R50/53 INPA Cable for R53
Old Apr 2, 2022 | 06:59 PM
Here2Go's Avatar
Here2Go
NAM Community Team
INPA Cable for R53
Did a bit of googling -
Getting prepared for a tune on my slightly modded '04 R53.
This cable was recommended/linked in a previous post here on NAM:
INPA K+ CAN with Switch INPA K+ CAN with Switch
. However, the description does not mention/compatible with an R53.
One comment/review stated that it worked on a '06 R50.
Is this the correct cable to purchase? Will this cable, via a remote tune, work with Windows 10?
Thanks.
Old Apr 2, 2022 | 07:43 PM
cooper48's Avatar
cooper48
Here's the version I have for my R53 - works perfectly.
Amazon Amazon
Old Apr 2, 2022 | 07:44 PM
cooper48's Avatar
cooper48
Also, I used Windows 10 with this cable for my remote tune.
Old Apr 2, 2022 | 07:46 PM
MCS4FUN's Avatar
MCS4FUN
Curious from your related topic, what tune you're planning on and what source? Personally, I'd worry about "bricking" the ECM/ECU and (literally) be dead in the water by loading a file that subsequently corrupts. So, the INPA cable is prox $36 shipped. How much for the tune sent in soft file format? My conservative nature suggests better instead (for me) to send the entire module to WMW (or comparable competent shop) for $300 total cost plus postage. I'll stay "tuned" (so to speak) on the sidelines...
Old Apr 2, 2022 | 08:00 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
lol if it's adriancl doing his tuning , which i PRAY it is...hes got nooooooooothing to worry about.
wmw v Adriancl tunes arnt even a comparison..i got a fully built motor thats Adriancl has tuned and it runs SPOT ON. Bvh, sprintex at 21psi ,550cc injectors and FULL boltons like 3in throttlebody, intake, ported sneed4speed Manifold, no cat 421 headers ectectect. I'd trust Adriancl over anybody anytime unless they were dyno tuning it in front of me..
Old Apr 2, 2022 | 08:16 PM
cooper48's Avatar
cooper48
+1 on Adrian - super nice and super helpful. Adrian's tuned 40+ Minis on this forum. He tuned my 2004 R53 remotely and I couldn't be happier. I also switched to the MS5150 (facelift) ECU version prior to the tune. That would also be my recommendation for better performance.
Old Apr 7, 2022 | 05:04 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Thanks for the feedback, all.
Ordered the cable. One with a switch was recommended.
Still going remote..
Notwithstanding:
Still getting great milage as long as cruising RPMS stay within 3500 - 3800 = (228 - 230 mi/tank @ initial red illumination before E). Not so great in heavy stop and go traffic...I can almost, literally, watch my needle drop.
Pick up/performance is outstanding in conjunction w/15% pulley.
Old Aug 25, 2022 | 04:00 PM
dmath's Avatar
dmath
When this thread first appeared, I added the cable recommended by @cooper48 to my Amazon save-for-later list. Now that I'm ready to try a couple of things via INPA, I moved the cable to my cart only to find that the expected delivery date is October 11. D'oh! In a somewhat older thread, Adrian recommended a cable but that is now a dead link. I could just choose one from the many available but I'd prefer to have a recommendation from a trusted NAMer. Can anyone point me to a cable that definitely works with the R53? Thanks.
Old Aug 25, 2022 | 04:12 PM
MCS4FUN's Avatar
MCS4FUN
^^^ Sent PM but items not currently available from my sellers either...
Old Aug 25, 2022 | 05:16 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Here is a link to the
INPA cable INPA cable
and
MPPS V18 ECU cable MPPS V18 ECU cable
I purchased from Amazon when adriancl remote tuned my R53.
They are both still available.
Both cables worked flawlessly - However, please be aware that the INPA software cd that came with my cable was an obvious return and the previous purchaser replaced the cd/software with a "home burned" cd, hacked installation version.
It wasn't a problem for me since adriancl remotely installed all the software needed for the tune.
Since I decided not to return the INPA, it maybe unlikely you will receive a hacked software. I purposely did not return it to insure it was taken out of circulation for the next unsuspecting buyer.
Good luck!
Old Aug 25, 2022 | 05:31 PM
MCS4FUN's Avatar
MCS4FUN
^^^ Agreed, I didn't need or use anything other than essential adapter cable hardware with INPA software file provided by @adriancl (downloaded in advance and ready for his use during my own remote tune). Adrian isn't secretive about that file as posted as recently as 5 days ago here: R50/53 NCS-Expert - post #2 Another example of not just having "the tools" but knowing how to use those.
Old Aug 25, 2022 | 05:37 PM
dmath's Avatar
dmath
Thanks guys. This morning I installed INPA via the link Adrian posted in the thread MCS4FUN linked above, so I shouldn't have any use for a disc that may come with the cable.
I was aware that I need the INPA cable. Do I also need the ECU cable? I plan to do some coding of simple things like the rear fog light on my own (INPA cable, I assume). I also plan to have Adrian smooth out a couple of rough edges in my tune (very minor flat spot around 2800 RPM under moderate throttle). Does the latter require the ECU cable?
Old Dec 28, 2022 | 07:11 PM
mmesa 005's Avatar
mmesa 005
Hello cooper48,
I just purchased the same cable and as it has 4 switch positions (or appears to) what switch position did you use?
Thanks!
Old Dec 28, 2022 | 08:41 PM
cooper48's Avatar
cooper48
My switch is pushed all the way to the right (closest to the N in the K+DCAN label. If that doesn't make sense when viewing your cable shoot me a pic and I'll confirm.
Old Dec 28, 2022 | 09:52 PM
mmesa 005's Avatar
mmesa 005
cooper48,
All the way right makes sense and thank you! I am trying to eliminate all possible errors on my part. I have installed, uninstalled, umpteen times and yet to get Inpa working. I am using Windows 10 64 bit, may I ask what OS version you are using and what software package you were able to get working?
Thank you again!
mmesa005
Old Dec 29, 2022 | 10:12 AM
cooper48's Avatar
cooper48
Software/system is the same however I've not tried to program with INPA. My sole reason for downloading it was to let Adrian Nastase remote tune my car via the OBD II port.
You might try this video and see if it helps:
Old Dec 29, 2022 | 08:20 PM
mmesa 005's Avatar
mmesa 005
https://www.youtube.com/watch?v=MfuFA7noM0Q
I will give this a go, thank you!
Old Dec 29, 2022 | 11:44 PM
thevastdifference's Avatar
thevastdifference
I'm totally just starting out on getting INPA - I got the cable recently, but have yet to start installing. I'm running win 10 in S mode - do I have to get out of S mode first? Do I need to run win xp?
I clearly have more reading to do... thanks in advance!
Old Dec 30, 2022 | 06:06 AM
megaDan's Avatar
megaDan
I can't answer all your questions, but I can confirm XP is likely not needed. I'm able to run on a copy of Win7.
MiniManAdam
Jun 5, 2020 01:37 AM
speedman
May 23, 2020 05:45 AM
lamontcg
Tires, Wheels, & Brakes
Aug 10, 2018 03:41 PM
fullmoonguru
Electrical
Dec 14, 2017 04:59 AM
IQRaceworks
Jun 1, 2014 08:05 PM
