R50/53 Who changes their own oil?
Old Sep 30, 2005 | 02:07 PM
coopercrazy's Avatar
coopercrazy
How easy is it?
Anything special worth noting?
Old Sep 30, 2005 | 02:18 PM
MGCMAN's Avatar
MGCMAN
Easy? yes for the minimally competent DIYer. You will need one special tool, a shallow 36mm socket.
Get some ramps, the aforementioned socket for your ratchet, superior synthetic oil and a filter from your dealer. Piece of cake.
Old Sep 30, 2005 | 02:19 PM
fishey72's Avatar
fishey72
it is very easy IMO. The only special tool you need is the 36mm socket for the oil filter.
See the following for pics and such
https://www.northamericanmotoring.co...ead.php?t=4928
Old Sep 30, 2005 | 02:21 PM
MadHatter's Avatar
MadHatter
easy....
here is one of many how to's
http://www.tech-esq.com/MINI/MINIOilChange.htm
two pointers
1) the 36mm socket from Sears works for the oil filter head
2) the spring loaded filter housing can be a little tricky... just be patient.
Let's Motor
Old Sep 30, 2005 | 03:30 PM
Crashton's Avatar
Crashton
Well in 40 years I've NEVER had anyone else change my oil. I like to do it, gives me a chance to look things over good while I'm at it. Nice to see that the MINI should be no big chore to do. Thanks for the great links.
Chuck
Old Sep 30, 2005 | 04:46 PM
Rev. Limiter's Avatar
Rev. Limiter
Chuck
No big chore, Crashton. You just have to hold your tongue right to get the oil filter back on without cross threading the #%&@# thing...
Old Sep 30, 2005 | 05:52 PM
Yucca Patrol's Avatar
Yucca Patrol
I use the same 1/2 inch drive 36mm socket from Sears and it works just fine. No need for the shallow one although it would be just a tad easier with it.
Unlike Global Imports in Atlanta, I am easily able to replace the o-rings on the canister without breaking it and causing an oil leak!
Old Sep 30, 2005 | 06:02 PM
05LiquidYellow's Avatar
05LiquidYellow
Yea, I've done mine 3 times now. Not very difficult. Just got a 36mm from Sears. In a few thousand miles I'll get my first free one!!
Old Sep 30, 2005 | 06:21 PM
Smokey's Avatar
Smokey
Yup me too! I haven't read all the links, so if this is already mentioned...sorry.
To help get the filter cover to thread on correctly, I "mount" the filter (just the filter) to the engine block to open up the hole. Then remove it and mount it to the post in the cannister. Make sure it's centered and then hand tighten the assembly, no problems. The socket doesn't come out until I've got it all the way snugged down.
If you feel around with your fingers you can tell if it's starting to cross thread before any damage has been done.
Old Sep 30, 2005 | 06:27 PM
2Miniacs's Avatar
2Miniacs
I do my own in between the free ones. It's easier if you buy a lift (see gallery) as it's much easier to get under the car
Old Sep 30, 2005 | 06:53 PM
Crashton's Avatar
Crashton
I guess since the dealer will do a few changes for free I might find myself at the dealer for those. All the others will be done by me.
Chuck
Old Sep 30, 2005 | 07:12 PM
coopercrazy
Thanks for all the help/replies guys.
I change the oil myself on the boat, big block v8.
For the 1st oil change at 500mi for break in, is it ok to do myself too?
Sorry for all the questions... silly nubie.
Old Sep 30, 2005 | 07:30 PM
Rev. Limiter
Originally Posted by coopercrazy
*snip* For the 1st oil change at 500mi for break in, is it ok to do myself too?
Yep. Did the first one myself, but changed to Mobil 1.
And the only dumb question is the one not asked... :smile:
CardinalsRule
Jun 11, 2016 04:34 PM
molala
Oct 2, 2015 01:53 PM
Sep 4, 2015 09:10 AM
Sep 3, 2015 03:01 PM
Sep 2, 2015 09:05 AM
