R50/53 Things You Didn't Know About Your MINI
Old Jul 24, 2009 | 10:00 PM
  #1626
Btwyx's Avatar
Btwyx
Originally Posted by Rodger
now I can't acess the hatch to reconnect the battery.
Does your's have the jumpstart terminals under the bonnet? Could you give it a jump to be able to unlock the boot?
Old Jul 25, 2009 | 06:37 AM
  #1627
Rodger's Avatar
Rodger
Thank-you for your reply. I did figure out how to get to the battery after I had made my post. Boy did I feel stupid. I diconnected the fan as you suggested and will attemped the change next week. I found the new fan assembly for $250. after tax. My dealer wanted $875 for parts and labor.
My mini has 66 k on it and this is the first big problem. My dealer also wants another $875 for the 65K service of the car. If you have any suggestions on where to get info on what all should be done for this service I could use the advice. The dealer said oil and filter change , belt replacement ect ... but not plugs, I guess they last until around 100K.
Again Thanks for all your help
Old Jul 26, 2009 | 05:19 PM
  #1628
ToBFree's Avatar
ToBFree
In the thread at https://www.northamericanmotoring.co...-problems.html I posted a link to a photo set I took when I replaced mine the first time. If you search some of the threads for cooling fan issues you will find some more information.
I don't know of a step by step instruction write up anywhere, but the jist of it is to disconnect the battery, leave the boot OPEN, remove the bumper cover, unhook all the lights in the cover, bumper, loosen the plastic shroud that supports the radiator and A/C coil, unhook the top radiator hose, let the radiator slip forward a little, setting the coil on a small chair or box (or suspend it from above if you're in a garage with trusses or the like) until you can reach behind, unclip the fan assembly and slide it up and out. There are numerous bolts, clips, and such to undo including breaking the wheel wells from the front plastic housing. Two useful tricks are removing the upper hose quickly and bungy it up to the bonnet so you lose little coolant. Second is the undo the bracket at the plug connection I spoke of so the A/C coil lines are loose allowing the coil to rotate out and to the driver's side of the vehicle.
The worse of it is trying to hold onto everything that's loose but not removed without accidently raking a hole through the coil or radiator. Take you time, it isn't too bad. Also, there are two silver bolts behind the bumper cover with large, deep, washers. Leave these in place as they are the alignment dogs for the assembled front components. Everything will go back into place properly when you set them back over those two points.
On the subject of the second inspection, the Owner's Manual lists all the work to be completed under the Inspection II.
Old Aug 2, 2009 | 01:39 PM
  #1629
Blainifer's Avatar
Blainifer
Originally Posted by Dave_in_Va
Anybody else noticed this? When using the cruise control, when you accelerate using the + button (for the cruise) if you let off the button at the desired speed, the car will actually go 1-2 mph over that speed, and then come back down to the desired speed. It's pretty cool, especially if you are using the cruise control to pass someone.
I'm not sure if this is a problem or a commonality:
When I'm going up a hill (not even a steep one) my cruise won't hold speed. It dips down to as much as 5 mph below where it's set.
When I'm going down a hill (again, not necessarily steep) it will accelerate as much as 5 mph.
Maybe conserving gas mileage by decelerating?
Maybe it sees opportunities to speed up without using more gas?
Is my car, in fact, smarter than i am?
Old Aug 2, 2009 | 02:30 PM
  #1630
Blainifer's Avatar
Blainifer
Originally Posted by erickvonzipper
What in Taco Bell could possibly make your a$$ feel like it's on fire?
Zip
I know this post is from 07.
But I'd say all of their food usually gives that sensation.
It certainly isn't Taco Bell's seat warmers.
Old Aug 3, 2009 | 03:18 PM
  #1631
Goldilocks's Avatar
Goldilocks
storage shelf under car?
Originally Posted by MUShadd
Well the rumor about the storage shelf under the car to hide your keys....absolutely true. Excellent for stashing your keys if you get out at the park to do some running.
Is this a joke or is there really a storage shelf under the car to hide your keys? where is it?
Old Aug 4, 2009 | 05:22 PM
  #1632
nickheart's Avatar
nickheart
Feature?
Originally Posted by Rubino
My 03 MCS Radio refused to play any station with Country Music. British Snobbery I think
How do you enable this feature, dealer reprogram???
Old Aug 5, 2009 | 09:45 AM
  #1633
ZCCROW23's Avatar
ZCCROW23
Gotta love the folks from Cali.
Old Aug 5, 2009 | 12:27 PM
  #1634
Minut's Avatar
Minut
I haven't seen any posts from anyone indicating they were from Columbia.
Old Aug 5, 2009 | 12:36 PM
  #1635
ZCCROW23's Avatar
ZCCROW23
LOL.
Old Aug 17, 2009 | 07:41 PM
  #1636
moreorless's Avatar
moreorless
I just found........
those little lights in the interior door opener pull wells.
Very cool.
Old Aug 19, 2009 | 09:12 AM
  #1637
DaveVT02S's Avatar
DaveVT02S
Feel around under the sill by the rear wheel arch. Note: NOT for drivin' around 'hide-a-key' use...
Old Aug 19, 2009 | 09:19 AM
  #1638
carjoy's Avatar
carjoy
Call me a skeptic or a pessimist if you will, but I have to wonder... is your key really safe there now that the location has been spread over the internet? I know I will not be using this 'convenient' feature.
Old Aug 19, 2009 | 11:27 AM
  #1639
DaveVT02S's Avatar
DaveVT02S
Yeah, me neither, but I'm a little more paranoid about security than the average person.
The first place I saw it was "The Unofficial MINI Cooper Owners Manual"...
Old Aug 23, 2009 | 12:36 PM
  #1640
Niziex's Avatar
Niziex
More of a question i guess
What is this? no air comes out of it, but it has vents, all pics I have seen of them removed there is nothing under them. I have searched long and hard before posting perhaps someone else knows!
Old Aug 23, 2009 | 12:41 PM
  #1641
bratling's Avatar
bratling
Super Moderator
If your car has the security system, this will have a microphone (to detect the sound frequency of breaking glass). If you don't have the security system, it's pretty much useless.
You can look inside it, if you want. Stick a flathead screwdriver under the edge and gently pry the cover off. Work one side, then the other; once the clips are mostly free you can pull it down with your fingers.
Old Aug 23, 2009 | 12:44 PM
  #1642
Niziex's Avatar
Niziex
tear*
Grabbed a screwdriver and went out into the 100degree garage to find out (its driving me nuts)...
Found an empty space lol!
owell!
Old Aug 23, 2009 | 12:58 PM
  #1643
irieman's Avatar
irieman
I believe this is the location where they put the Motion Sensor, when you have the OEM alarm option installed. (Oh, and a lot of people don't know this...[video, PG-13])
Old Aug 23, 2009 | 01:59 PM
  #1644
call it spade's Avatar
call it spade
It's also used for navigation. (Sits right under the antenna.)
Old Aug 23, 2009 | 02:14 PM
  #1645
rgc0233's Avatar
rgc0233
or for your secret stash? BTW, finally took the covers off and tried out my driving lights. They do only work when Hi-beams are on. What innovative engineering!
Old Aug 23, 2009 | 06:00 PM
  #1646
Mini2Go's Avatar
Mini2Go
Coordinator :: Pitt Stop MINI
Redundant response. I Didn't see the question was already answered.
Old Aug 23, 2009 | 08:57 PM
  #1647
rhcp4life's Avatar
rhcp4life
in my 03 when you open the glove box there is a pen holder, in the little compartment on the glove box door...
Old Aug 27, 2009 | 01:24 PM
  #1648
fishbone's Avatar
fishbone
This might qualify as one of those "didn't know about the Mini" or it might be issues I am having.
2006 MCS auto. I lock the car, but the P (for park) on the transmission selector (PRND) stays illuminated for a few minutes afterwards.
The engine temperature gauge never seems to start from the lowest setting. Is it because it is summer? It's always a bit above the cold mark and yes, this is with a car that sat undriven overnight or more. Never had a car do this before. Normal driving temp is right smack on the middle mark.
Old Aug 28, 2009 | 04:43 PM
  #1649
Suzanne's Chili Red S's Avatar
All normal. I think the temp gauge's lowest setting (chrono pack) is somewhere around 30 degrees, so yes in the summer it will be above that.
Old Aug 28, 2009 | 07:02 PM
  #1650
flamingvictory's Avatar
flamingvictory
Certainly not the "sauce".. Could be the age of the meat.
