R50/53 Cannot get CV axle to seat in trans
Old Apr 16, 2022 | 01:27 PM
indianajonesy's Avatar
indianajonesy
Like the title says, cant seem to get the splines to seat or at least go deep enough. I can still see the grooved ring above the splines and can’t seem to get it any deeper in. I pulled it out and as near as I can tell it’s identical in length, spline count, etc. Not my my first axle job, but I’m stumped and could use some ideas.
Old Apr 16, 2022 | 01:51 PM
AcidK1's Avatar
AcidK1
There are 2 different inner cv shafts, outer cv joints are the same though. Not sure what the counts on them are but if it's not going in I would assume it's the wrong one
Old Apr 16, 2022 | 02:08 PM
indianajonesy
That was my first thought as well, but my understanding is that there’s a difference in length in the other version. Having checked, length is the same so my thought is it’s the right part. Of course it could be after market incompetence, but open to other thoughts as well.
Old Apr 16, 2022 | 11:58 PM
AcidK1's Avatar
AcidK1
When I changed from the midland to the getrag I did not notice any difference in length, only that the inner cv was the only difference. Have you tried gently moving the opposite wheel while pushing the cv in? They can take a sudden shunt in to get them in, almost trying to catch it by surprise lol.
Old Apr 17, 2022 | 07:17 AM
mrbean's Avatar
mrbean
I had a similar issue with a remanned axle. There was debris under the c-clip which prevented it from squeezing down.
Remove clip,clean groove. Replace the clip with a new one - you can't remove it without damaging it - and also they're one time use only.
Old Apr 19, 2022 | 04:44 PM
Zsm's Avatar
Zsm
When we replaced the faulty aftermarket passenger side CV axle with a GKN, I too struggled for a bit. Keep the axle on the same plane and as straight in as you can. If the axle is going in at even a slightly off line, it will bind.
Old Apr 19, 2022 | 05:15 PM
r53racer's Avatar
r53racer
+1 on moving the opposite side or try to slowly/gently rotate the axle by hand if you can and the little by little try. hope you get this sorted.
wojtek@pagacz.ca
Aug 27, 2018 12:16 PM
jglover
Apr 23, 2018 06:24 AM
srponies
Dec 6, 2013 01:09 PM
idickers
Dec 22, 2011 04:03 AM
myla2003
Dec 11, 2009 08:14 AM
