R50/53 Things You Didn't Know About Your MINI
Old Jun 13, 2007 | 07:54 AM
  #851
mauberley's Avatar
mauberley
I think that's a new feature of the R56 model. If you fold down the rear seats, you'll see the catches for the seat locks exposed. You can actually rotate those to expose catches that are extended a few inches from the normal position; that allows the seats to be re-locked in a more upright position as he described.
Old Jun 13, 2007 | 10:11 AM
  #852
ASC's Avatar
ASC
Ah, thanks. Didn't think to look at his signature - he definitely has an '07. I guess I'll just have to live with folding down the seats.
- Al
Old Jun 13, 2007 | 11:04 AM
  #853
dennisd63's Avatar
dennisd63
You guys got it right..those are the ones! Sorry Al...I'm a new MINI owner, so I'm still sorting out differences between the years! Yet another cool little idiosyncrasy of the car!
Old Jun 16, 2007 | 08:39 PM
  #854
minimanmini's Avatar
minimanmini
can you access the boot from the rear seats cooper 2006?
Originally Posted by Rawhyde
The key recharges its transmitter when it's in the ignition switch on 05 and newer.
The UNLOCK button when held in will roll down all the windows and open the sunroof unless it has been de-activated.
The glovebox is refrigerated.
When you initially turn on the headlights, they'll be on low beam regardless of how they were when last turned off. The foglights are likewise off.
The controls on the automatic A/C are shaped like the MINI wings.
The annoying self-locking doors can be de-activated.
Daytime running lights can be programmed on or off per the owner's wishes.
When you activate the defroster, the rear defroster comes on as well.
There is a "pull ring" tucked under the rear seat to open the boot if there is an electrical failure.
There is a little toolkit included with the MINI.
There is a little tool to manually close the sunroof in case of an electrical failure.
The interior lights (or any other accessory) switches off after 15 minutes with the key off to prevent killing the battery.
The brake lights don't work without the key in the ignition.
The radio may turn off when you turn the key off, but you can turn it right back on without the key in the ignition.
The rear parcel shelf is designed to rest right behind the front seats upside down when it is removed from it's normal place.
There is an emergency release for the fuel door in the portside storage cubby hole in the boot.
All wipers can be lifted off the windshields, and they'll stay in the up position to keep them from freezing to the glass.
If parked with auto wipers ON, they'll be OFF when you start the car the next time. You must turn them off then back on to use them. (In case the wipers freeze to the glass)
Are these the types of odd facts you were looking for?
Rawhyde
Old Jun 20, 2007 | 06:15 AM
  #855
Dave_in_Va's Avatar
Dave_in_Va
Anybody else noticed this? When using the cruise control, when you accelerate using the + button (for the cruise) if you let off the button at the desired speed, the car will actually go 1-2 mph over that speed, and then come back down to the desired speed. It's pretty cool, especially if you are using the cruise control to pass someone.
Old Jun 20, 2007 | 06:26 AM
  #856
CooperGear's Avatar
CooperGear
From: Greater Chicagoland. Ich Bin Ein Midwesterner!!!
Cruise control to pass someone... Will the cruise control downshift and then upshift when the person is a tiny little speck in the rear view mirror? I was unaware of this
By the way, GREAT color choice!
Old Jun 20, 2007 | 08:48 AM
  #857
mauberley's Avatar
mauberley
I'm guessing the cruise control is a bit underdamped so that you won't feel a lurch when you do what you've described. The 1-2 mph excess is just inertia.
Old Jun 20, 2007 | 01:27 PM
  #858
minimic's Avatar
minimic
when you turn the car off, take the key out of the ignition and open either of the doors, the windows will come down slightly (like in a convertible). when you close the door, the window will go up to the original position.
if you want to crack your windows (say on a hot day) and don't want the window to come down a bit more, just crack your windows and take the key out of the ignition. when you open the door, the window will stay in its current position.
Old Jun 21, 2007 | 06:52 AM
  #859
Louispup's Avatar
Louispup
There's also a little MINI logo right next to the no wine glass graphic.
I did notice that the fabric below the rear seats blends in perfectly (pretty darn close) to the fabric covering on the rear parcel shelf, when the shelf is lowered to the the cargo area position.
Old Jun 21, 2007 | 11:31 AM
  #860
minimic's Avatar
minimic
Rawhyde
i have an '06 RG MCSa and this did NOT work.
guess mine is de=activated.
Old Jun 21, 2007 | 11:36 AM
  #861
Loony2N's Avatar
Loony2N
When rotating through the display options for the window in the tach, when you get to the one that displays MPH, at first it appears in the smaller font window. After a second or so, it moves up to the large font window. I wish there was a way to keep it in the lower window.....
Old Jun 21, 2007 | 12:16 PM
  #862
MotorMouth's Avatar
MotorMouth
hi lynnEl,
this is the first gen thread
Old Jun 21, 2007 | 12:18 PM
  #863
Loony2N's Avatar
Loony2N
Originally Posted by MotorMouth
hi lynnEl,
oops.
Old Jun 23, 2007 | 01:35 AM
  #864
X Skydiver X's Avatar
X Skydiver X
In reference to holding the unlock button to roll down windows...
I didn't think mine did it either...but I realized I have to hit the unlock button once to unlock the car, and then press it again and hold it down for a few seconds and it will then start to roll the windows down after about 3-5 seconds. Perhaps it might work for you then...?
Old Jun 23, 2007 | 03:11 AM
  #865
umberto's Avatar
umberto
'04 MC with the automatic AC:
I usually run it in manual mode and when the AC is off, if you turn the blower completely off, you still get a little flow of air at the temperature that was set in the little display.........but what I just noticed is that if the AC is on, in manual mode, and you shut the blower all the way down to off, it shuts off the AC too....and then if you push the AC button to on, the AC comes on and automatically bumps up the fan to the first position as it realizes that the system does not want the AC system on without the fan running....why I wonder?
Old Jun 24, 2007 | 02:46 PM
  #866
Bobbyn's Avatar
Bobbyn
you can leave the car running with the air on....slip the key out of the fob....lock the door and come back to a cool car.. )
bob
Old Jun 24, 2007 | 03:25 PM
  #867
daffodildeb's Avatar
daffodildeb
Careful--that's illegal in a lot of places.
Old Jun 24, 2007 | 05:35 PM
  #868
Bobbyn's Avatar
Bobbyn
thanks deb....i'll be careful )
bob
Old Jun 29, 2007 | 04:57 AM
  #869
diabolik!'s Avatar
diabolik!
Did anyone else's car come with the MiniFini cup holder? I special ordered my car, and it had the cup holder installed when I picked it up. I've had my car for 3 years and I just found it that its an aftermarket part. I'm curious if Mini started including these with new cars (perhaps because of complaints of small cupholders), or if my dealer just threw it in just to be nice...
Old Jun 29, 2007 | 05:56 AM
  #870
mauberley's Avatar
mauberley
The later models came with an OEM cupholder--the one that mounts higher up on the downtube, right around the environmental controls on the passenger side (see http://www.outmotoring.com/mini-coop...p-holder.html). The MiniFini cupholder mounts lower (see http://www.minifini.com/ShopDetail.aspx?id=5).
Old Jun 29, 2007 | 12:48 PM
  #871
diabolik!'s Avatar
diabolik!
thats the one my car came with. I guess it was just me?
Old Jun 29, 2007 | 01:33 PM
  #872
mauberley's Avatar
mauberley
Could be. I certainly didn't get one.
Old Jun 29, 2007 | 05:37 PM
  #873
Insomniac's Avatar
Insomniac
Originally Posted by Jimbo
You can counter rotate the rear view mirrors so that the mirror faces the ground....a nice feature to rid the mirror housing of water when washing to prevent it from blowing all over the side of the car after laborously drying what you thought was every last drop of water from your MINI!
Can someone elaborate on this? I went outside and tried to turn the mirror, I can sorta see how it works, but I'm afraid to break something
Old Jul 5, 2007 | 07:02 AM
  #874
Louispup's Avatar
Louispup
If you want to turn off your heated seats, a nice way to quickly know how many times to punch the heated seats button is to look at it. Two lights, tap it twice. Single light, hit it once.
Comes in handy when detailing too.
Old Jul 6, 2007 | 03:14 PM
  #875
Rubino's Avatar
Rubino
My 03 MCS Radio refused to play any station with Country Music. British Snobbery I think
