R50/53 Mini Motorers w/ HK systems
Originally Posted by jollybengali87
Hey Mini Motorers w/ HK systems
I have heard from other forums that HK system has a notorious "door rattle" due to the bass. Is the true?
I do have this annoying habit of putting a positive spin on things...
so IF I develop this rattle, it will be just the excuse I need to remove the door cards and stuff in some dynamat material, which I have been wanting to do ANYhow... :smile:.
A super easy How-To on MINI2 describes how to fix it, by taping/padding some of the panel's edges, and around the speaker grille...
Easy and cheap
Tatt
The rattle comes from the cover and speaker vibrating together. I had it my car and it was annoying. It is easy to fix yourself though. There are a couple of threads about it too. The HK system is good in my opinion. I wouldn't let the rattle keep you from getting it.
Tatt hit it right on the head, it's a common problem but by no means a Universal one... Take my 03 Cooper, 31k miles with HK, no rattle...
Big Time Rattle !
I drove my wife's Electric Blue 2004 "S" today and there was a horrible rattle sound in the door.
Turns out the sound came from behind the handle.....hairbrush, lotion, two empty CD boxes, two dollars worth of change,:smile: .....sorry, just had to say that.
Actually, we've had no problems so far.
Turns out the sound came from behind the handle.....hairbrush, lotion, two empty CD boxes, two dollars worth of change,:smile: .....sorry, just had to say that.Actually, we've had no problems so far.
Glad Martha is out of jail, maybe now I'll neaten-up my life a bit,
Tatt
Dealer just added dyna-mat to both of my doors because of the rattling, and they even replaced a door panel at the same time because of fitment issues.
It is a problem in a lot of HK systems, but nothing to be worried about. Worse case, you just bring it in under warranty and they fix the problem for you.
Originally Posted by tattman23
LOL Matt i so feel your pain! <hi-five smiley>! ooops wait, I got all that accumulated STUFF in my MCS, but strangely, I'm the only one who DRIVES it!
Tatt
Tatt
Tatt
Cleanliness is next to Hi-Fidelity (Stan Freberg said that),
Tatt
No Rattles Down South
It has been said better above. The HK rattle is an issue but not universal. I have about 4500 miles on my '05 MCS. I've driven it through CA, AZ, NM, TX, Mexico and the HK system plays on without rattles in Guatemala on roads that are "less than even."
It is a very nice stereo system though I usually just leave it hooked up to the iPod.
Saludos
Saludos
Rattles here. The 05 fix is somewhat different to all these posts referring to MINI2, etc...I performed this on my 05, broke two clips off the tweeter cover, and had some issues locating how to remove the arm rest.
If ya do need help you can PM me.
My door speakers used to rattle with music that was heavily bass oriented. I turned the bass down and faded it a little and now only the extremely bass oriented music makes the speaker area rattle(The rap group NWA's music is one such group).
if you want to know if you have the door rattle or not here is the formula to test out your system - the best ive found:
Hotel California - The Eagles ( Hast to be ORIGINAL, not the live one)
set it to MINI h/k
bass up one click from middle
trebble up 3 clicks from middle
turn driver off
and set it to about 3/4 to full power. this will tell you if you have the rattle or not. it mostly comes from guitar bass and not drum bass, i think it has something to do with the frequency.
hope this helps -
rednwhite
set it to MINI h/k
turn driver off
hope this helps -
rednwhite
I'm going to chime in, then hi-jack this thread.
Chime in - on certain songs (I haven't tried Hotel California yet) I'll get a rattle, but it is not over powering and easily ignored by reving to 6800 RPM!
Hi-jack - when playing a CD, is there a way to get the display to show something other than what track is playing - i.e., the elapsed time of the song or time remaining?
Thanks!
Thanks!
Update:
32,500 miles on Cooper when traded in with no HK rattle
756 miles now on the Cooper S, had a rattle once from the passenger side speaker. Definately from the speaker (went away when I turned the radio off) but only happened that one time, no rattle since...
It's more of a vibration than a rattle, and the annoying thing is that is usually does it when the volume is lower, but their is heavy bass. For instance (warning, possibly obscure band name coming up) the first Clem Snide CD has no drums on it - they used a stand-up bass instead. The songs are really mellow, but the bass notes seem to vibrate every panel in the car. It's not a noticeable with loud music.
I haven't had the car back to the dealer (04 MCS), but hopefully they'll take care of it.
My dealer fixed my door rattle 4 times now. The 4th time they were like "well we've done everything in the book, is it ok to do what we think will work". They lined the whole inside of the doors with foam, then ran velvet tape all around the edge. Rattle is gone and the bass sounds incredible because of the foam.
. I'll fix it later, it doesnt bother me that bad
