R50/53 [Edited] The Berkeley Cooper S Rebuild
Old Oct 26, 2022 | 08:25 AM
  #51
Rebound's Avatar
Rebound
I’m narrowing it down.
I swapped the starter and AC relays. Two loud clicks, and in the third time, it started!!! It started!!! And it ran!
But I shut it down and it would not restart. This is making me think I need to check the cable to the starter solenoid.
Old Oct 26, 2022 | 08:53 AM
  #52
ssoliman's Avatar
ssoliman
Sounds like loose connection / ground issue.
id check at the battery and starter first
Old Oct 26, 2022 | 02:51 PM
  #53
ChiefM's Avatar
ChiefM
Originally Posted by Rebound
It started!!! And it ran! .
It's about time! You had me racking my brain and it was driving me crazy.
Old Oct 26, 2022 | 06:41 PM
  #54
Rebound's Avatar
Rebound
Problem Solved!
Tested battery voltage first. Then tried a jump pack for extra power. No go.
Swapped relays, it started exactly once.
Checked voltage at starter, it was good.
Then, I brushed my hand over one of the nuts on the starter solenoid, and something moved! Aha! There are three nut/bolts: 12V power from battery, 12V trigger from the relay inside fuse box, and a cable between solenoid and starter (no external cable,). It was this third bolt that was missing a nut. Must have removed it when the starter was off the car. I threaded a bolt and tightened it up, then re-attached the battery. That was it!
I ran a scan tool and I have just one error:
P1.1234 DME: Fuel-Pump Relay, Primary Circuit - Input Low
Old Oct 26, 2022 | 06:48 PM
  #55
dmath's Avatar
dmath
Yes! Congratulations!
Old Oct 27, 2022 | 12:55 AM
  #56
ChiefM's Avatar
ChiefM
Yay!!
Can't wait to hear how the test drive goes!
Old Oct 27, 2022 | 04:58 AM
  #57
Rebound's Avatar
Rebound
Originally Posted by ChiefM
Yay!!
Test drive will go terribly, if I don’t bleed those brakes first!
Thank you so much for your enthusiasm and support! You helped a lot!
Old Nov 6, 2022 | 01:00 PM
  #58
Rebound's Avatar
Rebound
I thought I’d be driving the Mini today. I have very little left. I compressed the clutch slave cylinder and then attached a pressure bleeder and pumped it up. I set a five minute timer, and it dropped two PSI. Then I found brake fluid on the floor.
Bummer. So I order a new master cylinder plastic reservoir, which is probably the culprit. I’ll finish the other odds and ends this week, the reservoir arrives Wednesday or Thursday, and then I’ll bleed the system and wrap this thing up, assuming it’s the reservoir that gave up.
Old Nov 6, 2022 | 01:16 PM
  #59
cooper48's Avatar
cooper48
Check out ModMini on YouTube for how to install and bleed that master cylinder.
Old Nov 6, 2022 | 02:12 PM
  #60
Rebound's Avatar
Rebound
Thanks! I’ve watched all the ModMini videos. That guy is an incredible resource.
But I’m only going to replace the plastic reservoir, not the whole master cylinder. Like all things BMW/Mini, it’s usually the plastic. BMW plastic just isn’t very good for some reason.
Old Nov 6, 2022 | 02:41 PM
  #61
ChiefM's Avatar
ChiefM
Sorry to hear about the master giving up the ghost. Better it did it now than when you are out driving. I am still pulling for ya!!
Old Nov 6, 2022 | 03:08 PM
  #62
Rebound's Avatar
Rebound
Quitting is not an option.
Old Nov 11, 2022 | 03:15 PM
  #63
Rebound's Avatar
Rebound
Drove it!
She runs! It was dark and raining, so I just took a quick driveway test to shift gears and try out the steering and brakes. It goes, it stops, it steers!!!
Tomorrow is the shakedown drive, then I’ll get the inspection sticker.
Old Nov 12, 2022 | 05:54 PM
  #64
ChiefM's Avatar
ChiefM
Old Nov 13, 2022 | 09:02 AM
  #65
Rebound's Avatar
Rebound
We had a nice long drive. It passed inspection. I replaced a broken window regulator, so now the passenger window works. I still need to fix the leaking antenna base, and the power steering does not seem to be working. I’m going to get it fixed under the recall.
Old Nov 13, 2022 | 09:46 AM
  #66
ChiefM's Avatar
ChiefM
YAY!!
I love a good ending.
It's 37 degrees and windy. I have no plans to do anything outside today!
Old Nov 13, 2022 | 10:26 PM
  #67
jcolletteiii's Avatar
jcolletteiii
Not sure how much extra it would cost, but I regret not having them install new lines when I had my PS service done while they were in there. I can always do them when I drop the front subframe next year to clean/restore it and replace the oil pan gasket.
Old Nov 17, 2022 | 03:13 PM
  #68
Rebound's Avatar
Rebound
What would new lines do?
Old Nov 17, 2022 | 04:25 PM
  #69
Here2Go's Avatar
Here2Go
NAM Community Team
Mine were leaking and got worse over time (2months). Nearly 3-4 oz a day! New to working on my Mini - I eventually mustered the nerve to do the repulsive job of repair/replacement.
I purchased a pair if no-name-brand PS lines and preformed the installation (2.5hrs). The lines cost me $28 which included heatsheilds, crush washer & 2wo worm clamps. That was back in 2018. Hasn't leaked a drop since.
Old Nov 18, 2022 | 02:20 AM
  #70
Rebound's Avatar
Rebound
Update
It’s running great, and it’s a blast! I’ve put over 150 miles on so far. Very fun car!
I only have one fault code, P1234, and it doesn’t seem to be affecting the car, but I ordered a new fuel pump anyway. And the power steering gave up, so I’ll sort that out.
When I bought new tires, the installer told me that one of the wheels was slightly bent and needed to be double balanced. The car shimmies a bit at 90mph, so I’ll probably replace the wheels in the spring. I’ll keep an eye out for a good set.
After that, I’ll deal with the cosmetics.
Old Nov 19, 2022 | 02:25 PM
  #71
jcolletteiii
Prevent 20 year old crusty hoses from spewing flammable stuff all over your engine bay?
Braminator
Apr 18, 2013 03:16 PM
900darmah
Jun 9, 2008 08:01 AM
Big K
Mar 9, 2008 08:07 PM
Super Coop
15
Oct 3, 2005 05:30 PM
minibill
Jul 23, 2003 01:22 PM
