R50/53 Saving a R50 One 7
Old Nov 11, 2024 | 11:37 AM
  #126
ssoliman's Avatar
ssoliman
sorry to hear its not working. interested to see how the clutch kits compare. going through this myself currently
Old Nov 12, 2024 | 01:15 PM
  #127
LukasH's Avatar
LukasH
Thanks. Tomorrow evening I have a couple of hours, if all goes well I might get the gearbox out.
Curious to know what caused your issue once you figured it out.
Old Nov 12, 2024 | 02:21 PM
  #128
ssoliman's Avatar
ssoliman
yes sir, you know i will update with details. i'm currently in a holding pattern. waiting on parts. many, many parts
Old Nov 19, 2024 | 10:21 AM
  #129
LukasH's Avatar
LukasH
So I took the gearbox out. I was hoping to find something silly like putting the clutch in backwards. But unfortunately everything looked fine... Compared the clutch bearing/disc/housing and didn't find anything really. The design is definitely different compared to the LUK one but then again, a Valeo is also different compared to that.
So I made the not so fun decision to put the old clutch kit in, just to see if that resolved the issue. If not then I know the new clutch is fine and I need to look elsewhere. This does however mean I will have to pull the gearbox again...
Question: as I am looking to do as little work as possible, can I start the car and shift gears without putting the subframe and front end back on?
I think I can when putting the axels, gearlinkage and all electrics back in but then again, you never know if I overlooked something.
Nothing wrong here
Nothing wrong here
Clutch disc was not put in backwards
Bearings look very similar
Clutch housings do have a different design
This was the only question mark I had. The discs differ quite a lot in thickness. Not so much in clutch material but the new one is definitely sitting higher.
Old Nov 19, 2024 | 12:22 PM
  #130
slofut's Avatar
slofut
I think that last pic is telltale. Some diligent measuring is in order. Your symptoms sound like the clutch disk is not being released. Maybe even bolt the trans back up and use a borescope to watch pressure plate operation? That clutch disk difference looks very suspicious. I would prob call valeo tech supp first.
You cant change the position of the flywheel face, so I suspect that clutch disc is always contacting the flywheel.
Old Nov 19, 2024 | 12:28 PM
  #131
slofut's Avatar
slofut
Cool bike btw… what is that?
Old Nov 19, 2024 | 01:49 PM
  #132
Eddie07S's Avatar
Eddie07S
+1
Nope, not liking the friction plate differences.
Old Nov 19, 2024 | 05:52 PM
  #133
ssoliman's Avatar
ssoliman
the plot thickens
do you still have the old flywheel or did you not replace that? If you still have it use it to take some measurements;
-measure from the back of the flywheel to the top of the tines on the pressure plate
-measure from face of the splines on the clutch disk to the top of the tines
-compare the measurements to stock
your new pressure plate looks like it is not self-adjusting, that means the tines will go closer to the flywheel as you tighten it down on the flywheel
someone can correct me if I'm wrong, the throw out bearing will be pushed up against the tines of the pressure plate when the trans is installed. If it's further back you may not get enough push from the slave to disengage the clutch disk.
about the clutch disk, if the face does not make contact with the pressure plate or the glide tube on the trans side, and does not make contact with the flywheel it should be good. Sounds like you are ok there. If not, you would hear it and see damage
*tines is a new word to me and im not sure I spelled it right
Old Nov 19, 2024 | 11:28 PM
  #134
LukasH's Avatar
LukasH
You guys are right. After measuring the new clutch plate + cover and comparing it to the old the there is a +5mm difference. @ssoliman is on the money. If the look at the picture below you can see the gap at the clutch cover spring/flex part is larger. This would mean the travel distance is larger which the slave cylinder just can't cover. I wouldn't be surprised if this is the reason which my old slave cylinder failed; over stretching the rubber seal.
Left the old LUK, right the new MecArm (Italian clutch brand)
Old Nov 20, 2024 | 05:30 AM
  #135
slofut's Avatar
slofut
Actually, you don't want constant contactthrowout bearing to pressure plate fingers, you want a slight clearance so the bearing isn't always spinning and causing premature wear. There is actually a spec for that clearance but idk what it is on a mini.
Old Nov 20, 2024 | 11:31 AM
  #136
ssoliman's Avatar
ssoliman
thats what i've always heard also slofut.
there's a spring in the slave so that it extends out. it will hold the bearing against the pressure plate. i think the allowance / dimensions work out so the bearing is tight / touching the tines
here is what it looks like on bmw's
Old Nov 20, 2024 | 12:36 PM
  #137
LukasH's Avatar
LukasH
Its our kid transportation bike
Cool features are 2 kiddy seats, windscreen, extended steering arm, steering lock and a heavy duty stand:
In other news:
So I just bolted up the bare minimum to start it up with the old clutch in it and sure enough it shifts smoothly through all the gears. So it's not a badly bleed slave cylinder, it's not something I did wrong when rebuilding the gearbox with all new bearings.
It's the cheap ($70) MecArm clutch. For those in Europe NEVER BUY THE MecArm MK10190 even though TechDoc states it's the right one for your Mini R50 and the OE numbers match!
The question now is, do I buy a new LUK or Valeo one? I have the Valeo smf kit in my R53 but the LUK is the factory standard one.
Old Nov 20, 2024 | 05:02 PM
  #138
ssoliman's Avatar
ssoliman
that's good news! I bought the Valeo kit but that was based on price. its going in my son's r50. college car.
this is my first experience with installing a new clutch into the mini so I cant recommend one or the other
Old Nov 21, 2024 | 05:01 AM
  #139
slofut's Avatar
slofut
Ssoliman, I didn't know that about the bmw transmissions, that's interesting, I'll have to look into that. My 635 is older and I'm pretty sure the bearing doesn't ride on the tines when relaxed, but that goes back some years, things have changed since then, although I set up my t56 in my 71 corvette with clearance too so I'll be paying attention as I have a few more projects to complete before I'm done wrenching. Also have to do the clutch in my mini, and the head gasket...
Old Nov 22, 2024 | 06:38 AM
  #140
LukasH's Avatar
LukasH
Went ahead and ordered a new LUK clutch kit. Although I slightly fancy the Valeo set I didn't want to take any risk so replacing a LUK with a LUK which is the OEM anyway.
Old Nov 22, 2024 | 07:33 AM
  #141
Eddie07S's Avatar
Eddie07S
I think that was a good choice.
Old Nov 26, 2024 | 10:15 AM
  #142
LukasH's Avatar
LukasH
Since I'm waiting on parts, again I decided to tackle some lipstick jobs; respraying the wiper arms and making the headlights look a bit better.
For the headlights I used to do the 800/1200/1500/2000 wetsand + polish trick but that does only last one year. So this time I wanted to use clear coat instead of polish. And boy that worked like a treat! One down another one to go.
Btw doing this job is so much easier when it is up on jack stands, saves you a lot of back ache
Before, faded by the sun
After
After
Before
Before
Stage 1
Stage 1
Stage 3
Stage 3
Stage 4
Stage 4
Yellow milky stuff (plastic)
Packed up
Packed up
Sprayed
Sprayed
Before and after in one shot
Old Nov 27, 2024 | 05:23 PM
  #143
ssoliman's Avatar
ssoliman
That lens looks like crystal 🤩
Old Dec 5, 2024 | 10:12 AM
  #144
LukasH's Avatar
LukasH
Short but sweet update: fitted the new LUK clutch and tested it with a (bare minimum) running engine and it works perfectly. One thing I noticed was hoe much lighter the clutch pedal is compared to that faulty MecArm clutch kit (and we all know how heavy the LUK is!)
Old Dec 5, 2024 | 02:14 PM
  #145
ssoliman's Avatar
ssoliman
cheers!
Old Sep 10, 2025 | 07:44 AM
  #146
ezanner's Avatar
ezanner
This has been a great thread. Thank you! Hope you’ll update.
Marxmini
May 16, 2023 09:12 AM
bodydrp
Jul 23, 2020 04:25 PM
Oh Six Mini
Sep 4, 2019 05:53 AM
darianquayle
May 26, 2017 11:11 AM
Ironraven
12
Oct 9, 2009 04:35 PM
