R50/53 Crank Pulley help PRW
Old Mar 24, 2022 | 05:29 AM
Mortification's Avatar
Mortification
Hey what’s up fellas… I’m currently having trouble removing this crank pulley from PRW. It’s a liquid gel filled crank pulley I replaced a while back. Reason for me removing now is doing timing chain kit and installing a upgraded camshaft. Long story short… when I installed this a while back I never took notice of how the puller holes are in completely different spots. I’m other words… I can’t use the mini tool to pull this sucker off because the holes are at a wider radius than stock.
I even called the manufacturer and they themselves are puzzled and have no clue how to remove which pisses me off even more. Anyone here have any ideas or has had this pulley and was able to successfully remove it? Any help is appreciated because I’m out of ideas honestly. I’ve tried other pullers from local parts store with no success on the holes aligning up
Old Mar 24, 2022 | 01:12 PM
Tombstone's Avatar
Tombstone
What brand fluid dampener do you have , or can you post a picture for a solution? Thanks
Old Mar 24, 2022 | 01:29 PM
cooper48's Avatar
cooper48
Check this out. Note the puller that you should be able to rent (for free) at AutoZone.
Old Mar 24, 2022 | 01:36 PM
cooper48's Avatar
cooper48
Also:
Old Mar 24, 2022 | 02:29 PM
Mortification
This is the pulley
Old Mar 24, 2022 | 02:31 PM
Mortification
https://www.youtube.com/watch?v=JiVwVaVY1VA
I tried this already. The tool isn’t wide enough to reach the 3 bolt points
Old Mar 24, 2022 | 03:18 PM
cooper48's Avatar
cooper48
Amazon Amazon
Looks like it may fit since its made for BMW.
Old Mar 24, 2022 | 03:21 PM
cooper48's Avatar
cooper48
This one appears to be adjustable and span noted on the illustration is not correct. Scroll down and you can see it's as wide as 11.8".
Amazon Amazon
Old Mar 24, 2022 | 03:38 PM
Tombstone's Avatar
Tombstone
[QUOTE=Mortification;4616870]This is the pulley
[/https://www.ebay.com/itm/Harmonic-Balancer-Damper-Pulley-Puller-Removing-Repairing-Garage-Tool-Set-/114001308922?mkcid=16&mkevt=1&_trksid=p2349624.m46 890.l6249&mkrid=711-127632-2357-0
Old Mar 25, 2022 | 06:58 AM
ChiefM's Avatar
ChiefM
Your pulley is like the old one I pulled off my R50. I used this:
Amazon Amazon
We ended up welding an old one to the pulley because it was stuck to the crankshaft.
Old Mar 25, 2022 | 08:12 AM
Mortification
Originally Posted by ChiefM
Your pulley is like the old one I pulled off my R50. I used this: https://www.amazon.com/Orion-Motor-T...NsaWNrPXRydWU=
for ****s sake lol… damn that’s all bad. Not looking good for me
Old Mar 25, 2022 | 08:55 AM
ChiefM's Avatar
ChiefM
The guy said he had never seen a dampener so stuck onto the crank shaft and he has done dozens of Mini Coopers.. Nothing wrong with the crank end and the new dampener went on just fine. Hopefully you don't run into the same issue. You shouldn't if you put it on not that long ago.
I just put a new dampener on my R52 and it came off nice and easy.
Old Apr 22, 2022 | 09:06 PM
muddflapp's Avatar
muddflapp
R53 Crank Pulley stuck
I have a 2003 MCS R53 W11 engine. I got a spray of fine clean oil on my back window from one trip to the grocery store and traced it to a glub, glub, glub leak out of the hole the crankshaft is jutting out of.
Dumb me, I did not replace the crank seal a couple of years ago when my stock type pulley fell apart. I looked around for my puller and bolts. Apparently, I have discarded them. New puller and 6x70mm bolts. washers not big enough. I stacked different size washers. I loosened the crank bolt and put it back in 4 or 5 turns with the fingers and aligned my puller trying to keep it on straight. Engine spins so I got the impact wrench. It pulled it out some but it bent up the three 6 mm bolts. With new 6x60mm bolts, I try again and I pulled out the threads of one of the three holes when it ejected one of the 6mm bolts across the garage. No jaw puller can get a bite. So am I going to have to weld something to it and use a slide hammer like below or is there another method? tap out the screw holes to something meatier? Tow it to a shop?
The crank bolt still has 3/8" left before I have to get a longer bolt or put a smaller headless bolt into the crank snout like the video below. This pulley is like the stock pulley.
Old Apr 22, 2022 | 09:12 PM
muddflapp's Avatar
muddflapp
These three holes are M6x1.0. Should I try and tap them to M7x1.0 or M8x1.25 just so I can get this thing off and buy another $200 one?
Last edited by muddflapp; Apr 22, 2022 at 10:13 PM. Reason: combined messages in the previous message
Old Apr 23, 2022 | 06:18 PM
ghostwrench's Avatar
ghostwrench
This is the puller I use to pull my harmonic balancer. It's branded Matco but I'm pretty sure a puller in this style can be found online or maybe Harbor Freight for less than I paid Matco for it. The rod in the top of the picture laying under the pulley is not part of the kit. That rod is one of 4 rods from a Lisle brand pulley that I use with my Matco puller to get the W11 pulley off with.
File Type: mov
Apexlate
Oct 21, 2020 05:31 AM
IIIIIII
Aug 29, 2014 02:11 PM
motonikki812
Mar 30, 2007 12:46 AM
sea_to_sky
Nov 8, 2005 02:32 PM
