiGiNaL
Old Aug 13, 2010 | 12:31 AM
  #1830
MotorMouth's Avatar
MotorMouth
Originally Posted by Un0RiGiNaL
DID YOU GUYS KNOW
IF YOU HOLD YOUR UNLOCK BUTTON before you get in the car, both of your windows will automatically come down?!?!?!?
soo nice.. before i get in the car i can roll the windows down now..
both doors have to be unlocked before that works. So if the car is all locked up - press once, press twice, press third time and hold.
Old Aug 13, 2010 | 01:13 PM
  #1831
Suzanne's Chili Red S's Avatar
DID YOU GUYS KNOW
IF it's programmed by the dealer to do that. Some are and some aren't.
Old Aug 13, 2010 | 01:52 PM
  #1832
Wetworth's Avatar
Wetworth
I'll be honest, I did not know an A/C compressor costs $1800...
Old Aug 13, 2010 | 06:57 PM
  #1833
ToBFree's Avatar
ToBFree
Funny, I walk up to mine when its all locked up, press and hold, the windows come down which is followed thereafter by the sunroof opening. It came that way. I still need to invest in an auto-up though as I miss that.
Old Aug 17, 2010 | 07:36 AM
  #1834
DaveVT02S's Avatar
DaveVT02S
DID YOU GUYS KNOW
Mine isn't programmed that way (yet) - the only "convienience feature" I have in that regard is inserting the key in the driver's door handle, turn clockwise to lock, hold and wait a second and the windows roll up and the sunroof closes - good for when a rain shower blows in suddenly...
(p.s. - doesn't work to go down, just up)
Old Aug 31, 2010 | 10:52 AM
  #1835
SeanKidd's Avatar
SeanKidd
Originally Posted by Rodger
Thank-you for your reply. I did figure out how to get to the battery after I had made my post. Boy did I feel stupid. I diconnected the fan as you suggested and will attemped the change next week. I found the new fan assembly for $250. after tax. My dealer wanted $875 for parts and labor.
My mini has 66 k on it and this is the first big problem. My dealer also wants another $875 for the 65K service of the car. If you have any suggestions on where to get info on what all should be done for this service I could use the advice. The dealer said oil and filter change , belt replacement ect ... but not plugs, I guess they last until around 100K.
Again Thanks for all your help
What will reall get your boot is that the 1st stage fan failure is caused by a $15 resistor...
Old Aug 31, 2010 | 11:56 AM
  #1836
Keyser_Soze's Avatar
Keyser_Soze
They don't, except from BMW...
Old Sep 1, 2010 | 09:09 PM
  #1837
DixonL2's Avatar
DixonL2
On the water and hatch handle issue, I posted a waterproofing how to a while back. The switch can corrode and open the hatch all on its own...
https://www.northamericanmotoring.co...elf-fixed.html
Old Sep 11, 2010 | 03:06 PM
  #1838
MiniKar's Avatar
MiniKar
I just discovered that when you push the lock button on the key fob, it locks the gas cap on the MCS.
At first I thought my cap was broken ................................. Now I know
Nice design !!!!!!
Old Sep 30, 2010 | 11:08 PM
  #1839
bfromhold's Avatar
bfromhold
After buying my 2006 MINI new four years ago, I just recently found out that the top bulb in the taillight does nothing! Apparently, the top bulb in the lens was for a fog light in the Europe MINIs. In the U.S. models, the bulb is there but doesn't illuminate. Now, I just need to find info on how to convert this to another brake light. I hear there's an easy way to change this.
Old Sep 30, 2010 | 11:13 PM
  #1840
OctaneGuy's Avatar
OctaneGuy
I posted this DIY in October 2003.
http://www.littlemini.us/technical/brakemod/index.asp
Original Thread when NAM was still called MCO.
https://www.northamericanmotoring.co...-mod-pics.html
Old Sep 30, 2010 | 11:14 PM
  #1841
joe_bfstplk's Avatar
joe_bfstplk
It can be as easy as jumpering a diode or straight wire across the plug that plugs into the back side of each tail light. I used a diode since I had some around. I also swapped out the bulbs for LED bulbs in the foglight sockets.
There *is* a how-to on here about it somewhere if you search a bit....
HTH!
C ya,
Dutch
Old Oct 1, 2010 | 10:41 AM
  #1842
rkw's Avatar
rkw
Hi, I saw your post in the other thread and replied there as well. In a 2006, the top bulb is the turn signal. Do not apply this jumper mod on your taillight. You can do a brake light mod for the 2006 rear fog in the bumper, but in the other thread you said you've already done that.
Old Oct 4, 2010 | 09:04 AM
  #1843
DaveVT02S's Avatar
DaveVT02S
Maybe someone 'retro-fitted' the first series lights?
A quickie / plug-in set-up, available for either/or (shows the diff light set-ups, too)
http://www.gominigo.com/BLK-MINI.html
Old Nov 8, 2010 | 08:05 PM
  #1844
edgy's Avatar
edgy
I also found my vin under the rear license place holder.
Old Dec 3, 2010 | 06:50 AM
  #1845
fishbone's Avatar
fishbone
Is the internal cigarette lighter still powered when the ignition is off and the key is out? I ask because we have 2 heated cushions for our seats and I want to make sure I don't kill the battery. I have left them on overnight and they were cold in the morning and the battery was fine. The manufacturer of the cushions we have now indicates you should unplug them when not in use but the red powerlight does go off on the plug. I'm 99% sure they don't use any power when the car is off but I am not sure if the Mini continues to supply power or not.
Old Dec 3, 2010 | 07:44 AM
  #1846
ericfreeman's Avatar
ericfreeman
No, the front power socket goes off with the ignition. I have my radar detector plugged into the socket in the console and it turns on and off with the key switch. I don't know about the trunk socket though....
Eric
Old Dec 3, 2010 | 08:17 AM
  #1847
LRogers's Avatar
LRogers
The rear power outlet is also only under power when the ignition switch is on.
Old Dec 3, 2010 | 08:26 AM
  #1848
edgein's Avatar
edgein
And I'll bet they tell you to unplug them for liability reasons, not because it might drain the battery.
Old Dec 3, 2010 | 05:45 PM
  #1849
fishbone's Avatar
fishbone
Great! One less thing to worry about
Old Dec 18, 2010 | 12:52 AM
  #1850
Tomas_siba's Avatar
Tomas_siba
thanks guys, im a new owner of an 05 MCS and this thread really helped out cheers
