R50/53 Mini noise in the snow??
Old Feb 16, 2003 | 06:48 PM
MJC1880's Avatar
MJC1880
My car makes this kind of grinding noise in the snow when i reverse or do a u-turn.. or when i make a turn from a complete stop...Is it my tires...i have performance 16inch tires.....dont know what it is cant be the brakes grinding it a new car....anyone have this problem??
Old Feb 16, 2003 | 07:53 PM
Sarcux's Avatar
Sarcux
You sure you're not braking when you hear it? ABS makes a funky grinding noise.
Old Feb 16, 2003 | 11:25 PM
Blackbird's Avatar
Blackbird
drove home tonight when the snow just started to fall in jersey and experienced the same problem --- not sure what it is. had abs grind system when stopping, then when turning grinding problem as well when not applying the brake. same when in reverse. what is this? only happens in snow & i am familiar with abs kicking in & hearing the grinding noise... does the same apply when turning even though not applying brake??
Old Feb 17, 2003 | 06:58 AM
rataha's Avatar
rataha
I believe you are hearing the DSC operating. quite similar to ABS noise
Old Feb 17, 2003 | 12:09 PM
Blackbird's Avatar
Blackbird
ah ... thank you thank you
Old Feb 17, 2003 | 12:23 PM
jsun's Avatar
jsun
It ought to be pretty obvious if it's the DSC...look for the yellow triangle light (at the bottom of the tach face) to be on. In my experience, the DSC light always comes on when the ABS works (i.e., the DSC and ABS work in conjunction). So, if you don't have the yellow light, and still hear the grinding, you probably have some other problem and it's NOT the ABS/DSC you're hearing.
Old Feb 17, 2003 | 12:56 PM
GBMINI's Avatar
GBMINI
Might it simply be all the snow filling the wheel wells ... I wonder how my wheels manage to turn at all sometimes after driving home in this latest snow storm.
Old Feb 17, 2003 | 01:23 PM
Blackbird's Avatar
Blackbird
i figured it was snow in wheel wells, but was worried it might be something different just because it is a new car & i worry about every little noise lucy makes!! i do have the dsc on my car, but as of yet i have NOT seen a flashing yellow triangle in any driving condition, so i'm going to right now assume it was this massive amount of snow in my wheel well and if the problem persists i'll take it to the dealer!
Old Feb 17, 2003 | 01:49 PM
jsun's Avatar
jsun
If that's what it is, imagine how much worse it would be if you had the 17" wheels
But hey, try to stay off the roads if you're running the performance tires in this snow. DSC, ABS, lucky jesus on the dashboard...nothing subverts the laws of physics; and with performance tires on a day like today you might as well have skis on the car. Be safe.
Old Feb 17, 2003 | 02:00 PM
xpcdoojk's Avatar
xpcdoojk
I am betting on the fact that your tires are spinning and locking up and your MINI is trying to protect you with DSC and ABS.....
jc
Old Feb 17, 2003 | 02:54 PM
rataha's Avatar
rataha
also if you are driving in the snow you should see that DSC light flashing like crazy at leat in 1st and 2nd gear. I am surprised you have never seen it.
Old Feb 17, 2003 | 04:29 PM
Blackbird's Avatar
Blackbird
i have never seen it, and it's definitely on.... strange... and i do have the 17 inch tires!
Getrieben
Sep 12, 2024 07:03 AM
maestro39
Oct 27, 2015 02:38 PM
ludedude
Aug 10, 2015 07:16 PM
IstanBucket
Aug 8, 2015 02:25 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
